Topic: NoCover-Image (Read 240849 times) previous topic - next topic
NoCover-Image
Reply #75
I had created the image below after I rearranged my Foobar layout, in order to integrate the AlbumArt panel into the overall color theme, and for looks of course. Nothing complex here, just pure simplicity.
yours has the tied first place along with that leftist image
NoCover-Image
Reply #76
NoCover-Image
Reply #77
NoCover-Image
Reply #78
color scheming to fit with
NoCover-Image
Reply #81
thanks for reply
NoCover-Image
Reply #82
Here's mine:
foobar2000 + EAC + Burrrn = Happiness
NoCover-Image
Reply #83
whoa, did you make that?
NoCover-Image
Reply #84
I made this one to go with my color theme:
NoCover-Image
Reply #85
Here's what I use:
NoCover-Image
Reply #87
Got 2 different versions here, pick what you like. Took me a bit to do, but i think they turned out pretty good.
NoCover-Image
Reply #88
My Golden Apple
NoCover-Image
Reply #89
-$if($strcmp($left(%path%,7),http$char(58)$char(47)$char(47)),components\online-radio.*,components\no-cover.*)
Well I overhauled my interface and decided I wanted a new no-album pic. I came up with the above code as my no-cover art source which will display an alternate "Online Radio" image if the currently active source is a URL (online radio).
EDIT: Updated images and removed thumbnailing.
NoCover-Image
Reply #91
My image is based off the one from wikipedia.
I use png's alpha transparency to blend in, since I haven't decided on a final colour scheme yet.
You have to view it with a non-white background to actually see it, unfortunately.
NoCover-Image
Reply #93
My Radio Stream image
-foobar2000 + Burrrn + EAC
-HD 80Gb using High QualityVBR MP3s
NoCover-Image
Reply #95
Excuse the stupid question.. but is there a way to configure for a no-cover image to be displayed simply if no cover is found in the folder..? If not, what do you do? Don't tell me you go around all your music folders that don't contain an album cover image and place the no-cover image in there manually...
NoCover-Image
Reply #96
It usually is called default.png & should be located in your components directory. I believe the album art plugin is configured to look there automatically, if you store your image somewhere else you will need to change the path in the settings.
Cheers
NoCover-Image
Reply #97
Cheers
Ah crap.. we're talking about album art? I'm not even using album art yet . I'd like this to work with Pretty Popup!
Anybody wanna tell me where to put the image so it works with pretty popup? Thanks a lot.
NoCover-Image
Reply #98
In your prettypop album art filenames list, after your normal source(s), add the location of your no-cover image.  For instance, this is what I use:
['('%date%') ']%album%;|C:\Program Files\foobar2000\components\default
Make sure you don't forget the pipe "|", which tells pretty popup that you're giving the entire path to the image.
NoCover-Image
Reply #99
If you use the pipe, the plugin will by default search from your foobar directory so in the interest of keeping things simple and compatible with regions where windows uses a different name for your program files you can simplify things to just ";|components\default" if you want prettypop to use the same default no-cover image as albumart.
Also keep in mind that prettypop will automatically add the extensions for all supported image types to the search, so dont specify a file extension in your sources list.  If you want prettypop to display cover.* from the song's directory, and if that is not found display any image from the song's directory, and if that is not found display the same default no-cover image as albumart.. then your prettypop source line should look like this:
cover;*;|components\default
