High bitrate MP3 vs. Lossless ABX Tests?
Reply #17 –
Okay, fair enough - around here, the ACCEPTIBLE process is to ABX vs the original, since ABXing two different lossy codecs doesn't tell you much of anything, just which one sounds better to you (which could be the OPPOSITE of which one is closer to the source. Some people like the sound of certain codecs).
[a href="index.php?act=findpost&pid=302949"][{POST_SNAPBACK}][/a]
No this is not correct... ABX tells you *nothing* about your personal preference. It only tells you can hear a difference between the two files you are ABXing. While you can ABX two lossy files against one another, after doing this you can only show people that you can hear a difference between the two files, not which one you prefer.
[edit] removed some unclarities
