Topic: foo_uie_explorer - like windows explorer (Read 347910 times) previous topic - next topic
Reply #275
I get a "Cannot delete file: Cannot read from the source file or disk." error when I try to delete a file within the explorer component. However, it does successfully delete populated folders.
Reply #276
just wanna give props to the dev, and also suggest a feature.
I would IMMENSELY appreciate if this plugin had a way to sort the files according to the creation date.
I still use a file manager when playing music because of this, i have an 'incoming' folder for music, and i do that to find the latest stuff and add them to the player...
There are a few workarounds in foobar but they involve the %lastmodified% tag and it surely isn't the same thing (gets messed up when rating, adding RG info etc...)
I bet a lot of ppl do like me and would love this feature too.
Hope you hear me out.
cheers and thanks again
Reply #277
If you still have time to develop this plugin, i have a request:
Would it be possible to make all actions (from 'Add to Default Playlist' to 'Unmark All Sibling') from the dropdown list in the Actions tab in the preferences available for the columns UI's customisable buttons ?
edit
I m having crashes when i try to hide all the drives (to display only the favorites) if the Select the last selected path option is chosen. It doesn't crash if Do nothing or Select the path i specified below are chosen instead
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 00D1AFE0h
Access violation, operation: read, address: 0000000Ch
Call path:
entry=>app_mainloop
Code bytes (00D1AFE0h):
00D1AFA0h:  18 89 44 24 1C 89 44 24 20 89 44 24 24 89 44 24
00D1AFB0h:  28 89 44 24 2C 89 44 24 30 89 44 24 34 8D 44 24
00D1AFC0h:  10 50 6A 00 68 3E 11 00 00 51 C7 44 24 20 04 00
00D1AFD0h:  00 00 89 74 24 24 FF 15 20 62 D3 00 8B 5C 24 34
00D1AFE0h:  F6 43 0C 31 0F 84 D2 00 00 00 57 68 00 08 00 00
00D1AFF0h:  E8 47 B1 00 00 83 C4 04 8D 54 24 10 52 8B F8 6A
00D1B000h:  01 57 56 8B CD 89 7C 24 20 E8 B2 CB FF FF 80 7C
00D1B010h:  24 44 00 74 70 6A 2C E8 EF B9 00 00 83 C4 04 85
Stack (0012EDD8h):
0012EDB8h:  00000000 0012F6BC 0012F694 00000000
0012EDC8h:  B7B86658 00000001 804DA3EE B7B86690
0012EDD8h:  00D63FC4 038346DC 038346D8 0012EE04
0012EDE8h:  77D1B903 00730C50 0000110A 00000009
0012EDF8h:  00000000 00000000 00D63FC4 038346DC
0012EE08h:  00D1B196 001907CC 00D1B1A4 00000000
0012EE18h:  00000000 00D63FC4 0012F1B4 038346D8
0012EE28h:  00000000 038346DC 00D1C597 038346D8
0012EE38h:  97E48F93 00000001 00000000 00D42214
0012EE48h:  00000000 00000000 038346D8 00000004
0012EE58h:  00000004 00D64960 0000000D 0000000D
0012EE68h:  00000000 00000000 00000000 00000000
0012EE78h:  00000000 00000000 00000000 00000000
0012EE88h:  00000000 00000000 00000000 00000000
0012EE98h:  00000000 00000000 00000000 00000000
0012EEA8h:  00000000 00000000 00000000 00000000
0012EEB8h:  00000000 00000000 00000000 00000000
0012EEC8h:  00000000 00000000 00000000 00000000
0012EED8h:  00000000 00000000 00000000 00000000
0012EEE8h:  00000000 00000000 00000000 00000000
Registers:
EAX: 00000000, EBX: 00000000, ECX: 00D63FC4, EDX: 7C91EB94
ESI: 00000000, EDI: 00000000, EBP: 00D63FC4, ESP: 0012EDD8
Crash location: "foo_uie_explorer", loaded at 00D10000h - 00D4C000h
Loaded modules:
foobar2000                      loaded at 00400000h - 004F3000h
ntdll                            loaded at 7C910000h - 7C9C7000h
kernel32                        loaded at 7C800000h - 7C904000h
COMCTL32                        loaded at 77390000h - 77492000h
msvcrt                          loaded at 77BE0000h - 77C38000h
ADVAPI32                        loaded at 77DA0000h - 77E4C000h
RPCRT4                          loaded at 77E50000h - 77EE1000h
GDI32                            loaded at 77EF0000h - 77F37000h
USER32                          loaded at 77D10000h - 77DA0000h
SHLWAPI                          loaded at 77F40000h - 77FB6000h
SHELL32                          loaded at 7C9D0000h - 7D1F3000h
ole32                            loaded at 774A0000h - 775DD000h
shared                          loaded at 10000000h - 10029000h
comdlg32                        loaded at 76340000h - 7638A000h
uxtheme                          loaded at 5B090000h - 5B0C8000h
FRAPS                            loaded at 63560000h - 65369000h
foo_cdda                        loaded at 009E0000h - 00A16000h
foo_cwb_hooks                    loaded at 00A40000h - 00A6B000h
foo_input_monkey                loaded at 00A90000h - 00ADA000h
foo_input_std                    loaded at 00B00000h - 00C14000h
foo_uie_albumart                loaded at 00C40000h - 00C76000h
gdiplus                          loaded at 4EB80000h - 4ED23000h
foo_uie_albumlist                loaded at 00CB0000h - 00CEF000h
foo_uie_explorer                loaded at 00D10000h - 00D4C000h
foo_uie_single_column_playlist  loaded at 00D70000h - 00DBF000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
MSVCR80                          loaded at 78130000h - 781CB000h
foo_uie_tabs                    loaded at 00DE0000h - 00E09000h
foo_uie_trackinfo_mod            loaded at 00E30000h - 00E7A000h
foo_uie_vis_projectm            loaded at 00E90000h - 00F06000h
OPENGL32                        loaded at 5F070000h - 5F13C000h
GLU32                            loaded at 6CEF0000h - 6CF11000h
DDRAW                            loaded at 736B0000h - 736F9000h
DCIMAN32                        loaded at 73B10000h - 73B16000h
foo_ui_columns                  loaded at 01530000h - 015C7000h
foo_ui_std                      loaded at 015F0000h - 01647000h
CLBCATQ                          loaded at 76F80000h - 76FFF000h
COMRes                          loaded at 77000000h - 770D4000h
OLEAUT32                        loaded at 770E0000h - 7716C000h
VERSION                          loaded at 77BD0000h - 77BD8000h
SETUPAPI                        loaded at 778E0000h - 779D8000h
appHelp                          loaded at 77B50000h - 77B72000h
cscui                            loaded at 765B0000h - 76606000h
CSCDLL                          loaded at 76590000h - 765AD000h
atioglxx                        loaded at 69000000h - 694F3000h
rarext                          loaded at 02880000h - 028AB000h
diskcopy                        loaded at 6D130000h - 6D2A2000h
ntshrui                          loaded at 76930000h - 76956000h
ATL                              loaded at 76AC0000h - 76AD1000h
NETAPI32                        loaded at 6FEE0000h - 6FF34000h
USERENV                          loaded at 76960000h - 76A15000h
nodshex                          loaded at 028E0000h - 028EF000h
imagehlp                        loaded at 76C40000h - 76C68000h
DBGHELP                          loaded at 5D3F0000h - 5D491000h
Stack dump analysis:
Address: 77D1B903h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "SendMessageW" (+00000049h)
Address: 00D1B196h, location: "foo_uie_explorer", loaded at 00D10000h - 00D4C000h
Address: 00D1B1A4h, location: "foo_uie_explorer", loaded at 00D10000h - 00D4C000h
Address: 00D1C597h, location: "foo_uie_explorer", loaded at 00D10000h - 00D4C000h
Address: 00D42214h, location: "foo_uie_explorer", loaded at 00D10000h - 00D4C000h
Address: 7C9205C8h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlFreeHeap" (+0000018Bh)
Address: 7C920551h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlFreeHeap" (+00000114h)
Address: 7C920732h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 7C91EE18h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "strchr" (+00000117h)
Address: 7C920738h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 7C9206ABh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+000000D7h)
Address: 7C9206EBh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+00000117h)
Address: 7C9205D4h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+00000000h)
Address: 7C924190h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlDosPathNameToNtPathName_U" (+00000093h)
Address: 7C911005h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlEnterCriticalSection" (+00000000h)
Address: 7C920970h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlReleasePebLock" (+0000000Fh)
Address: 7C98E4C0h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 7C923E6Fh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlDetermineDosPathNameType_U" (+000004D0h)
Address: 7C923E62h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlDetermineDosPathNameType_U" (+000004C3h)
Address: 7C98CE28h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 7C926CD7h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlMultiAppendUnicodeStringBuffer" (+000005BCh)
Address: 7C98CE62h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 7C923D00h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlDetermineDosPathNameType_U" (+00000361h)
Address: 7C9241E4h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlGetFullPathName_U" (+00000033h)
Address: 7C92712Ah, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlDosSearchPath_U" (+00000331h)
Address: 7C925152h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "bsearch" (+00000157h)
Address: 7C926F59h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlDosSearchPath_U" (+00000160h)
Address: 7C92056Dh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 77D1F4BBh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "UserLpkPSMTextOut" (+0000006Bh)
Address: 77D1F4E2h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "UserLpkPSMTextOut" (+00000092h)
Address: 77D1B42Dh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+000000F1h)
Address: 7C91EAE3h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 00D2664Ch, location: "foo_uie_explorer", loaded at 00D10000h - 00D4C000h
Address: 00D137ACh, location: "foo_uie_explorer", loaded at 00D10000h - 00D4C000h
Address: 00D2B230h, location: "foo_uie_explorer", loaded at 00D10000h - 00D4C000h
Address: 00D11769h, location: "foo_uie_explorer", loaded at 00D10000h - 00D4C000h
Address: 00D13631h, location: "foo_uie_explorer", loaded at 00D10000h - 00D4C000h
Address: 00D11A62h, location: "foo_uie_explorer", loaded at 00D10000h - 00D4C000h
Address: 00D11A06h, location: "foo_uie_explorer", loaded at 00D10000h - 00D4C000h
Address: 00D111B4h, location: "foo_uie_explorer", loaded at 00D10000h - 00D4C000h
Address: 00D33C84h, location: "foo_uie_explorer", loaded at 00D10000h - 00D4C000h
Address: 00D2423Eh, location: "foo_uie_explorer", loaded at 00D10000h - 00D4C000h
Address: 00430716h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77D18734h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetDC" (+0000006Dh)
Address: 77D241E2h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefDlgProcW" (+00000000h)
Address: 00D24317h, location: "foo_uie_explorer", loaded at 00D10000h - 00D4C000h
Address: 00D247ABh, location: "foo_uie_explorer", loaded at 00D10000h - 00D4C000h
Address: 77D1885Ah, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetDC" (+00000193h)
Address: 77D1882Ah, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetDC" (+00000163h)
Address: 77D40467h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DeregisterShellHookWindow" (+000001CFh)
Address: 77D18830h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetDC" (+00000169h)
Address: 77D1B4C0h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+00000184h)
Address: 77F33020h, location: "GDI32", loaded at 77EF0000h - 77F37000h
Address: 77EF75BAh, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "CreateCompatibleBitmap" (+00000577h)
Address: 77EF75D1h, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "CreateCompatibleBitmap" (+0000058Eh)
Address: 77EF6B40h, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "GetTextExtentPointW" (+00000000h)
Address: 77EF6B58h, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "GetTextExtentPointW" (+00000018h)
Address: 77D1F155h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DrawTextExW" (+00000505h)
Address: 77D1F0F6h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DrawTextExW" (+000004A6h)
Address: 77D1F076h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DrawTextExW" (+00000426h)
Address: 00430041h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00450044h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00470046h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00490048h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B004Ah, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004D004Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77D188DAh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 00D21B60h, location: "foo_uie_explorer", loaded at 00D10000h - 00D4C000h
Address: 00D340FBh, location: "foo_uie_explorer", loaded at 00D10000h - 00D4C000h
Address: 00D21BA7h, location: "foo_uie_explorer", loaded at 00D10000h - 00D4C000h
Address: 00440746h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77D2418Dh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "PrivateExtractIconExW" (+000002B2h)
Address: 77D241B0h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "PrivateExtractIconExW" (+000002D5h)
Address: 77D23FD9h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "PrivateExtractIconExW" (+000000FEh)
Address: 63567CA0h, location: "FRAPS", loaded at 63560000h - 65369000h
Symbol: "FrapsProcCALLWND" (+00000000h)
Address: 77D24204h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefDlgProcW" (+00000022h)
Address: 77D18816h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetDC" (+0000014Fh)
Address: 77D1B4D0h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+00000194h)
Address: 77D1B50Ch, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+000001D0h)
Address: 77D1B473h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+00000137h)
Address: 77D194BEh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetWindowLongA" (+00000061h)
Address: 77D1D4E4h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "SetPropW" (+000000BBh)
Address: 77D1B5F5h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "InvalidateRect" (+00000000h)
Address: 773B25F5h, location: "COMCTL32", loaded at 77390000h - 77492000h
Symbol: "Ordinal384" (+000067CBh)
Address: 773EED0Ch, location: "COMCTL32", loaded at 77390000h - 77492000h
Symbol: "FlatSB_SetScrollProp" (+0001B99Bh)
Address: 773F0538h, location: "COMCTL32", loaded at 77390000h - 77492000h
Symbol: "FlatSB_SetScrollProp" (+0001D1C7h)
Address: 77D188A6h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetWindowLongW" (+00000000h)
Address: 773B3B41h, location: "COMCTL32", loaded at 77390000h - 77492000h
Symbol: "Ordinal384" (+00007D17h)
Address: 77D188D1h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 773B4712h, location: "COMCTL32", loaded at 77390000h - 77492000h
Symbol: "Ordinal384" (+000088E8h)
Address: 77D1DA6Ch, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "SetFocus" (+0000000Ch)
Address: 773B6FA5h, location: "COMCTL32", loaded at 77390000h - 77492000h
Symbol: "Ordinal384" (+0000B17Bh)
Address: 773B949Dh, location: "COMCTL32", loaded at 77390000h - 77492000h
Symbol: "Ordinal384" (+0000D673h)
Address: 773B8B56h, location: "COMCTL32", loaded at 77390000h - 77492000h
Symbol: "Ordinal384" (+0000CD2Ch)
Address: 77D1B4CBh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+0000018Fh)
Address: 77D189CDh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetWindowLongW" (+00000127h)
Address: 77D189F0h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetWindowLongW" (+0000014Ah)
Address: 77D18A10h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DispatchMessageW" (+0000000Fh)
Address: 77D2E097h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "IsDialogMessageW" (+000000DBh)
Address: 0042FC8Eh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77D1DAEAh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DestroyWindow" (+00000000h)
Address: 004BEBA0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0042FD00h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10002DD2h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uCallStackTracker::uCallStackTracker" (+00000032h)
Address: 004C0520h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00D1DAEAh, location: "foo_uie_explorer", loaded at 00D10000h - 00D4C000h
Address: 0043085Fh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C03BCh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004BFB18h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C7690h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C921414h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "wcsncpy" (+00000985h)
Address: 7C921596h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "wcsncpy" (+00000B07h)
Address: 004E41C0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 1000C391h, location: "shared", loaded at 10000000h - 10029000h
Version info:
foobar2000 v0.9.4 beta 3
UNICODE
Additional info:
Album list panel 0.2.1 beta 4  (foo_uie_albumlist)
Single Column Playlist Display 0.3.2 beta [Sep 20 2006 - 06:11:29]  (foo_uie_single_column_playlist)
Columns UI 0.1.3 beta 1v6 TEST  (foo_ui_columns)
Monkey's Audio decoder 2.1.1  (foo_input_monkey)
Tabbed panel modified 0.2.4  (foo_uie_tabs)
CD Audio Decoder 2.1.1  (foo_cdda)
cwbowron's title format hooks 1.0.9 [Sep 14 2006 - 08:58:14]  (foo_cwb_hooks)
projectM visualization (Panel) 0.4 (SSE2)  (foo_uie_vis_projectm)
foobar2000 core v0.9.4 beta 3  (Core)
WMA Decoder 1.1  (foo_input_std)
Track info panel mod 0.5 beta [Aug 30 2006 - 16:35:44]  (foo_uie_trackinfo_mod)
Default User Interface 0.9acc  (foo_ui_std)
Album Art Panel 0.2.4.1  (foo_uie_albumart)
FLAC decoder 1.1.0  (foo_input_std)
Explorer Tree 1.04.6b  (foo_uie_explorer)
Reply #278
this plugin is great!!
the only thing ot lacks is the ability to use ctrl and shift keys to select multiple files..
does anybody know how to make that ?
Reply #279
There is a 'Mark' function in the context menu that would maybe fit your needs.
Reply #281
is there a way to assign some commands from the uie_explorer to buttons because this could be very usefull so I don't have to reach for my keyboard every time I want to do something? and is there a way to collapse the folders with a command or something? thanks in advance
Reply #282
Why does this panel show hidden directories like "Recycler" and "System Volume Information"? Can I fix this somehow? If not, I would appreciate implementing this in the next version very much.
Reply #283
How do i get this plugin work? I placed it in C:\Program Files\foobar2000\components but it doesnt view the explorer panel...
Reply #284
The best way to set it up is to hide all your drives & then place only your music folders in the favourites, that way only you music folders & nothing else show up.
Cheers
Reply #285
Done, its working
I do wanna to know something else: i noticed this plugin slows my foobar startup time pretty much.. its even more than winamp startup time
Is there some way i can disable/enable this plugin with one-click? i.e.: i click on one button, and the explorer sidebar disappears, and when i startup foobar it is still disabled, and i can enable/disable whenever i want?
Reply #286
Hello everyone!
I tried to find such a component.
Unfortunately, it seems there is no component can do this job well.
I knew there are foo_playlist_tree and foo_uie_albumlist, but I don't like to spent my time maintaining a database.
So I started to develop this component.
If you interest it, just download it and try it now.
For foobar2000 v0.9.2+ and Columns UI 0.1.3 beta 1v5
foo_uie_explorer 1.04.6b (binary)
For foobar2000 v0.8.3 and Columns UI 0.1.2.
foo_uie_explorer 0.04.6 (binary)
foo_uie_explorer 0.04.6 ANSI version (binary)
Sources on SubVersion svn://ku.myftp.org/foo_uie_explorer
Changelog
The screenshot
These links appear to be broken. I have uploaded a copy here.
Reply #287
Is this plugin compatible with v 0.9.4.2 ??
I use it together with UI collumns, but I can't get the directorylisting panel on my foobar.
I copied the .dll into my components folder and started foobar.
the exlporer tree panel is available in the preferences menu.
Any help would be greatly appreciated.
Reply #288
you have to add the panel to colums UI and yes it works on the current version of Foobar, cheers. See shot
Reply #289
Hello ,
Will it be possible to make foo_uie_explorer work with foo_browser - I mean to see the files in a selected folder in browser panels according to artist , genre, album etc' ?
I already asked cwbowron(the developer of foo_browser) the same question and that was his answer :
It would have to be done in foo_uie_explorer. foo_browser allows its contents to be modified by other plugins by using callings its context menu command "Browse...", which is how playlist tree communicates with it.
Thanks,
Amit.
I'm wondering this as well...
Reply #290
Hello ,
Thanks,
Amit.
Bump.... All I need is a simple "Yes, this is possible" or "No, this is not currently possible"
Reply #291
Sure it is possible: you woul just need the opportunity to set the context menu command "browse" for a leftclick or doubleclick in the preferences of explorer tree. But thze plugin doesn't support foobar commands.
I am wondering if this component is still in development!?
Reply #293
I tried to make the defalut new playlist name to be %artist%, but this didn't work. Is it possible to make it dynamically choose a playlist name?
Reply #294
Hi there.
First off: I love it  thank you for creating it.
2nd: I have a few things I wanna change, and so far I havent been able to find an answer by searching or by looking in the settings.
1: Can I customize the contextmenu anyhow? I dont want the "Replace playlist and play", "Replace playlist", "Add to favorites", "Delete", "Rename", "Favorites", "Preferenses" and "shell menu" (I know im boring and demanding )
2: I want a folder I dubbelklick on to First: look if there is a playlist with its name, and if it exists: change to that playlist and start playing. else create a playlist with the same name as the folder and put the music in the folder in the playlist and start playing.
3: EDIT: messed this one up, It was an old question I found pretty fast, so ignore this nr 3
4: this one isnt that important, but it would be sweet if it worked: I want it to do different things when I dubbelkick on a folder and when I dubbelklick on a music-file. So if I dubbelklick on a folder it does as I said in nr2, and when I dubbelklick on a music-file I want it to send it to a specific playlist and start playing it.
I know its a lot of stuff, and probably complicated to create such settings, I will still love you even if there is no way to get any of the things the way I want em, its still a really nice plugin and I respect the time you took to create it.
And If anyone has an idea of how to do it (I wouldnt hate complete idiotproof guide on how its done, but pointing me in the right direction is greatly appreciated aswell) please help this dude out
over n out
Reply #295
very, very nice!
but how do I 'hide' everything and only show my favo's?
edit.
sorry --> options --> display --> hide drives.
Reply #296
Hopefully this great plugin will support/show all playable files - currently cda and playlistfiles are not shown.
Reply #297
Nevermind. Found answer.
Reply #298
1.04.6b: first run causes high CPU load although I am doing nothing. A restart solved this.
Reply #299
I try to use the foo_uie_explorer plugin v0.04.6b.
So I copied the plugin in the "components" folder.
But if I start foobar2000 this information:
Failed to load DLL: foo_uie_explorer.dll
Reason: This component is missing a required dependency, or was made for different version of foobar2000.
I use foobar2000 v0.9.4.3 in WinXP SP2
Any thought about it? Maybe you could help me to make it work?
Thanks in advance!
