Topic: [Question] Video Stream (Read 4722 times) previous topic - next topic
Hello,
I have an *.pls file for Winamp which is a Videostream!
Does there is a Plugin for foobar2k to play Video(streams)?
Short answer: no, and there will probably never be.
No, foobar2000 is not able to play videos. Depending on the video (container) format, you may be able to play the audio tracks contained in the video. It is not planned to add video playback capabilities to foobar2000.
Ok, thx
The main thing is that i can't increase the brightness in Winamp! It's to dark for me. Does anybody has a solution for me?
Ok, thx
[a href="index.php?act=findpost&pid=312884"][{POST_SNAPBACK}][/a]
Some other Video Player?
Which?  WindowsMediaPlayer can't read the .pls filetypes!
I thought .pls files were playlist files.  If so, then surely it must point at the video files.  If so, just play then directly.
I dunno, maybe I'm wrong.
In my fairly limited use of it, I would recommend [a href="http://www.bsplayer.org/]BSplayer[/url].  However, it doesn't suppprt .pls files.  You can change the video settings like contrast, brightness etc though.
Ok, thx
The solution might be to use a video player, and not an audio player, to play video. Not 100% sure though
You can save the pls file, open it with a text editor and get the video stream URL from it, and then you can play it with more players. IMHO.
Life is Real...
(But not in audio :) )
Theoretically, you *could* create a Video Viewer plugin in the foobar2000 API, but it would mean coding a fully-fledged media player within an API that wasn't designed for such a task. In other words, at this point it is unfeasable to create such a thing.
Use VLC or just Winamp.
Ok, thx
You can setup the brightness (and many more) directly in display properties / advanced / overlay - if you have ati card. It is better then do it in player because it does not decrease the performance.
Use ffdshow to increase the brightness and then play it in winamp if you like winamp.  Personally I would use MPC or something similar.
