Topic: Please help, the nero plugin messed up (Read 3026 times) previous topic - next topic
There is a related post in the support section of this forum.
I have tried everything to get fubar2000 working again and its driving me nuts.
Here is what I did: I followed the instructions from a doom9 forum post:
http://forum.doom9.org/showthread.php?s=&p...6664#post566664
regarding the DTS to HE-ACC instructions there.
To make a long story short, it doesnt work, I could not even add dts files to the playlist without a big window poping up with a string of errors, and now even if I completely unistall, reboot, reinstall, reboot I cant get back the prior functionality that I had. I can't even add a dts file to the playlist
any ideas?
a little more info, I've tried to re-create what happened.
After I put foo_nero.dll, Aac.dll and aacenc32.dll into the components directory, I opend foobar2000 and when I tried to add a dts file to the play list I got this error:
INFO (CORE) : startup time: 411 ms
ERROR (foo_nero) : Failed to open plugin 'mp3PP.dll'
I get the same error even if I copy mp3PP.dll to the components directory. If I ignore that and try to convert I get:
INFO (CORE) : startup time: 500 ms
ERROR (foo_diskwriter) : Conversion failed.
The files I copied from nero are from Nero-6.6.0.14
have you got this in the foobar 2000 components dir ?
Foo_DTS
Don't Cross Post!!!
INFO (CORE) : startup time: 2703 ms
INFO (CORE) : opening file for playback :
INFO (CORE) : location: "file://G:\UNDEFINED\dts DTS T03 DELAY 0ms.dts" (0)
INFO (foo_nero) : Encoding with Nero Digital Audio (HE-AAC)
INFO (foo_nero) : Encoding to: file://E:\_\_ - _\_ - _.m4a
INFO (foo_nero) : Source: file://G:\UNDEFINED\dts DTS T03 DELAY 0ms.dts
INFO (CORE) : Clipping detected.
INFO (CORE) : attempting to edit file info : file://E:\_\_ - _\_ - _.m4a
INFO (CORE) : file info update successful on : file://E:\_\_ - _\_ - _.m4a
the guide works fine here
Just delete mp3PP.dll.  Unless you are using the mp3Pro encoder in Nero, it's absolutely useless.
Quote from: A_Man_Eating_Duck,Jun 24 2005, 09:17 PM
Foo_DTS
Oh God! THANK YOU!
I been going crazy here - why in gods name doesn't the current foobar2000_special.exe install that file? I mean, a week ago i
I installed the file from foobar2000.org and everything worked
fine, was this file removed for some reason?
Sorry about the crosspost, I just been going crazy
Thank you so much!
mugz
