Topic: foo_vis_projectM (Read 167552 times) previous topic - next topic
foo_vis_projectM
Reply #150
I'm playing flac over my network on a dual display 1600x1200 x 2 via a 9800 Pro with ProjectM and I'm only sitting around 3-4% CPU usage.  I think you have something else going on there Moofar.  How do other opengl applications affect your cycles?
No mercy for the bandwidth impaired
foo_vis_projectM
Reply #151
I'm using the panel version 0.97.6.2. I'm having the same problem as jkwarras where it will freeze up my whole system after having it on for a while. Sometimes I can have it on all day and not have a problem and sometimes it happens after a few hours. It only happens when I have another program in front of it and then I switch to put foobar in the foreground. The whole system locks up for about 5 seconds at a time, then unfreezes for a split second and freezes for 5 seconds again, etc. My mouse cursor is frozen until the split-second unfreeze where it jumps to whereever I moved it.
The only way to get it unfrozen (besides rebooting) is to painstakingly move my mouse toward the X in the top-right corner and wait for it to jump to see how much I need to move it again. Once it's there I click it and it brings up an "end task" dialog box which then closes foobar and the system goes back to normal. Alt-F4 doesn't do anything. Or I can alt-tab to another window that completely covers foobar and the system will go back to normal until I bring foobar into focus again.
After closing foobar, opening it again causes the same thing. After this has happened, all video on media players get about 0.5 fps. If I remove the component after closing foobar and reopen it, foobar works fine, but freezes up again once I put it back. Only rebooting fixes it. I don't get any blue screen. foobar.exe has 99-100% CPU usage while frozen.
My system specs:
OS: Windows XP Corporate Professional SP2
Video: nVidia GeForce 6800 with latest drivers
DirectX 9.0C
If it helps at all, I get the same thing sometimes when I'm viewing a folder with videos in it and it's in thumbnail view. In task manager, it shows explorer.exe as boosting the CPU usage.
foo_vis_projectM
Reply #152
Hmm, similar problem, but with nVidia now.  Do you get any failure logs in your foobar2000 directory when this happens?  If not, I'll have to just leave the panel running on my computer for extended periods of time and see if it eventually crashes.  Also, are you using any presets beyond the ones that were included?
foo_vis_projectM
Reply #153
Well, I had it on all night last night and all day today and it works fine. There has to be something I do that locks it up. Perhaps it is one of the presets and if I happen to view it while that preset is going it locks up. I never thought of that before. I have 3 failure logs but I don't know which one is for this error (all 3 of them could be or only one)
failure.txt
Created Dec. 26, 2005
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 00E93210h
Access violation, operation: read, address: 00000004h
Call path:
WinMain=>app_mainloop
Code bytes (00E93210h):
00E931D0h:  10 3B C8 75 04 33 C0 EB 05 1B C0 24 FE 40 5E C2
00E931E0h:  04 00 56 8B F1 E8 14 00 00 00 F6 44 24 08 01 74
00E931F0h:  07 56 E8 31 54 00 00 59 8B C6 5E C2 04 00 56 8B
00E93200h:  F1 8B 4E 08 C7 06 48 A5 E9 00 85 C9 74 05 8B 01
00E93210h:  FF 50 04 8B 4E 14 5E 85 C9 74 04 8B 01 FF 10 FF
00E93220h:  0D 98 C9 E9 00 C3 6A 01 FF 74 24 08 E8 03 00 00
00E93230h:  00 C2 04 00 55 8B EC 83 EC 24 80 3D 94 C9 E9 00
00E93240h:  00 56 74 57 57 BE F0 A4 E9 00 8D 7D F0 8D 45 DC
Stack (0013F460h):
0013F440h:  00D3DB9C 7C9C93A0 77F643DD 7C9C93A0
0013F450h:  00000004 00000000 00D3D0A8 00000000
0013F460h:  01CEFE60 00E931EA 01CEFE60 00E931A8
0013F470h:  00000001 000003E8 00E92169 00E9C8FC
0013F480h:  00E9C8F0 00E90000 77C2C275 00000004
0013F490h:  77C2C2E3 0013F4D0 00E93CFA 00000001
0013F4A0h:  0094941C 00E90000 00031E90 00031E90
0013F4B0h:  0013F494 0013F58C 0013F58C 77C35C94
0013F4C0h:  00E9C8F0 0013F58C 00E98DDD 00000002
0013F4D0h:  0013F4F8 00E986C5 00000000 00E9875A
0013F4E0h:  00E90000 00000000 00000001 00000000
0013F4F0h:  0013F50C 002642D8 0013F518 7C9011A7
0013F500h:  00E90000 00000001 00000001 002642D8
0013F510h:  00000000 00264398 0013F59C 7C923F31
0013F520h:  00E986E5 00E90000 00000000 00000001
0013F530h:  000000FF 7C90E88E 00000000 00000014
0013F540h:  00000001 00000000 00000000 00000010
0013F550h:  20656D69 6F727245 0A0A2172 676F7250
0013F560h:  7C910945 7C91094E 01CC65D0 00000001
0013F570h:  00264398 7FFDF000 7FFD7000 00E986E5
Registers:
EAX: 00000000, EBX: 000003D2, ECX: 01CC65D4, EDX: 77C61AA0
ESI: 01CEFE60, EDI: 00E9C8FC, EBP: 0013F494, ESP: 0013F460
Crash location: "foo_history", loaded at 00E90000h - 00EA0000h
Loaded modules:
foobar2000                      loaded at 00400000h - 00452000h
ntdll                            loaded at 7C900000h - 7C9B0000h
kernel32                        loaded at 7C800000h - 7C8F4000h
USER32                          loaded at 77D40000h - 77DD0000h
GDI32                            loaded at 77F10000h - 77F57000h
ole32                            loaded at 774E0000h - 7761D000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F01000h
msvcrt                          loaded at 77C10000h - 77C68000h
COMCTL32                        loaded at 773D0000h - 774D2000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
utf8api                          loaded at 10000000h - 1000D000h
comdlg32                        loaded at 763B0000h - 763F9000h
SHELL32                          loaded at 7C9C0000h - 7D1D5000h
IMM32                            loaded at 76390000h - 763AD000h
LPK                              loaded at 629C0000h - 629C9000h
USP10                            loaded at 74D90000h - 74DFB000h
foo_abx                          loaded at 003A0000h - 003AC000h
foo_ac3                          loaded at 003B0000h - 003C3000h
foo_albumlist                    loaded at 003D0000h - 003DB000h
foo_ape                          loaded at 003E0000h - 003FF000h
foo_apl                          loaded at 00A40000h - 00A4A000h
foo_bitcompare                  loaded at 00A50000h - 00A59000h
foo_burninate                    loaded at 00A60000h - 00A6C000h
VERSION                          loaded at 77C00000h - 77C08000h
foo_cdda                        loaded at 00A70000h - 00A7E000h
foo_clienc                      loaded at 00A80000h - 00A8B000h
foo_console                      loaded at 00A90000h - 00A97000h
foo_convolve                    loaded at 00AA0000h - 00AEF000h
foo_dbsearch                    loaded at 00AF0000h - 00B08000h
foo_diskwriter                  loaded at 00B10000h - 00B22000h
WINMM                            loaded at 76B40000h - 76B6D000h
foo_dsp_crossfade                loaded at 00BB0000h - 00BB7000h
foo_dsp_crossfeed                loaded at 00BC0000h - 00BC6000h
foo_dsp_extra                    loaded at 00BD0000h - 00BE5000h
foo_dsp_nogaps                  loaded at 00BF0000h - 00BF7000h
foo_dsp_pause                    loaded at 00C00000h - 00C07000h
foo_dsp_skip_silence            loaded at 00C10000h - 00C17000h
foo_dsp_soundtouch              loaded at 00C20000h - 00C2B000h
MSVCP60                          loaded at 76080000h - 760E5000h
foo_dynamics                    loaded at 00C30000h - 00C37000h
foo_faac                        loaded at 00C40000h - 00C73000h
foo_festalon                    loaded at 00C80000h - 00DBE000h
foo_flac                        loaded at 00DC0000h - 00DDC000h
foo_flaccer                      loaded at 00DE0000h - 00DF6000h
foo_freedb                      loaded at 00E00000h - 00E2E000h
WS2_32                          loaded at 71AB0000h - 71AC7000h
WS2HELP                          loaded at 71AA0000h - 71AA8000h
foo_gym                          loaded at 00E30000h - 00E8E000h
foo_history                      loaded at 00E90000h - 00EA0000h
foo_id3v2                        loaded at 00EA0000h - 00ED0000h
foo_infobox                      loaded at 00ED0000h - 00EE3000h
foo_input_std                    loaded at 00EF0000h - 00F8E000h
MSACM32                          loaded at 77BE0000h - 77BF5000h
foo_lpac                        loaded at 00F90000h - 00F97000h
lpac_codec_api                  loaded at 00FA0000h - 00FAA000h
lpaccodec                        loaded at 00FB0000h - 00FD9000h
foo_masstag                      loaded at 01200000h - 01214000h
foo_matroska                    loaded at 01220000h - 01268000h
foo_mod                          loaded at 01270000h - 01279000h
BASS                            loaded at 01280000h - 012DA000h
foo_monkey                      loaded at 012E0000h - 012FC000h
foo_mpeg4u                      loaded at 01300000h - 01329000h
foo_nez                          loaded at 01330000h - 0135B000h
foo_null                        loaded at 01360000h - 01367000h
foo_ofr                          loaded at 01370000h - 01376000h
OptimFROG                        loaded at 01380000h - 013AC000h
foo_oggpreview                  loaded at 013C0000h - 014C1000h
foo_output_std                  loaded at 014D0000h - 014D9000h
foo_out_dsound_ex                loaded at 014E0000h - 014E9000h
DSOUND                          loaded at 73F10000h - 73F6C000h
foo_out_ks                      loaded at 01500000h - 0150B000h
SETUPAPI                        loaded at 77920000h - 77A13000h
foo_playlistgen_ex              loaded at 01510000h - 0151F000h
foo_pphsresample                loaded at 01520000h - 01530000h
foo_psf                          loaded at 01530000h - 015DC000h
foo_read_http                    loaded at 015E0000h - 015E9000h
foo_rgscan                      loaded at 015F0000h - 015FD000h
foo_scroll                      loaded at 01600000h - 01606000h
foo_search_ex                    loaded at 01610000h - 01618000h
foo_shn                          loaded at 01620000h - 0162F000h
foo_sid                          loaded at 01630000h - 01677000h
foo_spc                          loaded at 01680000h - 01691000h
foo_speex                        loaded at 016B0000h - 016C8000h
foo_tfmx                        loaded at 016D0000h - 016D9000h
foo_tta                          loaded at 016E0000h - 016E9000h
foo_tta_old                      loaded at 016F0000h - 016F9000h
foo_uie_albumart                loaded at 01700000h - 0170C000h
gdiplus                          loaded at 4EC50000h - 4EDF3000h
MSVCR71                          loaded at 7C340000h - 7C396000h
foo_uie_tabs                    loaded at 01730000h - 0173A000h
foo_uie_trackinfo                loaded at 01740000h - 0174B000h
foo_ui_columns                  loaded at 01750000h - 01787000h
foo_ui_std                      loaded at 01790000h - 017A7000h
foo_unpack                      loaded at 017B0000h - 017E1000h
OLEAUT32                        loaded at 77120000h - 771AC000h
foo_utils                        loaded at 017F0000h - 01801000h
foo_vis_manager                  loaded at 01810000h - 01818000h
foo_vis_simple_spectrum          loaded at 01820000h - 0182A000h
foo_vorbisenc                    loaded at 01830000h - 01941000h
foo_wavpack                      loaded at 01950000h - 01962000h
foo_winamp_spam                  loaded at 01970000h - 01978000h
foo_wma                          loaded at 01980000h - 0199A000h
WMVCore                          loaded at 086D0000h - 08916000h
WMASF                            loaded at 070D0000h - 0710A000h
foo_xa                          loaded at 019A0000h - 019AF000h
apphelp                          loaded at 77B40000h - 77B62000h
msctfime                        loaded at 755C0000h - 755EE000h
UxTheme                          loaded at 5AD70000h - 5ADA8000h
WINTRUST                        loaded at 76C30000h - 76C5E000h
CRYPT32                          loaded at 77A80000h - 77B14000h
MSASN1                          loaded at 77B20000h - 77B32000h
IMAGEHLP                        loaded at 76C90000h - 76CB8000h
ksuser                          loaded at 73EE0000h - 73EE4000h
CLBCATQ                          loaded at 76FD0000h - 7704F000h
COMRes                          loaded at 77050000h - 77115000h
cscui                            loaded at 77A20000h - 77A74000h
CSCDLL                          loaded at 76600000h - 7661D000h
browseui                        loaded at 75F80000h - 7607D000h
ntshrui                          loaded at 76990000h - 769B5000h
ATL                              loaded at 76B20000h - 76B31000h
NETAPI32                        loaded at 5B860000h - 5B8B4000h
USERENV                          loaded at 769C0000h - 76A73000h
shdocvw                          loaded at 77760000h - 778CE000h
CRYPTUI                          loaded at 754D0000h - 75550000h
WININET                          loaded at 771B0000h - 77256000h
WLDAP32                          loaded at 76F60000h - 76F8C000h
xpsp2res                        loaded at 20000000h - 202C5000h
dciman32                        loaded at 73BC0000h - 73BC6000h
DBGHELP                          loaded at 59A60000h - 59B01000h
Stack dump analysis:
Address: 00E931EAh, location: "foo_history", loaded at 00E90000h - 00EA0000h
Address: 00E931A8h, location: "foo_history", loaded at 00E90000h - 00EA0000h
Address: 00E92169h, location: "foo_history", loaded at 00E90000h - 00EA0000h
Address: 00E9C8FCh, location: "foo_history", loaded at 00E90000h - 00EA0000h
Address: 00E9C8F0h, location: "foo_history", loaded at 00E90000h - 00EA0000h
Address: 00E90000h, location: "foo_history", loaded at 00E90000h - 00EA0000h
Address: 77C2C275h, location: "msvcrt", loaded at 77C10000h - 77C68000h
Symbol: "free" (+0000005Ah)
Address: 77C2C2E3h, location: "msvcrt", loaded at 77C10000h - 77C68000h
Symbol: "free" (+000000C8h)
Address: 00E93CFAh, location: "foo_history", loaded at 00E90000h - 00EA0000h
Address: 77C35C94h, location: "msvcrt", loaded at 77C10000h - 77C68000h
Symbol: "except_handler3" (+00000000h)
Address: 00E98DDDh, location: "foo_history", loaded at 00E90000h - 00EA0000h
Address: 00E986C5h, location: "foo_history", loaded at 00E90000h - 00EA0000h
Address: 00E9875Ah, location: "foo_history", loaded at 00E90000h - 00EA0000h
Address: 7C9011A7h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "LdrInitializeThunk" (+00000029h)
Address: 7C923F31h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "LdrShutdownProcess" (+00000142h)
Address: 00E986E5h, location: "foo_history", loaded at 00E90000h - 00EA0000h
Address: 7C90E88Eh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "ZwTerminateProcess" (+00000000h)
Address: 7C910945h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAcquirePebLock" (+00000028h)
Address: 7C91094Eh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAcquirePebLock" (+00000031h)
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+00000117h)
Address: 7C923E98h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "LdrShutdownProcess" (+000000A9h)
Address: 7C81CA3Eh, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "IsValidLocale" (+000008EBh)
Address: 77C3B16Ch, location: "msvcrt", loaded at 77C10000h - 77C68000h
Symbol: "lock" (+00000BB1h)
Address: 77D4882Ah, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+00000163h)
Address: 77D70467h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DeregisterShellHookWindow" (+000001CFh)
Address: 77D4C63Fh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "IsWindowUnicode" (+000000A1h)
Address: 7C90F0AAh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAnsiStringToUnicodeString" (+0000005Eh)
Address: 7C8399F3h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "FindAtomW" (+00000094h)
Address: 7C81CA78h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "IsValidLocale" (+00000925h)
Address: 7C81CAB6h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "ExitProcess" (+00000014h)
Address: 77E8F3B0h, location: "RPCRT4", loaded at 77E70000h - 77F01000h
Symbol: "UuidCreateSequential" (+000007E8h)
Address: 77C39D45h, location: "msvcrt", loaded at 77C10000h - 77C68000h
Symbol: "strerror" (+00002B4Bh)
Address: 77C39E78h, location: "msvcrt", loaded at 77C10000h - 77C68000h
Symbol: "initterm" (+00000111h)
Address: 77C39EACh, location: "msvcrt", loaded at 77C10000h - 77C68000h
Symbol: "exit" (+00000012h)
Address: 77C1F159h, location: "msvcrt", loaded at 77C10000h - 77C68000h
Symbol: "amsg_exit" (+00000034h)
Address: 77C35F14h, location: "msvcrt", loaded at 77C10000h - 77C68000h
Symbol: "purecall" (+00000007h)
Address: 0041BA74h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00445468h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 0041BA41h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 7C917BB8h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+000001BBh)
Address: 0041D19Fh, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00445924h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00435D4Dh, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 004458F4h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 004225C1h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 004458F8h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 004218B7h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00413394h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 0042183Bh, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 0043A1C8h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 0043A1B4h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00426FE2h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 004277B4h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 0043B508h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 004465ACh, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 0176261Ah, location: "foo_ui_columns", loaded at 01750000h - 01787000h
Address: 004465DCh, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 0176158Eh, location: "foo_ui_columns", loaded at 01750000h - 01787000h
Address: 7C90EAD0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "KiUserCallbackDispatcher" (+00000000h)
Address: 7740EF05h, location: "COMCTL32", loaded at 773D0000h - 774D2000h
Symbol: "Ordinal384" (+000230DBh)
Version info:
foobar2000 v0.8.3
UNICODE
failure_00000001.txt
Created Dec. 27, 2005 (my birthday)
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 004212F5h
Access violation, operation: read, address: 00000001h
Call path:
WinMain=>app_mainloop=>playlist_switcher_saveconfig
Code bytes (004212F5h):
004212B5h:  FF 15 18 90 43 00 8B 3D 1C 59 44 00 FF 05 10 59
004212C5h:  44 00 C1 EF 03 C7 45 FC 00 00 00 00 74 3D 53 8B
004212D5h:  5D 08 56 8B 4D 0C FF 75 FC 8B 01 FF 10 84 C0 74
004212E5h:  20 A1 14 59 44 00 8B 4D FC 8B 34 C8 8B CE 8B 06
004212F5h:  FF 10 8B 03 8B CB FF 10 8B 13 50 56 8B CB FF 52
00421305h:  10 FF 45 FC 39 7D FC 72 CA 5E 5B 8D 4D F8 E8 0C
00421315h:  4D FE FF 5F C9 C2 08 00 55 8B EC 51 B8 F8 58 44
00421325h:  00 56 50 89 45 FC FF 15 18 90 43 00 A1 1C 59 44
Stack (0013FB2Ch):
0013FB0Ch:  00D3DB9C 7C9C93A0 77F643DD 7C9C93A0
0013FB1Ch:  00000004 00000000 00D3D0A8 00000000
0013FB2Ch:  01B01FB0 00000000 004458F4 004458F8
0013FB3Ch:  00000000 0013FB60 00427292 01B01FC4
0013FB4Ch:  0013FB5C 0013FC14 0040465C 00000000
0013FB5Ch:  004394C4 0013FB84 004271A9 01B98C40
0013FB6Ch:  0043946C 01B98C40 0000002D 0000002D
0013FB7Ch:  00000000 00000015 0013FBAC 00404721
0013FB8Ch:  00000000 0040465C 00000000 00000000
0013FB9Ch:  0013FBB8 773E1AEB 773F8B56 001E01F0
0013FBACh:  0013FBD8 77D48734 00950168 00000111
0013FBBCh:  00000004 00A50248 0040465C DCBAABCD
0013FBCCh:  00000000 0013FC14 0040465C 0013FC44
0013FBDCh:  77D5418D 0040465C 00950168 00000111
0013FBECh:  00000004 00A50248 00000111 00950168
0013FBFCh:  0064F900 00000014 00000001 00000000
0013FC0Ch:  00000000 00000010 00000000 00000014
0013FC1Ch:  00000000 00000000 00000000 00000000
0013FC2Ch:  0013FBF4 0013F750 0013FE2C 77D70467
0013FC3Ch:  77D541B0 00000000 0013FC8C 77D53FD9
Registers:
EAX: 00000001, EBX: 01B01FC4, ECX: 01C82A44, EDX: 004458F8
ESI: 01C82A44, EDI: 0000002A, EBP: 0013FB40, ESP: 0013FB2C
Crash location: "foobar2000", loaded at 00400000h - 00452000h
Loaded modules:
foo_uie_albumlist                loaded at 01730000h - 01742000h
foo_uie_tabs                    loaded at 01750000h - 0175A000h
foo_uie_trackinfo                loaded at 01760000h - 0176B000h
foo_ui_columns                  loaded at 01770000h - 017A7000h
foo_ui_std                      loaded at 017B0000h - 017C7000h
foo_unpack                      loaded at 017D0000h - 01801000h
foo_utils                        loaded at 01810000h - 01821000h
foo_vis_manager                  loaded at 01830000h - 01838000h
foo_vis_simple_spectrum          loaded at 01840000h - 0184A000h
foo_vorbisenc                    loaded at 01850000h - 01961000h
foo_wavpack                      loaded at 01970000h - 01982000h
foo_winamp_spam                  loaded at 01990000h - 01998000h
foo_wma                          loaded at 019A0000h - 019BA000h
foo_xa                          loaded at 019C0000h - 019CF000h
Address: 00427292h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 0040465Ch, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 004394C4h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 004271A9h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 0043946Ch, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00404721h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 773E1AEBh, location: "COMCTL32", loaded at 773D0000h - 774D2000h
Symbol: "Ordinal11" (+00000328h)
Address: 773F8B56h, location: "COMCTL32", loaded at 773D0000h - 774D2000h
Symbol: "Ordinal384" (+0000CD2Ch)
Address: 77D48734h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+0000006Dh)
Address: 00A50248h, location: "foo_bitcompare", loaded at 00A50000h - 00A59000h
Address: 77D5418Dh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PrivateExtractIconExW" (+000002B2h)
Address: 77D541B0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PrivateExtractIconExW" (+000002D5h)
Address: 77D53FD9h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PrivateExtractIconExW" (+000000FEh)
Address: 77D4B4CBh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+0000018Fh)
Address: 77D5CB2Bh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "RegisterLogonProcess" (+00000528h)
Address: 77D4B903h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SendMessageW" (+00000049h)
Address: 773F6FF6h, location: "COMCTL32", loaded at 773D0000h - 774D2000h
Symbol: "Ordinal384" (+0000B1CCh)
Address: 773F70D8h, location: "COMCTL32", loaded at 773D0000h - 774D2000h
Symbol: "Ordinal384" (+0000B2AEh)
Address: 773F93DDh, location: "COMCTL32", loaded at 773D0000h - 774D2000h
Symbol: "Ordinal384" (+0000D5B3h)
Address: 01832191h, location: "foo_vis_manager", loaded at 01830000h - 01838000h
Address: 018351E4h, location: "foo_vis_manager", loaded at 01830000h - 01838000h
Address: 01834170h, location: "foo_vis_manager", loaded at 01830000h - 01838000h
Address: 018323ACh, location: "foo_vis_manager", loaded at 01830000h - 01838000h
Address: 018341BCh, location: "foo_vis_manager", loaded at 01830000h - 01838000h
Address: 018317D2h, location: "foo_vis_manager", loaded at 01830000h - 01838000h
Address: 0183522Ch, location: "foo_vis_manager", loaded at 01830000h - 01838000h
Address: 77D48816h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+0000014Fh)
Address: 77D48830h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+00000169h)
Address: 77D489CDh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+00000127h)
Address: 77D61B4Dh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "AppendMenuA" (+0000006Eh)
Address: 77D489F0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+0000014Ah)
Address: 77D48A10h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DispatchMessageW" (+0000000Fh)
Address: 77D5E097h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "IsDialogMessageW" (+000000DBh)
Address: 100036BCh, location: "utf8api", loaded at 10000000h - 1000D000h
Symbol: "uIsDialogMessage" (+0000000Eh)
Address: 0041236Ch, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00410FEAh, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00438DB5h, location: "foobar2000", loaded at 00400000h - 00452000h
Version info:
foobar2000 v0.8.3
UNICODE
failure_00000002.txt
Created Jan 14, 2006
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 01DC29B1h
Access violation, operation: write, address: 007FFFF8h
Call path:
Code bytes (01DC29B1h):
01DC2971h:  CB 8B F0 46 8D 04 76 C1 E0 02 50 E8 9F 06 00 00
01DC2981h:  8B 54 24 1C 8D 46 FF 3B C2 76 19 8D 0C 40 C1 E1
01DC2991h:  02 2B C2 8B 33 8D 3C 31 83 E9 0C 48 8D 77 F4 A5
01DC29A1h:  A5 A5 75 EF 8B 0B 8D 04 52 8D 74 24 10 8D 3C 81
01DC29B1h:  A5 A5 A5 5F 5E 5B C2 10 00 8B 01 50 FF 48 18 FF
01DC29C1h:  15 08 40 DC 01 C3 8B 44 24 04 85 C0 7D 05 8A 41
01DC29D1h:  0C EB 17 3B 41 08 7D 0F 8B 49 04 33 D2 38 14 08
01DC29E1h:  0F 95 C2 8A C2 EB 03 8A 41 0D C2 04 00 8B 51 08
Stack (0013FD60h):
0013FD40h:  00C5DB9C 7C9C93A0 77F643DD 7C9C93A0
0013FD50h:  00000004 00000000 00C5D0A8 00000000
0013FD60h:  0013FD7C 0013FD98 023351B0 01DC19E9
0013FD70h:  023351B0 0861D650 00420701 000AAAAA
0013FD80h:  01DC522C 00000002 00000000 023351B0
0013FD90h:  0861D650 00420701 0861D680 000848C5
0013FDA0h:  00000001 000261E3 010D6454 0013FDD4
0013FDB0h:  01DC16B0 CF0D6454 40B261BB 0013FE3C
0013FDC0h:  01DC15CE CF0D6454 40B261BB 00000001
0013FDD0h:  0013FE84 0013FE00 77D48734 00050334
0013FDE0h:  00000113 0000029A 00000000 01DC15CE
0013FDF0h:  DCBAABCD 00000000 0013FE3C 01DC15CE
0013FE00h:  0013FE68 77D48816 01DC15CE 00050334
0013FE10h:  00000113 0000029A 00000000 0013FF00
0013FE20h:  0013FEF8 00687830 00000014 00000001
0013FE30h:  00000000 00000000 00000010 00000000
0013FE40h:  77D4EAAD 00000000 00000000 00000000
0013FE50h:  0013FE1C 0013F984 0013FEB8 77D70467
0013FE60h:  77D48830 00000000 0013FEC8 77D489CD
0013FE70h:  00000000 01DC15CE 00050334 00000113
Registers:
EAX: 001FFFFE, EBX: 01DC519C, ECX: 00000000, EDX: 000AAAAA
ESI: 0013FD70, EDI: 007FFFF8, EBP: 0013FDAC, ESP: 0013FD60
Crash location: "foo_vis_manager", loaded at 01DC0000h - 01DC8000h
Loaded modules:
foo_output_asio(dll)            loaded at 003A0000h - 003C0000h
foo_abx                          loaded at 003D0000h - 003DC000h
foo_ac3                          loaded at 003E0000h - 003F3000h
foo_albumlist                    loaded at 00AC0000h - 00ACB000h
foo_ape                          loaded at 00AD0000h - 00AEF000h
foo_apl                          loaded at 00AF0000h - 00AFA000h
foo_bitcompare                  loaded at 00B00000h - 00B09000h
foo_burninate                    loaded at 00B10000h - 00B1C000h
foo_cdda                        loaded at 00B20000h - 00B2E000h
foo_clienc                      loaded at 00B30000h - 00B3B000h
foo_console                      loaded at 00B40000h - 00B47000h
foo_convolve                    loaded at 00B50000h - 00B9F000h
foo_dbsearch                    loaded at 00BA0000h - 00BB8000h
foo_diskwriter                  loaded at 00BC0000h - 00BD2000h
foo_dsp_crossfade                loaded at 00BE0000h - 00BE7000h
foo_dsp_crossfeed                loaded at 00BF0000h - 00BF6000h
foo_dsp_extra                    loaded at 00C00000h - 00C15000h
foo_dsp_nogaps                  loaded at 00C20000h - 00C27000h
foo_dsp_pause                    loaded at 00C30000h - 00C37000h
foo_dsp_skip_silence            loaded at 00C40000h - 00C47000h
foo_dsp_soundtouch              loaded at 00C50000h - 00C5B000h
foo_dynamics                    loaded at 00C60000h - 00C67000h
foo_faac                        loaded at 00C70000h - 00CA3000h
foo_festalon                    loaded at 00CB0000h - 00DEE000h
foo_flac                        loaded at 00DF0000h - 00E0C000h
foo_flaccer                      loaded at 00E10000h - 00E26000h
foo_freedb                      loaded at 00E30000h - 00E5E000h
foo_gym                          loaded at 00E60000h - 00EBE000h
foo_history                      loaded at 00EC0000h - 00ED0000h
foo_id3v2                        loaded at 00ED0000h - 00F00000h
foo_infobox                      loaded at 00F00000h - 00F13000h
foo_input_std                    loaded at 00F20000h - 00FBE000h
foo_lpac                        loaded at 00FC0000h - 00FC7000h
lpac_codec_api                  loaded at 00FD0000h - 00FDA000h
lpaccodec                        loaded at 00FE0000h - 01009000h
foo_masstag                      loaded at 01230000h - 01244000h
foo_matroska                    loaded at 01250000h - 01298000h
foo_mod                          loaded at 012A0000h - 012A9000h
BASS                            loaded at 012B0000h - 0130A000h
foo_monkey                      loaded at 01310000h - 0132C000h
foo_mpeg4u                      loaded at 01330000h - 01359000h
foo_nez                          loaded at 01360000h - 0138B000h
foo_null                        loaded at 01390000h - 01397000h
foo_ofr                          loaded at 013A0000h - 013A6000h
OptimFROG                        loaded at 013B0000h - 013DC000h
foo_oggpreview                  loaded at 013F0000h - 014F1000h
foo_output_std                  loaded at 01500000h - 01509000h
foo_out_dsound_ex                loaded at 01510000h - 01519000h
foo_out_ks                      loaded at 01530000h - 0153B000h
foo_playlistgen_ex              loaded at 01540000h - 0154F000h
foo_pphsresample                loaded at 01550000h - 01560000h
foo_psf                          loaded at 01560000h - 0160C000h
foo_read_http                    loaded at 01610000h - 01619000h
foo_rgscan                      loaded at 01620000h - 0162D000h
foo_scroll                      loaded at 01630000h - 01636000h
foo_search_ex                    loaded at 01640000h - 01648000h
foo_shn                          loaded at 01650000h - 0165F000h
foo_sid                          loaded at 01660000h - 016A7000h
foo_spc                          loaded at 016B0000h - 016C1000h
foo_speex                        loaded at 016E0000h - 016F8000h
foo_tfmx                        loaded at 01700000h - 01709000h
foo_tta                          loaded at 01710000h - 01719000h
foo_tta_old                      loaded at 01720000h - 01729000h
foo_uie_albumart                loaded at 01730000h - 0173C000h
foo_uie_albumlist                loaded at 01760000h - 01772000h
foo_uie_tabs                    loaded at 01780000h - 0178A000h
foo_uie_trackinfo                loaded at 01790000h - 0179B000h
foo_uie_vis_projectm            loaded at 017A0000h - 017E0000h
OPENGL32                        loaded at 5ED00000h - 5EDCC000h
GLU32                            loaded at 68B20000h - 68B40000h
DDRAW                            loaded at 73760000h - 737A9000h
DCIMAN32                        loaded at 73BC0000h - 73BC6000h
foo_ui_columns                  loaded at 01CE0000h - 01D17000h
foo_ui_std                      loaded at 01D20000h - 01D37000h
foo_unpack                      loaded at 01D40000h - 01D71000h
foo_utils                        loaded at 01D80000h - 01D91000h
foo_vis_bacon                    loaded at 01DA0000h - 01DB7000h
foo_vis_manager                  loaded at 01DC0000h - 01DC8000h
foo_vis_simple_spectrum          loaded at 01DD0000h - 01DDA000h
foo_vorbisenc                    loaded at 01DE0000h - 01EF1000h
foo_wavpack                      loaded at 01F00000h - 01F12000h
foo_winamp_spam                  loaded at 01F20000h - 01F28000h
foo_wma                          loaded at 01F30000h - 01F4A000h
foo_xa                          loaded at 01F50000h - 01F5F000h
foo_xlobby                      loaded at 01F60000h - 01F67000h
ASOEHOOK                        loaded at 651B0000h - 651D2000h
ccL40                            loaded at 6AF90000h - 6AFEE000h
MSVCP71                          loaded at 7C3A0000h - 7C41B000h
nview                            loaded at 02070000h - 021DF000h
PSAPI                            loaded at 76BF0000h - 76BFB000h
NTMARTA                          loaded at 77690000h - 776B1000h
SAMLIB                          loaded at 71BF0000h - 71C03000h
LgWndHk                          loaded at 022A0000h - 022A7000h
nvoglnt                          loaded at 69500000h - 69A37000h
LgMsgHk                          loaded at 035A0000h - 035AB000h
asio4all                        loaded at 03D30000h - 03E4D000h
KSUSER                          loaded at 73EE0000h - 73EE4000h
nvwddi                          loaded at 048D0000h - 048E5000h
DBGHELP                          loaded at 0FF40000h - 0FFE1000h
Address: 01DC19E9h, location: "foo_vis_manager", loaded at 01DC0000h - 01DC8000h
Address: 00420701h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 01DC522Ch, location: "foo_vis_manager", loaded at 01DC0000h - 01DC8000h
Address: 01DC16B0h, location: "foo_vis_manager", loaded at 01DC0000h - 01DC8000h
Address: 01DC15CEh, location: "foo_vis_manager", loaded at 01DC0000h - 01DC8000h
Address: 77D4EAADh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "EnableMenuItem" (+0000007Eh)
Address: 100038ECh, location: "utf8api", loaded at 10000000h - 1000D000h
Symbol: "uDispatchMessage" (+0000000Ah)
Address: 0041238Bh, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 00438DE0h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 0043C320h, location: "foobar2000", loaded at 00400000h - 00452000h
Address: 7C816D4Fh, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "RegisterWaitForInputIdle" (+00000049h)
Address: 7C816D58h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "RegisterWaitForInputIdle" (+00000052h)
Address: 00438C81h, location: "foobar2000", loaded at 00400000h - 00452000h
Version info:
foobar2000 v0.8.3
UNICODE
These are the presets I'm using:
Aderrasi - Agitator.milk
Aderrasi - Aimless (Gravity Directive Mix).milk
Aderrasi - Aimless (Spirogravity Mix).milk
Aderrasi - Airhandler (Menagerie Mix).milk
Aderrasi - Airs (Windy Mix).milk
Aderrasi - Airs.milk
Aderrasi - Anchorpulse (Pulse Of A Ghast II Mix).milk
Aderrasi - Anchorpulse (Verified Mix).milk
Aderrasi - Anomalous Material Science (Pure Splinter Mix).milk
Aderrasi - Antidote (Aqualung Mix).milk
Aderrasi - Antidote (Side Effects Mix).milk
Aderrasi - Antidote.milk
Aderrasi - Antique Abyss.milk
Aderrasi - Arise! (Padded Mix).milk
Aderrasi - Ashes Of Air (Remix).milk
Aderrasi - Bitterfeld (Crystal Border Mix).milk
Aderrasi - Blender.milk
Aderrasi - Bow To Gravity.milk
Aderrasi - Brakefreak.milk
Aderrasi - Candy Avian.milk
Aderrasi - Causeway Of Dreams (Nightmare Mix).milk
Aderrasi - Causeway Of Dreams (REMix).milk
Aderrasi - Causeway Of Dreams.milk
Aderrasi - Chromatic Abyss (The Other Side).milk
Aderrasi - Circlefacade.milk
Aderrasi - Contortion (Xenomorph Mix).milk
Aderrasi - Contortion.milk
Aderrasi - Crystal Storm.milk
Aderrasi - Dark Matter (Converse Mix).milk
Aderrasi - Elastoid.milk
Aderrasi - Floater Society.milk
Aderrasi - Flowing Form.milk
Aderrasi - Making Time (Swamp Mix).milk
Aderrasi - Multiviola.milk
Aderrasi - Negative Sun III.milk
Aderrasi - Paintsphere.milk
Aderrasi - What Cannot Be Undone.milk
Aderrasi - What cannot be.milk
Bmelgren & Krash - Rainbow Orb Peacock (Centred Journey Mix.milk
Bmelgren & Krash - Rainbow Orb Peacock (Lonely Signal Gone .milk
bmelgren - Godhead.milk
Bmelgren - Pentultimate Nerual Slipstream (Tweak 2).milk
bmelgren - Take this highway.milk
Che - Terracarbon Stream.milk
CrystalHigh - mad ravetriping.milk
EvilJim - Follow the ball.milk
EvilJim - Ice Drops.milk
Fvese - 0 To 60.milk
Fvese - simple.milk
Fvese - Window Reflection 6.milk
Geiss & Rovastar - Notions Of Tonality 2.milk
Geiss & Rovastar - Tokamak (Naked Intrusion Mix).milk
Geiss - Blasto.milk
Geiss - Cosmic Dust 2.milk
Geiss - Cruzin'.milk
Geiss - Downward Spiral.milk
Geiss - Dynamic Swirls 1.milk
Geiss - Dynamic Swirls 2.milk
Geiss - Eddies 2.milk
Geiss - Eggs.milk
Geiss - El Cubismo.milk
Geiss - Nautilus.milk
Geiss - Octopus Ever Changing.milk
Geiss - Octopus Gold.milk
Geiss - Octopus.milk
Geiss - Oldskool Mellowstyle.milk
Geiss - Swirlie 1.milk
Geiss - Swirlie 2.milk
Geiss - Swirlie 3.milk
Geiss - Swirlie 4.milk
Geiss - Swirlie 5.milk
Idiot & Rovastar - Altars Of Madness 2 (X.42 Mix).milk
Idiot & Zylot - Unhealthy Love (Idiot's STDs Mix).milk
Idiot - MOTIVATION!.milk
Idiot - Texture Boxes (Remix 2).milk
Idiot - Texture Boxes (Remix).milk
Idiot24-7 - Ascending to heaven 2.milk
Illusion & Che - Return Of The King.milk
Illusion & Che - The Piper.milk
Illusion & Rovastar - Clouded Bottle.milk
Illusion & Unchained - Invade My Mind.milk
Illusion - Figure Eight.milk
Krash & Illusion - Spiral Movement.milk
Krash & Rovastar - Altars of Madness (Mad Ocean Mix).milk
Krash & TEcHNO - Rhythmic Mantas.milk
Krash - 3D Shapes Demo 2.milk
Krash - 3D Shapes Demo.milk
Krash - Digital Flame.milk
Krash - Dynamic Borders 1.milk
Krash - Framed Geometry.milk
Krash - Interwoven (Nightmare Weft Mix).milk
Krash - War Machine (Shifting Complexity Mix).milk
Krash - Windowframe To Mega Swirl 2.milk
Krash and Rovastar - Rainbow Orb 2 Peacock (Bmelgren's Comp.milk
Krash and Rovastar - Rainbow Orb.milk
Mstress & Darius - Pursuing The Sunset.milk
Mstress & Juppy - Dancer.milk
Mstress & Juppy - Dancers In The Dark.milk
Mstress - Acid Universes (Big Bang Interferences Mix).milk
Mstress - Acoustic Nerve Impulses (Under Drug Effetcs (Hypn.milk
Mstress - Aurora Boreale.milk
Mstress - Curtain.milk
Reenen - phoenix.milk
Rovastar & Aderrasi - Clockwork Organism.milk
Rovastar & Fvese - Deadly Flower.milk
Rovastar & Fvese - Stranger Minds (Astral Mix).milk
Rovastar & Fvese - Stranger Minds.milk
Rovastar & Geiss - Dynamic Swirls 3 (Broken Destiny Mix).milk
Rovastar & Geiss - Dynamic Swirls 3 (Mysticial Awakening Mi.milk
Rovastar & Geiss - Dynamic Swirls 3 (Poltergiest Mix).milk
Rovastar & Geiss - Dynamic Swirls 3 (Twisted Truth Mix).milk
Rovastar & Geiss - Hurricane Nightmare.milk
Rovastar & Geiss - Ice Planet.milk
Rovastar & Geiss - Notions Of Tonality.milk
Rovastar & Geiss - Octoplasm.milk
Rovastar & Geiss - Octotrip (MultiTrip Mix).milk
Rovastar & Geiss - Octotrip.milk
Rovastar & Geiss - Surface (Vectrip Mix).milk
Rovastar & Idiot24-7 - Balk Acid.milk
Rovastar & Krash - Flowing Synergy.milk
Rovastar & Krash - Interwoven (Contra Mix).milk
Rovastar & Rocke - Headspin.milk
Rovastar & Rocke - Sugar Spun Sister.milk
Rovastar & StudioMusic - More Cherished Desires.milk
Rovastar & StudioMusic - Twisted Spider Web.milk
Rovastar & Telek - Cosmic Fireworks.milk
Rovastar & Unchained - Centre Of Gravity.milk
Rovastar & Zylot - Crystal Ball (Cerimonial Decor).milk
Rovastar & Zylot - Narell's Fever.milk
Rovastar & Zylot - Sea Of Zigrot.milk
Rovastar - A Million Miles from Earth (Pathfinder Mix).milk
Rovastar - A Million Miles from Earth.milk
Rovastar - Altars Of Harlequin's Madness (Dark Disorder Mix.milk
Rovastar - Altars Of Madness (A Million Miles From Earth Mi.milk
Rovastar - Altars Of Madness (Duel Mix).milk
Rovastar - Altars Of Madness (Surealist Mix).milk
Rovastar - Altars Of Madness.milk
Rovastar - Bellanova (New Wave Mix).milk
Rovastar - Biohazard Warning.milk
Rovastar - Chapel Of Ghouls.milk
Rovastar - Cosmic Echoes 1.milk
Rovastar - Cosmic Echoes 2.milk
Rovastar - Cosmic Mosaic (Active Mix).milk
Rovastar - Decreasing Dreams (Extended Movement Mix).milk
Rovastar - Explosive Minds.milk
Rovastar - Forgotten Moon.milk
Rovastar - Frozen Rapture .milk
Rovastar - Future Speakers.milk
Rovastar - Hallucinogenic Pyramids (Beat Time Mix).milk
Rovastar - Harlequin's Dynamic Fractal (Crazed Spiral Mix).milk
Rovastar - Harlequin's Fractal Encounter.milk
Rovastar - Hyperspace (Frozen Rapture Mix).milk
Rovastar - Hyperspace.milk
Rovastar - Inner Thoughts (Clouded Judgement Mix).milk
Rovastar - Inner Thoughts (Dark Secret Mix).milk
Rovastar - Inner Thoughts (Distant Memories Mix).milk
Rovastar - Inner Thoughts (Frantic Thoughts Mix).milk
Rovastar - Inner Thoughts (Strange Cargo Mix).milk
Rovastar - Kalideostars (Altars Of Madness MIx).milk
Rovastar - Kalideostars (Round  Round Mix).milk
Rovastar - Kalideostars.milk
Rovastar - Magic Carpet.milk
Rovastar - Multiverse Starfield 1.milk
Rovastar - Multiverse Starfield 3.milk
Rovastar - Omnipresence Resurrection.milk
Rovastar - Pandora's Volcano.milk
Rovastar - Parallel Universe.milk
Rovastar - Sea Shells.milk
Rovastar - Solarized Space (Space DNA Mix).milk
Rovastar - Solarized Space.milk
Rovastar - Space (Twisted Dimension Mix).milk
Rovastar - Space.milk
Rovastar - The Awakening.milk
Rovastar - The Chaos Of Colours (Drifting Mix).milk
Rovastar - The Chaos Of Colours.milk
Rovastar - The Shroomery.milk
Rovastar and Krash - Hallucinogenic Pyramids (Extra Beat Ti.milk
Rovastar and Unchained - Braindance Visions.milk
Rozzer & Neuro - Starover (Semicolon Mix).milk
Rozzer & Zylot - Force Field Generator (Slowtime Tweak).milk
Rozzor & Aderrasi - Canon.milk
Rozzor & Che - Inside The House Of Nil.milk
Rozzor & Rovastar - Oozing Resistance (Waveform Mod).milk
Rozzor & Zylot - Rainbow River.milk
StudioMusic & Unchained - Entity.milk
StudioMusic & Unchained - Minor Alteration.milk
StudioMusic & Unchained - State Of Discretion.milk
StudioMusic & Unchained - Wrenched Fate.milk
StudioMusic - It's Only Make Believe.milk
StudioMusic - Numerosity.milk
Telek - Flicker.milk
Unchained & Illusion - Logic Morph.milk
Unchained & Rovastar - For The Seagull.milk
Unchained & Rovastar - Slow Solstice.milk
Unchained & Rovastar - Triptionary.milk
Unchained & Rovastar - Wormhole Pillars (Hall of Shadows mi.milk
Unchained & Rovastar - Wormhole Pillars.milk
Unchained & Rovastar - Xen Traffic.milk
Unchained - Beat Demo 1.0.milk
Unchained - Beat Demo 2.0.milk
Unchained - Beat Demo 2.1.milk
Unchained - Beat Demo 2.2.milk
Unchained - Beat Demo 2.3.milk
Unchained - Cartoon Factory.milk
Unchained - Cranked On Failure.milk
Unchained - Goo Kung Fu.milk
Unchained - In Memory Of Peg.milk
Unchained - Jaded Emotion.milk
Unchained - Perverted Dialect.milk
Unchained - ReAwoke.milk
Unchained - Ribald Ballad.milk
Unchained - Shaping The Grid.milk
Unchained - Subjective Experience Of The Manifold.milk
Unchained - Working the Grid.milk
Zylot - Azirphaeli's Mirror.milk
Zylot - Block Of Sound (Abstract Architecture Mix).milk
Zylot - Crystal Ball (Magical Reaction Mix).milk
Zylot - Digiscape Advanced Processor.milk
Zylot - Ether Storm.milk
Zylot - Inside The Planar Portal.milk
Zylot - light of the path.milk
Zylot - Magma Crawl.milk
Zylot - Magma Vein.milk
Zylot - PinWheel.milk
Zylot - String.milk
Zylot - Tangent Universe (Collapsed With Artifact Mix).milk
Zylot - The Inner Workings of my New Computer.milk
Zylot - Visionarie.milk
I'm not sure which of these came with it. You can copy the list to a text file (text.txt in my example) and put it in your presets folder and in CMD window focused on your presets folder, type:
for /f "delims=" %a in (text.txt) do if not exist "%a" c: > "%a.tmp"
and all the 0-byte files with a .tmp at the end in your presets folder are ones that are in my presets folder and not in your's. I hope that helps.
foo_vis_projectM
Reply #154
Hmm, it doesn't look like you have any presets that I don't.  Also, though I won't deny that foo_uie_vis_projectM may have been involved in at least the second and third crashes, they didn't happen inside the foo_uie_vis_projectM DLL, so I can't see what's causing the crash from those.  I guess I'll just have to leave projectM running for a long time and see if I can get it to blow up.
foo_vis_projectM
Reply #155
And perhaps it's just my computer. I was having some issues using ASIO that I believe were responsible for some lock-ups and have since switched to wave out, but this issue has happened after switching.
I included the information about other media players going extremely slow after this happens so it might give some insight into exactly how it is affecting the computer (or video card). I wish I could be of more help but I know nothing of how to make something like this or how to troubleshoot it. That CMD command is something I came up with for this issue and I used to make units for Total Annihilation, but that's probably pretty basic stuff. However, if there's anything I can do let me know.
foo_vis_projectM
Reply #156
To be honest, I really don't know what the problem could be.  If it's making video players break, I'd guess that it's leaking something graphics-related or fouling up some driver internally, but that's really just a guess.  I had it running in the debugger for a couple hours earlier today without seeing a crash...  I'll try it again with a release build over the next few days and see if I can get anything to happen.
foo_vis_projectM
Reply #157
I've had it on since I last posted and still no crashes. It probably has something to do with me viewing something online or playing a game and the way it uses the video card doesn't go well with how your plugin uses it afterward. I haven't been able to recreate it since I first posted about it.
foo_vis_projectM
Reply #158
I have experienced an odd problem using this.  My mouse scroll buttons stopped working when using this vis.  I have a logitech MX 510.
Put the vis into components, buttons stop working, remove the vis, scrolling buttons work ??
foo_vis_projectM
Reply #159
[a href="index.php?act=findpost&pid=369041"][{POST_SNAPBACK}][/a]
So you're saying that if foo_vis_projectm.dll (or foo_uie_vis_projectm.dll) is in your components folder, your scroll buttons don't work?  Hmm... *goes back through thread* 2xG posted something similar a while back, saying that foo_uie_vis_projectm would break mouse acceleration whenever foobar2000 was in focus.  I still don't know how this is happening, but I'll give the code another going-through and see if I'm missing something severe.
Are you using foo_vis_projectm or foo_uie_vis_projectm?
[EDIT]:  Are using Logitech's MouseWare/SetPoint software?  I wonder if they could get confused when it sees projectM using OpenGL and reconfigure the mouse for gaming mode...
foo_vis_projectM
Reply #160
Thanks for having a look.
I am using foo_uie_vis_projectm.dll.  When I put this in my components folder the mouse scrolling buttons do not work.  When I remove the dll out of the foobar folder the mouse buttons function as normal.
Yes, I am using the mouseware software.
If you require any more info to help track down this issue please let me know.
cheers and thanks!
foo_vis_projectM
Reply #161
I can't be completely sure about this because I'm visiting my family at the moment and hence don't have access to a compiler or a debugger, but I don't see anything special in the code that would get executed when the dll is loaded.  I also can't think of anything I'm doing with the mouse that could disable the scroll buttons.  I'll run foo_uie_vis_projectm through a debugger when I get back on Tuesday to see if I'm missing anything, but in the meantime, I'd suggest taking a look at your MouseWare settings.  It's possible that projectM is being detected as an OpenGL "game" and that MouseWare is doing something to the scroll wheel as a result.  If there were a spare computer around here, I could probably put MouseWare on it and test it myself, but none of the computers here are mine, so I don't think I'll be able to do that...
foo_vis_projectM
Reply #162
[a href="index.php?act=findpost&pid=369479"][{POST_SNAPBACK}][/a]
I went through the software, I can't see anything about games or software specific settings.  The software is simply for setting the button action, speed etc.
foo_vis_projectM
Reply #163
I tried putting MouseWare on my computer and I can confirm that with, MouseWare running, opening foobar2000 with projectM installed will mess with the MouseWare acceleration/button settings.  If you're relying on MouseWare to set up your scrolling, then I can see that breaking things.  I found an "Advanced" MouseWare configuration utility on Logitech's site that allows you to change the way the game detection works.  Turning game detection off globally doesn't seem to work - if you turn it off, then close and reopen the advanced configuration thing, the game detection will be on again - but you can set it to not change the mouse acceleration or button assignments when a game is detected, which has the same effect as disabling the game detection.  When I check all of the boxes in the middle section, the mouse works the same in foobar2000/projectM as it does in Windows.  Let me know if this works for you.
Sorry if I sound like I'm trying to ignore the problem, but I've gone through the code a couple of times now and while I can't see anything that could be changing the mouse settings in foo_uie_vis_projectM, I do know that MouseWare can have an effect.
foo_vis_projectM
Reply #164
That worked,  thanks!  Awesome component btw.
foo_vis_projectM
Reply #165
I must be an ass for asking, but uhm. the sdk for 0.9 is out. Is there a change that projectm will be released for foobar 0.9?
would be great
Inter Deum et Diabolum semper Musica est", Tanzwut
foo_vis_projectM
Reply #166
would be great
[a href="index.php?act=findpost&pid=373284"][{POST_SNAPBACK}][/a]
THIS is the plugin I was looking for.
Yes, 0.9 version would be great. At least Columns UI panel.
foo_vis_projectM
Reply #167
would be great
Yes.  Eventually.  It may be a week or two from now.
foo_vis_projectM
Reply #168
would be great
Because I know many people are anxiously awaiting a .9 version, does anyone know the status as to when the port for projectm for .9 will be available?
foo_vis_projectM
Reply #169
A week or two from 21st March. So soon I suppose. Be patient.
foo_vis_projectM
Reply #170
Gonna be worse than that I'm afraid.  Maybe mid-to-late-April.  We'll see.
foo_vis_projectM
Reply #172
thanks G-lite
excellent works
and,
i'll waiting for pannel version
comming soon?
foo_vis_projectM
Reply #173
Panel version will have to wait. It looks like the current version is rather buggy for some people, slow for some people, and I might have to do a bit of code overhaul to get it working reliably and properly.
If this is working for you, consider yourself lucky.
foo_vis_projectM
Reply #174
So bleh isn't developing this anymore? Just asking...
EDIT: Works like charm! Thank you! Maybe I'm lucky
