Topic: EAC & Access Violations (Read 1860 times) previous topic - next topic
I recently wiped the drives and reloaded two of my computers:
• W2K Pro, SP4, HP9100b, all hotfixes applied up to June 2005
• XP Pro, SP2, Plextor PX-40TS, all hotfixes applied up to June 2005
Both machines are able to rip with CDex and Audiograbber, but EAC (.095b2) gives an Access Violation error and crashes.
• Switched to Native NT interface. Crash
• Installed winaspi 4.61. Crash
• Installed winaspi 4.71. Crash
• Installed ASAPI. Crash
I did reboots after each crash/install. I deleted EAC .095b2, cleaned the Registry and loaded EAC .095pb5. Crash.
I noticed that EAC kept losing my EAC/Drive/Compression settings. I went through each one of them tab by tab under the ASAPI interface and finally got EAC to rip to wave, but ripping directly to MP3 caused a crash again.
Then I switched from using the lame_enc.dll (3.92) to using the external lame.exe and suddenly everything worked fine. It's the same .dll that I was using in CDex and Audiograbber but it makes EAC give Access Violation errors and crashes.
It's a clean install, there are no other codecs or apps loaded besides what Windows put there. Anybody else run into this? Is there some other explanation or fix for these Access Violation errors? I tried the EAC forum but no success.
