This thread got me curious to see if I could switch from -V 2 to -V 3--vbr-new. So after all this time using --preset standard, I finally decided to do my first abx tests to see if I really needed it. I downloaded some of the test samples from ff123's site, and some from HA threads. The "infamous" ones like castanets, fatboy, as well as kraftwerk, the beatles.
In short, I could successfully abx all of them with -V 3 --vbr-new, and also also had success with -V 2 on 2 of 3 samples. But there was a difference between the successful tests from -V 2 to -V 3: the -V 3 tests were very quick and very confident, and the -V 2 tests took a bit longer and a few trials were pure guesses on my part, even though the overall test turned successful. So I'm sticking with -V 2.
The tests were done using some nondescript earbuds into an SBLive Value card using kx project drivers.
I didn't have the time or energy tonight to abx these samples with -V 2 --vbr-new, but maybe another time.
ABX logs for -V 3 --vbr-new:
foo_abx 1.2 report
foobar2000 v0.9 beta 5
2005/07/23 21:49:33
File A: C:\My Documents\test files\castanets.flac
File B: C:\My Documents\test files\v3new - castanets.mp3
21:49:34 : Test started.
21:50:14 : 01/01 50.0%
21:50:22 : 02/02 25.0%
21:50:30 : 03/03 12.5%
21:50:39 : 04/04 6.3%
21:51:00 : 05/05 3.1%
21:51:06 : 06/06 1.6%
21:51:19 : 07/07 0.8%
21:51:32 : 08/08 0.4%
21:51:38 : 09/09 0.2%
21:51:46 : 10/10 0.1%
21:51:53 : 11/11 0.0%
21:51:57 : 12/12 0.0%
21:52:01 : 13/13 0.0%
21:52:06 : 14/14 0.0%
21:52:20 : Test finished.
Total: 14/14 (0.0%)
foo_abx 1.2 report
2005/07/23 21:59:15
File A: C:\My Documents\test files\kraftwerk.flac
File B: C:\My Documents\test files\v3new - kraftwerk.mp3
21:59:19 : Test started.
22:02:21 : 01/01 50.0%
22:02:27 : 02/02 25.0%
22:02:33 : 03/03 12.5%
22:02:41 : 04/04 6.3%
22:02:45 : 05/05 3.1%
22:03:02 : 06/06 1.6%
22:03:19 : 07/07 0.8%
22:03:28 : 08/08 0.4%
22:03:33 : 09/09 0.2%
22:03:44 : 10/10 0.1%
22:03:53 : 11/11 0.0%
22:04:00 : 12/12 0.0%
22:04:05 : 13/13 0.0%
22:04:07 : Test finished.
Total: 13/13 (0.0%)
foo_abx 1.2 report
2005/07/23 21:53:39
File A: C:\My Documents\test files\fatboy_30sec.flac
File B: C:\My Documents\test files\v3new - fatboy_30sec.mp3
21:53:43 : Test started.
21:56:37 : 01/01 50.0%
21:56:57 : 02/02 25.0%
21:57:17 : 03/03 12.5%
21:57:36 : 04/04 6.3%
21:57:42 : 05/05 3.1%
21:57:49 : 06/06 1.6%
21:58:00 : 07/07 0.8%
21:58:08 : 08/08 0.4%
21:58:14 : 09/09 0.2%
21:58:20 : 10/10 0.1%
21:58:34 : 11/11 0.0%
21:58:45 : 12/12 0.0%
21:58:54 : 13/13 0.0%
21:58:57 : Test finished.
Total: 13/13 (0.0%)
ABX tests at -V 2
foo_abx 1.2 report
2005/07/23 22:08:38
File B: C:\My Documents\test files\v2 - castanets.mp3
22:08:39 : Test started.
22:10:23 : 01/01 50.0%
22:10:28 : 01/02 75.0%
22:10:38 : 02/03 50.0%
22:10:47 : 03/04 31.3%
22:10:56 : 04/05 18.8%
22:11:02 : 05/06 10.9%
22:11:08 : 06/07 6.3%
22:11:13 : 07/08 3.5%
22:11:23 : 08/09 2.0%
22:11:43 : 08/10 5.5%
22:11:55 : 09/11 3.3%
22:12:08 : 10/12 1.9%
22:12:18 : 11/13 1.1%
22:12:33 : 12/14 0.6%
22:12:52 : 13/15 0.4%
22:13:01 : Test finished.
Total: 13/15 (0.4%)
foo_abx 1.2 report
2005/07/23 22:13:25
File B: C:\My Documents\test files\v2 - kraftwerk.mp3
22:13:28 : Test started.
22:15:21 : 01/01 50.0%
22:15:30 : 02/02 25.0%
22:15:48 : 03/03 12.5%
22:15:55 : 04/04 6.3%
22:16:09 : 05/05 3.1%
22:16:19 : 06/06 1.6%
22:16:26 : 07/07 0.8%
22:16:35 : 08/08 0.4%
22:16:43 : 09/09 0.2%
22:16:51 : 10/10 0.1%
22:16:58 : 11/11 0.0%
22:17:04 : 12/12 0.0%
22:17:13 : 13/13 0.0%
22:17:14 : Test finished.
Total: 13/13 (0.0%)
foo_abx 1.2 report
2005/07/23 22:17:56
File A: C:\My Documents\test files\taxman.flac
File B: C:\My Documents\test files\v2 - taxman.mp3
22:17:57 : Test started.
22:20:35 : 01/01 50.0%
22:20:58 : 02/02 25.0%
22:21:13 : 03/03 12.5%
22:22:11 : 04/04 6.3%
22:22:23 : 05/05 3.1%
22:22:41 : 06/06 1.6%
22:22:52 : 07/07 0.8%
22:23:00 : 07/08 3.5%
22:23:10 : 08/09 2.0%
22:23:21 : 08/10 5.5%
22:23:35 : 08/11 11.3%
22:23:58 : 08/12 19.4%
22:24:18 : 09/13 13.3%
22:24:36 : 09/14 21.2%
22:24:57 : 10/15 15.1%
22:25:40 : 10/16 22.7%
22:25:42 : Test finished.
Total: 10/16 (22.7%)
About this
If you use -V2 -Y you will for sure also see a dramatic bitrate drop, the result will probably be not much larger than -V3.
[a href="index.php?act=findpost&pid=310539"][{POST_SNAPBACK}][/a]
I just wanted to mention that I could not successfully encode with the -Y switch with 3.97. I didn't see this switch in the documentation, and foobar just did nothing when I had the switch in the parameters.
