Poll
Which Replaygain mode do you use for listening?
Track gain
[ 54 ] (17.7%)
Album gain
[ 208 ] (68.2%)
I don't use Replaygain
[ 43 ] (14.1%)
Total Members Voted: 375
Topic: Which Replaygain mode do you use? (Read 26294 times) previous topic - next topic
There's a lot of Replaygain related discussion going on lately, so I was wondering, which mode do people use for listening?
Sometimes I use trackgain, sometimes I use Albumgain.
fb2k 0.9 beta 13.
Both. It mainly depends on listening conditions. Outside, Track mode (through MP3Gain currently) is preferable. It breaks the composition coherence, but I could at least hear something from quiet tracks
I prefer album gain. It helps keep the 'mood flows' of the albums.
Eric
I usally use 'Track gain' unless it's an album without any pauses
Album gain makes much more sense to me.
Acid8000 aka. PhilDEE
I use album gain since I tend to listen to whole albums at a time.
Nero AAC 1.5.1.0: -q0.45
Album for album listening; track gain for randomness.
Album gain as I always listen to albums, rather than mixes.
If I make an MP3 CD for the car I apply album gain to all albums so that they are all of the same relative volume, so I can still shuffle the whole disc if I want.
I'm on a horse.
I don't listen to full albums all the time, but I still use album gain.  Some of my metal albulms (In Flames) have acoustics tracks that are too loud if I don't use album gain.
- FLAC/200GB external
- AAC 128 vbr/local
- iPod Nano 2G 8GB
This discussion gave me the idea of impleminting a fast track-album gain switch in foobar2000. Anyone think this is a good idea?
Yes markanini, that's a very good idea.
I constantly switch between them depending on whether I'm listening to a whole album straight through, or playing a mix. I've often thought that a really useful foobar plugin would be one that detects whether the next track is from the same album and adjusts the RG playback setting accordingly.
CJ
[a href="index.php?act=findpost&pid=312186"][{POST_SNAPBACK}][/a]
Very intelligent answer IMO.
I always used album gain. Last week I was listening to random tracks and noticed that one of them was too quiet (everything replaygained). Changed to track gain and voilá.
But most of the time I´d keep using album gain .
Album gain: I always use album gain for listening on the computer, hence the majority of the tracks I have are derived from albums. I absolutely can't stand gapless tracks that all of a sudden change in volume due to not using album gain, it literally drives me bananas. I also use album gain for tracks ripped from the same audio CD when making a backup audio CD.
Track gain: I use track gain only when making an audio CD from tracks ripped from different sources to make them have a similiar volume level so I don't have to fiddle with the speaker volume at all.
I listen with my Squeezebox3 that has a smart-gain setting. When I listen to an Album, it uses album gain, if I mix tracks it uses track gain.
ciao, TommyZ
Same here. I voted "Track Gain", but Pink Floyd's on Album Gain.
I always use Album mode. Even on shuffle I prefer it. And in my 'singles' directory where theres every track from a different source every track gets it's own album gain, pardon
flac 1.2.1 -8 (archive) | aoTuVb5.7 -q 4 (pc, s1mp3)
Album mode most of the time, because I normally listen to albums.
On the rare occasion I want to listen to tracks for an extended period, then I'll switch to Track mode.
If I'm creating mixes, then I use Track gain so I don't have to dork with the volume from song to song.
I mostly use Track mode, since I usually randomize my playlist, but I will switch to album mode if I'm listening to an album in track order.
IMO, if a track is quiet in the context of an album it should also be quiet in the context of a random playlist.  For this reason I only use album mode.
I agree completely. It's also based on more data so is statistically more sound. I have found the odd "hidden track" that's 20 dB down, for which I've simply made a manual adjustment of the Album Gain on that track alone.
Sheesh, talk about bring back an old thread....
Anyways, I always use Album gain as I only listen to entire albums and DJ mix sets.
JXL
Same here. If the album was loud compared to the rest of the album, let it be loud on a playlist, same for the quiet ones.
