Topic: The Definitive Custom Buttons Thread (Read 717786 times) previous topic - next topic
Reply #50
Call me a noob, but do I need any plugin to display theese buttons? As soon as I load any custom button the area it should be is blank. Always. Default however always work...
Reply #51
1) Right click on your buttons, choose "Customize" from the popup menu.
2) Click the [Tools] button at the bottom and select "Load from file..." from the popup menu.
3) Browse to the .fcb file you downloaded and click [Open].
4) Click [OK] and your new buttons should replace your old ones.
If you are creating your own buttons, remember that they need to all be the same height.  Only buttons the same height as the button with the largest height will show up.
Reply #53
@Yotsuya
That was exactly what I was doing.
@Migiel
Thanks, that solved it
I did use search, but I didn't know what to search for
Reply #55
my contribution:
download
Reply #56
New Buttonbar with Jyriks Buttons! (32x32)
((((( Strictly4me )))))
Reply #57
The new black: A remix of the black ClearONE style buttons.
Reply #58
Here my buttons... Soon there will be a updating
New round buttons:
Reply #59
Buttons DefaultUI
As the ColumnsUI-standard-buttons are a bit different from the DefaultUI-standard-buttons, I made a fcb-file with embedded DefaultUI-buttons.
libpng & zlib are neccessary.
[attachment=2475:attachment]
[attachment=2476:attachment]
Reply #61
Anyone looking for custom buttons that match the default foobar grey skin?  Check out these.
@dem0n (in post #19):  Thanks for the buttons, I liked them and am posting the individual buttons (slightly modified).  I modified to change white space in the corners to rgb(192,192,192) to match the default foobar toolbar color.  I also added another button.
Pics:
my uses from left to right:  stop, pause, play, previous, next, random, add files..., add directory...
[attachment=2490:attachment]
Reply #63
Just a set of round dark buttons i made for myself
smaller version:
Reply #65
 the link for the iFoo buttons on page 2 is dead, does anyone still have these?
Ignorance is bliss.
Reply #67
Reply #69
I just made the Stop-buttons. You probably can insert them yourself.
Reply #73
GANT-buttons grey, with coloured mouse over. (24x24)
[attachment=2345:attachment]
Hi
Is there a site where i can download those grey icons (as .PNG or .ICO) or did you just converted the original icons to grey with a picture editor ?
Reply #74
Yes, I just converted the original icons to grey! The original icons you can find here.
