Topic: [help] Drag drop tab name (Read 2200 times) previous topic - next topic
Hello  ... all is on the image
Thanks to ImageShack for Free Image Hosting
Hi, welcome =)
I use this, it works pretty good.
%album%\$directory(%_path%,2)
Hope it was what you wanted =)
Edit: Maybe it just works from explorer, the option to create name from folder is already there (you have it enabled on your pic)
I think it's the plugin you're using, foo_explorer or Albumlist? That need the ability to create the name, not sure.
Hi, welcome =)
[a href="index.php?act=findpost&pid=305625"][{POST_SNAPBACK}][/a]
Work nicce, thank you
I using Playlist Tree which can be found [a href="http://www.hydrogenaudio.org/forums/index.php?showtopic=29435]here[/url]
Your script not seem work with the music genre (rock, pop...)  ... Its that possible to have simply the node name and not use any infomation in the database like %album% %_path%?
After post the question, I found this solution for music genre...
%album%\$directory(%_path%,2)\%genre%
but it depent always de the infomation from the database, and not the nodes name
If you're using Playlist Tree, why not activate the option to create a playlist with the name of the node when you double click?  That is what I do.
