Topic: NoCover-Image (Read 240787 times) previous topic - next topic
NoCover-Image
Reply #150
One of several to go with my new look - artist is Jason Brooks.
NoCover-Image
Reply #151
Heres my try, it looks good at all sizes....
I was also gonna try my hand at maybe editing the source to maybe downloading covers from amazon? or from a windows media player collection....not sure...
NoCover-Image
Reply #152
I'm using the following No Cover-Images:
  • Picture 1 is used for Audio CDs (Filename in Source List: audio_cd.jpg)
  • Picture 2 is used for empty playlists, when no track is playing (Filename in Source List: logo.jpg)
  • Picture 3 is used for tracks without a cover, which aren't in the media library (Filename in Source List: nocover.jpg)
  • Picture 4 is used for tracks without a cover, which are in the media library (Filename in Source List: nocover_library.jpg)
  • Picture 5 is used for streaming media (Filename in Source List: streaming.jpg)
The Source List looks like this:
$if(%path%,,images\albumart\logo.jpg)
$replace(%path%,%filename_ext%,)folder.*
-$replace(%path%,$directory(%path%,1)\%filename_ext%,)folder.*
-$replace(%path%,$directory(%path%,2)\$directory(%path%,1)\%filename_ext%,)folder.*
--$if($stricmp($left(%path%,7),'http://'),images\albumart\streaming.jpg,)
--$if($stricmp($left(%codec%,4),cdda),images\albumart\audio_cd.jpg,)
You've got to edit the last line, to match your folders in the library.
NoCover-Image
Reply #153
tango album art
400x400
500x500
NoCover-Image
Reply #154
Mine, a white label vynil
NoCover-Image
Reply #155
PROTIP:
use hello.jpg as the nocover image. great motivation to find those missing covers.
NoCover-Image
Reply #156
This may sound totally ignorant but how do I make one of these no cd art images display when there is no cover art?
NoCover-Image
Reply #157
NoCover-Image
Reply #158
mine, clickable:
[a href="http://img98.imageshack.us/my.php?image=nocovermd5.png" target="_blank"]
NoCover-Image
Reply #159
I use this:
If the song I have isn't on an album, I make my own cover art for them. I only use the above image if I know a cover exists, but I can't find it.
Song List: keikoniumboards.ke.funpic.org/files/songlist.html
NoCover-Image
Reply #160
Here's mine. Nice and simple. There are some really nice ones in this thread though! I'm definitely going to set up an radio stream one, I hadn't thought about doing that.
NoCover-Image
Reply #161
File > Preferences > Advanced > Display.
NoCover-Image
Reply #163
Would someone have the "no cover" picture iTunes 7 uses in CoverFlow mode ?
You can see a glimpse of it here (right of the picture) : http://birdhouse.org/blog/wp-content/uploa...09/flipview.png
I don't have the exact same cover, but I quickly made something similar in PS:
Alternative blue version I made to go with my Luna Element foobar config:
  http://img144.imageshack.us/img144/9158/nocoverblueil9.png
NoCover-Image
Reply #164
Thanks Dirhael, good work.
Two little comments to make it even better if possible :
- In the original Apple version, the notes aren't doubled with a shadow : it's just a part of CoverFlow's effect (the covers are translucent so you see the next cover, and even the following one if you look closely)
- In the original Apple version, there is a circular color gradient, from light (center) to dark (borders).
NoCover-Image
Reply #165
Something more in line with this? I took a look at iTunes, and the gradient doesn't actually start in the center but rather more to the top. There's also a whole lot of banding in the original Apple gradient, so I dropped some of the noise I added previously.
http://img262.imageshack.us/img262/8137/itunestv3.jpg
NoCover-Image
Reply #166
That's great !  Would you care to share the original PSD file so that I can play with it myself ? Thank you.
NoCover-Image
Reply #167
NoCover-Image is what I want, and more that I want is "filename support".
Now foobar2000 can only show images with file name "cover.*", but I want foobar2000 to show ones with "*cover.*" or "*.jpg" or "*.png".
I'm sorry for my poor written English.
Pacific Moon
NoCover-Image
Reply #168
I've always been fond of the default image Rhythmbox uses:
Though I have foobar set up with a black background so unfortunately it wouldn't fit in...
Would like to see it with a black background if possible though.
NoCover-Image
Reply #169
Well, if you can post the image here at a decent resolution, I'm sure it won't be a problem to make the background black or translucent.
EDIT : your image looks translucent already, so if you can find the file within your hard drive, it should work.
NoCover-Image
Reply #172
another png with transparent background - slightly different
edit - forgot compression on first try
NoCover-Image
Reply #174
I did mine with Illustrator. Put the blame on Adobe.
