foobar2000 v0.9 public beta
Reply #62 – 2005-05-23 14:45:54
2) In the new "Drive settings" for Audio CD; does "Offset correction" and "Secure mode" mean the same as in EAC? I guess it's limited how many times data are read while playback? Are "Secure mode" for ripping purposes? Does this mean foobar2000 are a full-fledged ripper too, now? And are "Offset correction" value entered as it are in EAC? Meaning; My drive, a PX-W4824A, has what Plextools name "Audio read offset" of -392 bytes. This is the same as -98 samples(-392:4), and are entered into EAC as an "Offset correction" of 98. (This is a bit important, as -98 and 98 are not quite the same... ) [a href="index.php?act=findpost&pid=299771"][{POST_SNAPBACK}][/a] Offset correction is same as "read sample offset correction" in EAC. In case of doubts do a bitcompare between foo_cdda output and EAC output. Secure mode rereads every 4MB block until it gets two results with identical CRC, so it's equivalent to burst mode test© because what you get has been read twice with identical resutls, except you don't have to watch CRC numbers unlike in EAC - if there is a problem, additional rereading is done behind your back. Secure mode should not be used for playback because it's too slow, I'll add special options for that later.bugs (Playback - Audio CD): seeking "Not here"Last track time... [a href="index.php?act=findpost&pid=299757"][{POST_SNAPBACK}][/a] On what disc ?
