Topic: foo_uie_explorer - like windows explorer (Read 347777 times) previous topic - next topic
Reply #250
@mil3s
Just make the folders in your favorite folder favorite...
Something I would like is a caching system, so foo_uie_explorer doesn't have to read the tag's all the time.
If you have lots of folders and files in another folder, it takes to long to read them...
Grtz from a new user!
Reply #251
How can i add a command to open a file in the default application?
Is it possible to add a keyboard shortcut to a command?
Excuse my English
Reply #252
Sorry guys for asking again but can this plugin be used with 0.9.2? I read the thread but I cannot seem to add this panel at all.
I am using version 1.04.6a, Columns 0.1.3beta1v5 and foobar 0.9.2.
Same versions, same problem : you can access options in prefs, but cannot set panel in layout
It seems it's not ported yet for 0.9.2
les conquérants de l'inutile
Reply #253
Make sure you have the latest ColumnsUI as well
Reply #254
Yes I checked before, 0.1.3 beta 1v5 ...
The last edit in the first post says it s compatible with 0.9.1
Reply #255
I would love to download this plugin, but the link doesn't seem to work.
Reply #256
Hi!
I am also looking for this plugin, but can't find a link that works.
Could anyone upload it at rapidshare or give me a working link?
greetinx,
smoki1
Reply #258
Big Thanks!
Now my foobar is perfect for me
Reply #260
Thanks for the update
-foobar2000 + Burrrn + EAC
-HD 80Gb using High QualityVBR MP3s
Reply #261
Hi!
Is it possible to hide some folders from foo_uie_explorer? I cann't find any way for it. - Thanks!
Example:
((((( Strictly4me )))))
Reply #264
Here you will find the answere!
Reply #265
Someone could really screw up their foobar if they put in a bad path for "Select the path I specify" (on startup), because your program doesn't check whether that path is valid before trying to access it. (I should know - I did it! I'm glad I could press "No" to "You've removed this component, do you want to keep its settings?")
Maybe something to look at...
Reply #267
I have some problems with external drives:
When  I start foobar with my external drive closed, everyting is normal, but when I turn on my external hard drive, I can't see it except if I close foobar and reopen it.
Reply #268
I don't seem to be able to access other computers in my network. Is it possible to do this?
The drive I want to access is shared.
EDIT : Got it!
Reply #269
Hello ,
Will it be possible to make foo_uie_explorer work with foo_browser - I mean to see the files in a selected folder in browser panels according to artist , genre, album etc' ?
I already asked cwbowron(the developer of foo_browser) the same question and that was his answer :
It would have to be done in foo_uie_explorer. foo_browser allows its contents to be modified by other plugins by using callings its context menu command "Browse...", which is how playlist tree communicates with it.
Thanks,
Amit.
Reply #270
fb2k crashes when trying to hide a virtual drive (elaborate bytes VirtualCloneDrive).
not too important though
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 0188BCF0h
Access violation, operation: read, address: 0000000Ch
Call path:
entry=>app_mainloop
Code bytes (0188BCF0h):
0188BCB0h:  18 89 44 24 1C 89 44 24 20 89 44 24 24 89 44 24
0188BCC0h:  28 89 44 24 2C 89 44 24 30 89 44 24 34 8D 44 24
0188BCD0h:  10 50 6A 00 68 3E 11 00 00 51 C7 44 24 20 04 00
0188BCE0h:  00 00 89 74 24 24 FF 15 20 72 8A 01 8B 5C 24 34
0188BCF0h:  F6 43 0C 31 0F 84 D2 00 00 00 57 68 00 08 00 00
0188BD00h:  E8 F7 B1 00 00 83 C4 04 8D 54 24 10 52 8B F8 6A
0188BD10h:  01 57 56 8B CD 89 7C 24 20 E8 52 C9 FF FF 80 7C
0188BD20h:  24 44 00 74 70 6A 2C E8 94 B6 00 00 83 C4 04 85
Stack (0012EEFCh):
0012EEDCh:  00000000 F0EEA6C8 BC6E03E8 7FFDF700
0012EEECh:  007703E8 0000007D FFFFFFF0 50010000
0012EEFCh:  018D4BA4 018DEB6C 018DEB68 0012EF28
0012EF0Ch:  77D4B903 007A3C38 0000110A 00000009
0012EF1Ch:  00000000 00000000 018D4BA4 018DEB6C
0012EF2Ch:  0188BEA6 005A0316 0188BEB4 00000000
0012EF3Ch:  00000000 018D4BA4 0012F2F4 018DEB68
0012EF4Ch:  00000007 018DEB6C 0188D2A8 018DEB68
0012EF5Ch:  6362BB76 00000001 00000000 018B31F4
0012EF6Ch:  00000000 00000000 018DEB68 00000004
0012EF7Ch:  018DE548 00000013 FFFF0000 FFFF0002
0012EF8Ch:  00000027 003D0000 7C910202 00000002
0012EF9Ch:  FFFFFFFF 003D0000 FFFFFFFF FFFFFFFF
0012EFACh:  7C910202 03773BE0 7C90E900 01E307ED
0012EFBCh:  00000007 00000000 00440043 00440020
0012EFCCh:  00690072 00650076 00280020 003A0054
0012EFDCh:  00000029 00500028 0029003A 00000000
0012EFECh:  00630061 0075006B 00200070 00490028
0012EFFCh:  0029003A 00120000 7C90E900 0012F03C
0012F00Ch:  003D0000 7C910202 00000003 003D0718
Registers:
EAX: 00000000, EBX: 00000000, ECX: 018D4BA4, EDX: 7C90E4F4
ESI: 00000000, EDI: 00000000, EBP: 018D4BA4, ESP: 0012EEFC
Crash location: "foo_uie_explorer", loaded at 01880000h - 018BD000h
Loaded modules:
foobar2000                      loaded at 00400000h - 004EC000h
ntdll                            loaded at 7C900000h - 7C9AF000h
kernel32                        loaded at 7C800000h - 7C8F4000h
COMCTL32                        loaded at 773D0000h - 774D3000h
msvcrt                          loaded at 77C10000h - 77C68000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F01000h
GDI32                            loaded at 77F10000h - 77F57000h
USER32                          loaded at 77D40000h - 77DD0000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7D1D6000h
ole32                            loaded at 774E0000h - 7761D000h
shared                          loaded at 10000000h - 1002A000h
comdlg32                        loaded at 763B0000h - 763F9000h
IMM32                            loaded at 76390000h - 763AD000h
LPK                              loaded at 629C0000h - 629C9000h
USP10                            loaded at 74D90000h - 74DFB000h
FileBXH                          loaded at 003E0000h - 003FB000h
UxTheme                          loaded at 5AD70000h - 5ADA8000h
apphelp                          loaded at 77B40000h - 77B62000h
msctfime                        loaded at 755C0000h - 755EE000h
foo_abx                          loaded at 00A30000h - 00A63000h
foo_AdvancedControls            loaded at 00A90000h - 00AC0000h
foo_alarm                        loaded at 00AD0000h - 00AEC000h
foo_albumlist                    loaded at 00B10000h - 00B51000h
foo_benchmark                    loaded at 00B80000h - 00BA8000h
foo_binpack                      loaded at 00BD0000h - 00BF0000h
foo_bitcompare                  loaded at 00C10000h - 00C36000h
foo_burninate                    loaded at 00C60000h - 00C97000h
VERSION                          loaded at 77C00000h - 77C08000h
foo_cdda                        loaded at 00CC0000h - 00CF6000h
foo_channel_mixer                loaded at 00D20000h - 00D5A000h
foo_common                      loaded at 00D70000h - 00DAA000h
foo_converter                    loaded at 00DD0000h - 00E3A000h
foo_convolve                    loaded at 00E60000h - 00EB1000h
foo_cuesheet_creator            loaded at 00EE0000h - 00F0D000h
foo_dbsearch                    loaded at 00F30000h - 00F8C000h
foo_dsp_std                      loaded at 00FB0000h - 00FF1000h
foo_dsp_tube                    loaded at 01020000h - 01046000h
foo_freedb2                      loaded at 01060000h - 010A0000h
foo_infobox                      loaded at 010C0000h - 01100000h
foo_input_monkey                loaded at 01120000h - 0116A000h
foo_input_shorten                loaded at 01190000h - 011BE000h
foo_input_std                    loaded at 011E0000h - 012EB000h
foo_lnk                          loaded at 01310000h - 01329000h
foo_masstag                      loaded at 01350000h - 0139F000h
foo_out_asio                    loaded at 013C0000h - 013EE000h
foo_out_ks                      loaded at 01410000h - 0143A000h
SETUPAPI                        loaded at 77920000h - 77A13000h
foo_playcount                    loaded at 01460000h - 01487000h
foo_playlist_bind                loaded at 014B0000h - 014D5000h
foo_playlist_manager            loaded at 014F0000h - 01537000h
foo_pqview                      loaded at 01560000h - 0157C000h
foo_preview                      loaded at 015A0000h - 015C1000h
foo_random                      loaded at 015E0000h - 0161F000h
foo_rgscan                      loaded at 01640000h - 01685000h
foo_run                          loaded at 016B0000h - 016DB000h
foo_shutdown                    loaded at 01700000h - 01718000h
foo_skip                        loaded at 01740000h - 0175B000h
foo_uie_albumlist                loaded at 01780000h - 017BF000h
foo_uie_bookmarks                loaded at 017E0000h - 0182E000h
foo_uie_console                  loaded at 01840000h - 0185C000h
foo_uie_explorer                loaded at 01880000h - 018BD000h
foo_uie_playlists_dropdown      loaded at 018E0000h - 0191A000h
foo_uie_quicksearch              loaded at 01940000h - 01988000h
foo_uie_tabs                    loaded at 019B0000h - 019D6000h
foo_uie_trackinfo                loaded at 01A00000h - 01A2E000h
foo_ui_columns                  loaded at 01A50000h - 01AEB000h
foo_ui_std                      loaded at 01B10000h - 01B67000h
foo_unpack                      loaded at 01B90000h - 01BBE000h
foo_utils                        loaded at 01BE0000h - 01C19000h
foo_vis_channelusage            loaded at 01C40000h - 01C63000h
OLEAUT32                        loaded at 77120000h - 771AC000h
CLBCATQ                          loaded at 76FD0000h - 7704F000h
COMRes                          loaded at 77050000h - 77115000h
gdiplus                          loaded at 4EC50000h - 4EDF5000h
CFiShlJP                        loaded at 02430000h - 02455000h
USERENV                          loaded at 769C0000h - 76A73000h
imagehlp                        loaded at 76C90000h - 76CB8000h
DBGHELP                          loaded at 59A60000h - 59B01000h
Stack dump analysis:
Address: 77D4B903h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SendMessageW" (+00000049h)
Address: 0188BEA6h, location: "foo_uie_explorer", loaded at 01880000h - 018BD000h
Address: 0188BEB4h, location: "foo_uie_explorer", loaded at 01880000h - 018BD000h
Address: 0188D2A8h, location: "foo_uie_explorer", loaded at 01880000h - 018BD000h
Address: 018B31F4h, location: "foo_uie_explorer", loaded at 01880000h - 018BD000h
Address: 7C910202h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 7C90E900h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "strchr" (+00000113h)
Address: 00440043h, location: "foobar2000", loaded at 00400000h - 004EC000h
Address: 00440020h, location: "foobar2000", loaded at 00400000h - 004EC000h
Address: 00490028h, location: "foobar2000", loaded at 00400000h - 004EC000h
Address: 7C910208h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 7C911066h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "wcsncpy" (+00000B07h)
Address: 7C9101BBh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+00000117h)
Address: 7C9100A4h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+00000000h)
Address: 7C91017Bh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+000000D7h)
Address: 7C910000h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+000000F3h)
Address: 7C910098h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+0000018Bh)
Address: 7C910021h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+00000114h)
Address: 7C91003Dh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 7C910040h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 018972FDh, location: "foo_uie_explorer", loaded at 01880000h - 018BD000h
Address: 0189731Ch, location: "foo_uie_explorer", loaded at 01880000h - 018BD000h
Address: 0189C010h, location: "foo_uie_explorer", loaded at 01880000h - 018BD000h
Address: 018A4B34h, location: "foo_uie_explorer", loaded at 01880000h - 018BD000h
Address: 01895073h, location: "foo_uie_explorer", loaded at 01880000h - 018BD000h
Address: 7C91082Ch, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "wcsncpy" (+000002CDh)
Address: 7C910961h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "wcsncpy" (+00000402h)
Address: 003E48DCh, location: "FileBXH", loaded at 003E0000h - 003FB000h
Symbol: "DFH_AddMenuItem" (+00000FFCh)
Address: 77F180F7h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "ExtTextOutW" (+00000098h)
Address: 74DE055Ch, location: "USP10", loaded at 74D90000h - 74DFB000h
Address: 74DE0604h, location: "USP10", loaded at 74D90000h - 74DFB000h
Address: 74DE0470h, location: "USP10", loaded at 74D90000h - 74DFB000h
Address: 74DC4700h, location: "USP10", loaded at 74D90000h - 74DFB000h
Address: 74DA31BDh, location: "USP10", loaded at 74D90000h - 74DFB000h
Symbol: "ScriptTextOut" (+00000178h)
Address: 74DE0384h, location: "USP10", loaded at 74D90000h - 74DFB000h
Address: 74DE0260h, location: "USP10", loaded at 74D90000h - 74DFB000h
Address: 74DAE11Dh, location: "USP10", loaded at 74D90000h - 74DFB000h
Symbol: "ScriptApplyDigitSubstitution" (+0000949Bh)
Address: 74DE04B4h, location: "USP10", loaded at 74D90000h - 74DFB000h
Address: 00420041h, location: "foobar2000", loaded at 00400000h - 004EC000h
Address: 00460045h, location: "foobar2000", loaded at 00400000h - 004EC000h
Address: 00480047h, location: "foobar2000", loaded at 00400000h - 004EC000h
Address: 01892990h, location: "foo_uie_explorer", loaded at 01880000h - 018BD000h
Address: 018A4FFBh, location: "foo_uie_explorer", loaded at 01880000h - 018BD000h
Address: 018929D7h, location: "foo_uie_explorer", loaded at 01880000h - 018BD000h
Address: 77D48734h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+0000006Dh)
Address: 77D5418Dh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PrivateExtractIconExW" (+000002B2h)
Address: 77D70467h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DeregisterShellHookWindow" (+000001CFh)
Address: 77D541B0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PrivateExtractIconExW" (+000002D5h)
Address: 77D53FD9h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PrivateExtractIconExW" (+000000FEh)
Address: 76398CB3h, location: "IMM32", loaded at 76390000h - 763AD000h
Symbol: "ImmIsIME" (+0000003Fh)
Address: 77D4B50Ch, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+000001D0h)
Address: 7C90E453h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 77D53F5Ah, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PrivateExtractIconExW" (+0000007Fh)
Address: 77D494BEh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongA" (+00000061h)
Address: 77D4D4E4h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SetPropW" (+000000BBh)
Address: 77D4B5F5h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "InvalidateRect" (+00000000h)
Address: 773F285Bh, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+000069D3h)
Address: 7742F530h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "FlatSB_SetScrollProp" (+0001BA03h)
Address: 77430D5Ch, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "FlatSB_SetScrollProp" (+0001D22Fh)
Address: 77D488A6h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+00000000h)
Address: 773F3DA7h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+00007F1Fh)
Address: 77D488D1h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 77D488DAh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 773F4978h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+00008AF0h)
Address: 77D4D69Ch, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetActiveWindow" (+00000044h)
Address: 77D48816h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+0000014Fh)
Address: 77D48830h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+00000169h)
Address: 77D4B4C0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000184h)
Address: 77D4B4D0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000194h)
Address: 77D4B473h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000137h)
Address: 77D4DA6Ch, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SetFocus" (+0000000Ch)
Address: 773F72DBh, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+0000B453h)
Address: 773F97D3h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+0000D94Bh)
Address: 773F8E8Ch, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+0000D004h)
Address: 77D4B4CBh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+0000018Fh)
Address: 77D618F4h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "UnhookWinEvent" (+00000077h)
Address: 77D489CDh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+00000127h)
Address: 77D489F0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+0000014Ah)
Address: 77D48A10h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DispatchMessageW" (+0000000Fh)
Address: 77D5E097h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "IsDialogMessageW" (+000000DBh)
Address: 0042EC53h, location: "foobar2000", loaded at 00400000h - 004EC000h
Address: 004BCBA0h, location: "foobar2000", loaded at 00400000h - 004EC000h
Address: 0042ECBDh, location: "foobar2000", loaded at 00400000h - 004EC000h
Address: 77D4DAEAh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DestroyWindow" (+00000000h)
Address: 00D4DAEAh, location: "foo_channel_mixer", loaded at 00D20000h - 00D5A000h
Address: 0042F80Ch, location: "foobar2000", loaded at 00400000h - 004EC000h
Address: 004BE37Ch, location: "foobar2000", loaded at 00400000h - 004EC000h
Address: 004C55F8h, location: "foobar2000", loaded at 00400000h - 004EC000h
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 004EC000h
Address: 004C55DCh, location: "foobar2000", loaded at 00400000h - 004EC000h
Address: 004E2158h, location: "foobar2000", loaded at 00400000h - 004EC000h
Address: 7C91968Ah, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlReAllocateHeap" (+0000020Ah)
Address: 1000E250h, location: "shared", loaded at 10000000h - 1002A000h
Address: 1000396Ah, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uGetCallStackPath" (+00000B5Ah)
Address: 7C9101C0h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 004915DDh, location: "foobar2000", loaded at 00400000h - 004EC000h
Address: 004E21D8h, location: "foobar2000", loaded at 00400000h - 004EC000h
Address: 0044CAC9h, location: "foobar2000", loaded at 00400000h - 004EC000h
Address: 0040C5ADh, location: "foobar2000", loaded at 00400000h - 004EC000h
Address: 0040372Bh, location: "foobar2000", loaded at 00400000h - 004EC000h
Address: 004943AAh, location: "foobar2000", loaded at 00400000h - 004EC000h
Address: 004BE4D0h, location: "foobar2000", loaded at 00400000h - 004EC000h
Address: 10002D97h, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000B7h)
Address: 004ACB62h, location: "foobar2000", loaded at 00400000h - 004EC000h
Address: 0042F9F8h, location: "foobar2000", loaded at 00400000h - 004EC000h
Address: 004DE970h, location: "foobar2000", loaded at 00400000h - 004EC000h
Address: 00494434h, location: "foobar2000", loaded at 00400000h - 004EC000h
Address: 0048F90Ch, location: "foobar2000", loaded at 00400000h - 004EC000h
Address: 0048F906h, location: "foobar2000", loaded at 00400000h - 004EC000h
Address: 004B29E8h, location: "foobar2000", loaded at 00400000h - 004EC000h
Version info:
foobar2000 v0.9.3 beta 4
UNICODE
Additional info:
Album list panel 0.2.1 beta 4  (foo_uie_albumlist)
Explorer Tree 1.04.6a  (foo_uie_explorer)
Track info panel 0.8  (foo_uie_trackinfo)
Foo Shutdown 0.9  (foo_shutdown)
ASIO support 1.2.2  (foo_out_asio)
ABX comparator 1.3  (foo_abx)
Preview 1.2  (foo_preview)
Convolver 0.3  (foo_convolve)
Monkey's Audio decoder 2.1.1  (foo_input_monkey)
Binary comparator 1.0  (foo_bitcompare)
Shell Link Resolver 1.2  (foo_lnk)
foo_skip 0.2  (foo_skip)
Alarm 1.01  (foo_alarm)
FLAC decoder 1.1.0  (foo_input_std)
Run services 0.3.2  (foo_run)
Converter 1.0.1  (foo_converter)
ReplayGain Scanner 2.0.2  (foo_rgscan)
Shorten decoder 0.4.2a  (foo_input_shorten)
Album List 3.2.0  (foo_albumlist)
Tube Sound 0.7  (foo_dsp_tube)
CD Audio Decoder 2.1.1  (foo_cdda)
Playlists Dropdown 0.5.7.5  (foo_uie_playlists_dropdown)
Standard DSP array 1.0  (foo_dsp_std)
Playlist Manager 1.0.2  (foo_playlist_manager)
Tabbed panel modifyed 0.2.1  (foo_uie_tabs)
Console panel 0.2  (foo_uie_console)
Masstagger 1.6  (foo_masstag)
Cuesheet Creator 0.4.5  (foo_cuesheet_creator)
Default User Interface 0.9acc  (foo_ui_std)
Channel Usage Visualisation 1.0  (foo_vis_channelusage)
freedb tagger v0.5.1  (foo_freedb2)
Decoding speed test 1.0  (foo_benchmark)
ZIP/GZIP reader 1.0  (foo_unpack)
Randomized playlist entry 1.2.3  (foo_random)
Database search 1.3.1 beta 11  (foo_dbsearch)
Special file info box 2.0.3  (foo_infobox)
Bookmarks 0.0.1c  (foo_uie_bookmarks)
Columns UI 0.1.3 beta 1v5  (foo_ui_columns)
Quick Search Toolbar 2.8f  (foo_uie_quicksearch)
FooBar2000 Advanced Controls 0.5.9.0  (foo_AdvancedControls)
Playback Statistics 1.0  (foo_playcount)
Audio CD Writer 2.0.1  (foo_burninate)
Channel Mixer 0.9.4  (foo_channel_mixer)
Common services 0.1  (foo_common)
BinPack Playlist Generator 1.0.0  (foo_binpack)
RAR reader 1.1  (foo_unpack)
Playlist Bind 3.0  (foo_playlist_bind)
Playlist tools 0.5.8  (foo_utils)
Kernel Streaming Output 1.2.2  (foo_out_ks)
Reply #271
Illegal operation:
Code: C0000090h, flags: 00000000h, address: 01261784h
Call path:
entry=>app_mainloop=>on_playback_stop
Code bytes (01261784h):
01261744h:  05 18 E7 27 01 DD 05 10 E7 27 01 DE F9 8B E5 5D
01261754h:  C3 E8 A6 52 00 00 89 44 24 04 DB 44 24 04 DD 5C
01261764h:  24 08 E8 75 53 00 00 89 44 24 04 DB 44 24 04 D9
01261774h:  EE D8 D9 DF E0 F6 C4 41 7A 0C DD 44 24 08 D9 C9
01261784h:  DE F9 8B E5 5D C3 DD D8 DD 05 08 E7 27 01 8B E5
01261794h:  5D C3 CC CC CC CC CC CC CC CC CC CC 53 32 DB E8
012617A4h:  28 54 00 00 84 C0 74 13 E8 2F 53 00 00 85 C0 7D
012617B4h:  0A 38 9E D1 08 00 00 74 02 B3 01 8B C6 88 9E CC
Stack (0012F7DCh):
0012F7BCh:  0209F774 77F988F0 77F421E0 0000005A
0012F7CCh:  0209CD64 C0000005 0209CD40 0209CD50
0012F7DCh:  01283500 00000018 00000000 0040A3A8
0012F7ECh:  0040A3BD 00000000 0040B4DE 0040A3BD
0012F7FCh:  00000000 0040B4DE 00007210 0012F874
0012F80Ch:  004384B2 01266C1C 01283500 00000000
0012F81Ch:  004D1CD0 0012F868 0127B528 FFFFFFFF
0012F82Ch:  0126404A 00000004 00000000 00436695
0012F83Ch:  00000002 0012F888 00000004 00000000
0012F84Ch:  00000000 004D4704 004D4D00 00000013
0012F85Ch:  00000012 0000000B 0012F840 0012F890
0012F86Ch:  0049D04A 00000002 0012F89C 004379DA
0012F87Ch:  00000002 00000006 00000015 00000000
0012F88Ch:  052F8000 0012F8CC 004A0BDF FFFFFFFF
0012F89Ch:  0012F8D8 00437B00 00000002 0043848C
0012F8ACh:  00000000 004D2040 0044C2D4 00000004
0012F8BCh:  00000000 00E80043 004D2040 05403E50
0012F8CCh:  0012F98C 0049D125 00000000 0012F998
0012F8DCh:  0523DCE7 004D1CD0 00000015 00010420
0012F8ECh:  0524F6FC 00000015 DF36F8D9 00010420
Registers:
EAX: 00000018, EBX: 00000000, ECX: 0012F868, EDX: 00429BDF
ESI: 01283500, EDI: 0012F888, EBP: 0012F874, ESP: 0012F7DC
Crash location: "foo_AdvancedControls", loaded at 01260000h - 01290000h
Loaded modules:
foobar2000                      loaded at 00400000h - 004E6000h
ntdll                            loaded at 77F40000h - 77FEE000h
kernel32                        loaded at 77E40000h - 77F38000h
COMCTL32                        loaded at 78090000h - 78175000h
msvcrt                          loaded at 77BE0000h - 77C33000h
GDI32                            loaded at 7F000000h - 7F041000h
USER32                          loaded at 77D10000h - 77D9D000h
ADVAPI32                        loaded at 77DA0000h - 77E3C000h
RPCRT4                          loaded at 78000000h - 78087000h
SHLWAPI                          loaded at 70A70000h - 70AD6000h
SHELL32                          loaded at 004F0000h - 00CF4000h
ole32                            loaded at 4FEC0000h - 4FFF6000h
comdlg32                        loaded at 76350000h - 76396000h
uxtheme                          loaded at 5B0F0000h - 5B124000h
foo_abx                          loaded at 003C0000h - 003F4000h
foo_AdvancedControls            loaded at 01260000h - 01290000h
foo_albumlist                    loaded at 012A0000h - 012E1000h
foo_cdda                        loaded at 01310000h - 01349000h
foo_common                      loaded at 01370000h - 013AA000h
foo_converter                    loaded at 013D0000h - 01434000h
foo_cwb_hooks                    loaded at 01460000h - 01469000h
MSVCR80                          loaded at 01480000h - 0151B000h
foo_dbsearch                    loaded at 01530000h - 0158C000h
foo_dsp_std                      loaded at 015B0000h - 015F2000h
foo_freedb2                      loaded at 01620000h - 01660000h
foo_input_shorten                loaded at 01680000h - 016AE000h
foo_input_std                    loaded at 016D0000h - 017CB000h
foo_lnk                          loaded at 017F0000h - 01809000h
foo_lock_ex                      loaded at 01830000h - 01849000h
foo_lyricsdb                    loaded at 01860000h - 0187E000h
OLEAUT32                        loaded at 770F0000h - 7717B000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
WININET                          loaded at 63000000h - 63097000h
CRYPT32                          loaded at 76260000h - 762E9000h
MSASN1                          loaded at 76240000h - 76250000h
foo_managedWrapper              loaded at 01940000h - 019E1000h
mscoree                          loaded at 79000000h - 79045000h
msvcm80                          loaded at 7C4C0000h - 7C53D000h
mscorwks                        loaded at 79E70000h - 7A3D1000h
mscorlib.ni                      loaded at 790C0000h - 79BA8000h
mscorjit                        loaded at 79060000h - 790B3000h
rsaenh                          loaded at 0FFD0000h - 0FFF3000h
System.ni                        loaded at 7A440000h - 7ABFE000h
System.Drawing.ni                loaded at 7ADE0000h - 7AF74000h
System.Windows.Forms.ni          loaded at 7AFD0000h - 7BC56000h
dotnet_title                    loaded at 11000000h - 11012000h
gdiplus                          loaded at 70D00000h - 70E91000h
foo_masstag                      loaded at 042F0000h - 04340000h
foo_playcount                    loaded at 04460000h - 04474000h
foo_playlist_manager            loaded at 04490000h - 044D6000h
foo_pqview                      loaded at 04500000h - 0451C000h
foo_random                      loaded at 04540000h - 0457F000h
foo_rgscan                      loaded at 045A0000h - 045E6000h
foo_run                          loaded at 04610000h - 0463B000h
foo_tradersfriend                loaded at 04660000h - 0469D000h
foo_uie_albumart                loaded at 046C0000h - 046F0000h
foo_uie_albumlist                loaded at 04710000h - 0474F000h
foo_uie_console                  loaded at 04770000h - 0478C000h
foo_uie_explorer                loaded at 047B0000h - 047EC000h
foo_uie_lyrics                  loaded at 04810000h - 0486E000h
WINMM                            loaded at 76AF0000h - 76B1D000h
foo_uie_playlists_dropdown      loaded at 04910000h - 0494A000h
foo_uie_tabs                    loaded at 04970000h - 04996000h
foo_uie_trackinfo_mod            loaded at 049C0000h - 049FF000h
foo_ui_std                      loaded at 04A10000h - 04A67000h
foo_unpack                      loaded at 04A90000h - 04ABE000h
foo_utils                        loaded at 04AE0000h - 04B19000h
foo_version                      loaded at 04B40000h - 04B66000h
dbghelp                          loaded at 6DA00000h - 6DA7D000h
VERSION                          loaded at 77BD0000h - 77BD7000h
foo_vis_projectM                loaded at 04C90000h - 04D01000h
OPENGL32                        loaded at 5F0D0000h - 5F196000h
GLU32                            loaded at 68FC0000h - 68FDE000h
DDRAW                            loaded at 51000000h - 51050000h
DCIMAN32                        loaded at 73B30000h - 73B36000h
foo_ui_columns                  loaded at 05230000h - 052CB000h
CLBCATQ                          loaded at 05B60000h - 05BE1000h
COMRes                          loaded at 77010000h - 770E3000h
SETUPAPI                        loaded at 76620000h - 76708000h
appHelp                          loaded at 75EE0000h - 75EFF000h
cscui                            loaded at 765C0000h - 76610000h
CSCDLL                          loaded at 765A0000h - 765BC000h
USERENV                          loaded at 75A10000h - 75AB7000h
System.Xml.ni                    loaded at 69BE0000h - 6A148000h
DSOUND                          loaded at 51080000h - 510E1000h
wdmaud                          loaded at 72C90000h - 72C99000h
msacm32                          loaded at 72C80000h - 72C88000h
MSACM32                          loaded at 77BB0000h - 77BC4000h
midimap                          loaded at 77BA0000h - 77BA7000h
KsUser                          loaded at 5EF80000h - 5EF84000h
shdocvw                          loaded at 71700000h - 71849000h
NBShell                          loaded at 068C0000h - 068DE000h
MFC71U                          loaded at 7C250000h - 7C352000h
MSVCR71                          loaded at 068E0000h - 06936000h
MSVCP71                          loaded at 7C3A0000h - 7C41B000h
TzShell                          loaded at 06A90000h - 06B38000h
OLEPRO32                        loaded at 5F1A0000h - 5F1BA000h
TzArchive10                      loaded at 06C40000h - 06DE8000h
cabinet                          loaded at 750D0000h - 750E3000h
unrar3                          loaded at 06DF0000h - 06E20000h
TzImage10                        loaded at 06960000h - 06975000h
ntshrui                          loaded at 76940000h - 76965000h
ATL                              loaded at 76AD0000h - 76AE5000h
NETAPI32                        loaded at 71BA0000h - 71BEE000h
shlext                          loaded at 07780000h - 07793000h
oodsh                            loaded at 078D0000h - 07931000h
WINSPOOL                        loaded at 72F70000h - 72F93000h
OODSHRS                          loaded at 077C0000h - 077C9000h
bdshelxt                        loaded at 07940000h - 0794E000h
MFC70                            loaded at 7C140000h - 7C22E000h
MSVCR70                          loaded at 7C000000h - 7C054000h
OLEACC                          loaded at 74C00000h - 74C2C000h
MSVCP60                          loaded at 76020000h - 76081000h
avgse                            loaded at 621A0000h - 621AE000h
ShellExtensionU                  loaded at 07970000h - 07984000h
MFC42u                          loaded at 727A0000h - 72892000h
MFC42LOC                        loaded at 61DC0000h - 61DCE000h
ICQLiteShell                    loaded at 07990000h - 0799F000h
MFC42                            loaded at 73D30000h - 73E22000h
chext                            loaded at 079A0000h - 079BE000h
7-zipn                          loaded at 079F0000h - 07A0D000h
Secur32                          loaded at 76F50000h - 76F60000h
wsock32                          loaded at 71A30000h - 71A39000h
WS2_32                          loaded at 71A10000h - 71A25000h
WS2HELP                          loaded at 71A00000h - 71A08000h
RASAPI32                        loaded at 76EA0000h - 76ED7000h
rasman                          loaded at 76E50000h - 76E61000h
TAPI32                          loaded at 76E70000h - 76E9B000h
rtutils                          loaded at 76E40000h - 76E4D000h
sensapi                          loaded at 72240000h - 72245000h
urlmon                          loaded at 1A400000h - 1A47D000h
mswsock                          loaded at 719B0000h - 719EC000h
DNSAPI                          loaded at 76EE0000h - 76F05000h
winrnr                          loaded at 76F70000h - 76F77000h
WLDAP32                          loaded at 76F20000h - 76F4D000h
rasadhlp                        loaded at 76F80000h - 76F85000h
wshtcpip                        loaded at 719F0000h - 719F8000h
imagehlp                        loaded at 76C50000h - 76C72000h
Address: 01283500h, location: "foo_AdvancedControls", loaded at 01260000h - 01290000h
Address: 0040A3A8h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 0040A3BDh, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 0040B4DEh, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004384B2h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 01266C1Ch, location: "foo_AdvancedControls", loaded at 01260000h - 01290000h
Address: 004D1CD0h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 0127B528h, location: "foo_AdvancedControls", loaded at 01260000h - 01290000h
Address: 0126404Ah, location: "foo_AdvancedControls", loaded at 01260000h - 01290000h
Address: 00436695h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004D4704h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004D4D00h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 0049D04Ah, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004379DAh, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004A0BDFh, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 00437B00h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 0043848Ch, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004D2040h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 0044C2D4h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 0049D125h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 0523DCE7h, location: "foo_ui_columns", loaded at 05230000h - 052CB000h
Address: 0524F6FCh, location: "foo_ui_columns", loaded at 05230000h - 052CB000h
Address: 052B3C0Ch, location: "foo_ui_columns", loaded at 05230000h - 052CB000h
Address: 77D45602h, location: "USER32", loaded at 77D10000h - 77D9D000h
Symbol: "CreateAcceleratorTableA" (+00000314h)
Address: 77D1A548h, location: "USER32", loaded at 77D10000h - 77D9D000h
Symbol: "DefWindowProcW" (+00000072h)
Address: 05291844h, location: "foo_ui_columns", loaded at 05230000h - 052CB000h
Address: 77D1A586h, location: "USER32", loaded at 77D10000h - 77D9D000h
Symbol: "DefWindowProcW" (+000000B0h)
Address: 77D1883Fh, location: "USER32", loaded at 77D10000h - 77D9D000h
Symbol: "IsCharAlphaNumericA" (+00006683h)
Address: 05237220h, location: "foo_ui_columns", loaded at 05230000h - 052CB000h
Address: 77D18D0Bh, location: "USER32", loaded at 77D10000h - 77D9D000h
Address: 77D18D14h, location: "USER32", loaded at 77D10000h - 77D9D000h
Address: 05237398h, location: "foo_ui_columns", loaded at 05230000h - 052CB000h
Address: 052569A8h, location: "foo_ui_columns", loaded at 05230000h - 052CB000h
Address: 045102D1h, location: "foo_pqview", loaded at 04500000h - 0451C000h
Address: 77D18654h, location: "USER32", loaded at 77D10000h - 77D9D000h
Symbol: "IsCharAlphaNumericA" (+00006498h)
Address: 77D18723h, location: "USER32", loaded at 77D10000h - 77D9D000h
Symbol: "IsCharAlphaNumericA" (+00006567h)
Address: 77D18740h, location: "USER32", loaded at 77D10000h - 77D9D000h
Symbol: "IsCharAlphaNumericA" (+00006584h)
Address: 77D18999h, location: "USER32", loaded at 77D10000h - 77D9D000h
Symbol: "GetMessageW" (+00000125h)
Address: 004D1800h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 77D189C0h, location: "USER32", loaded at 77D10000h - 77D9D000h
Symbol: "GetMessageW" (+0000014Ch)
Address: 77D18A12h, location: "USER32", loaded at 77D10000h - 77D9D000h
Symbol: "DispatchMessageW" (+0000000Bh)
Address: 00427DCAh, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 77D1D185h, location: "USER32", loaded at 77D10000h - 77D9D000h
Address: 004287F1h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004B0380h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004B287Ch, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 77F47BAEh, location: "ntdll", loaded at 77F40000h - 77FEE000h
Address: 77F844A8h, location: "ntdll", loaded at 77F40000h - 77FEE000h
Symbol: "RtlRemoteCall" (+000001BEh)
Address: 004B9F28h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 77F988F0h, location: "ntdll", loaded at 77F40000h - 77FEE000h
Symbol: "wcstombs" (+00003409h)
Address: 77F48497h, location: "ntdll", loaded at 77F40000h - 77FEE000h
Symbol: "RtlAllocateHeap" (+000008E9h)
Address: 77F48A3Ah, location: "ntdll", loaded at 77F40000h - 77FEE000h
Symbol: "RtlAllocateHeap" (+00000E8Ch)
Address: 004D6BCCh, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004A892Ch, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 77F49037h, location: "ntdll", loaded at 77F40000h - 77FEE000h
Symbol: "RtlFreeHeap" (+000005F9h)
Address: 77F7E227h, location: "ntdll", loaded at 77F40000h - 77FEE000h
Symbol: "RtlReAllocateHeap" (+00000BDFh)
Address: 77F7E397h, location: "ntdll", loaded at 77F40000h - 77FEE000h
Symbol: "RtlReAllocateHeap" (+00000D4Fh)
Address: 77F7E3C3h, location: "ntdll", loaded at 77F40000h - 77FEE000h
Symbol: "RtlReAllocateHeap" (+00000D7Bh)
Address: 0044005Ch, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 006B006Fh, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal712" (+0002ABAAh)
Address: 006D0075h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 00650074h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal7" (+00038180h)
Address: 00750020h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 0064006Eh, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal7" (+0002817Ah)
Address: 00450020h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 00740073h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 006C0065h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal712" (+0003ABA0h)
Address: 0075006Ch, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 0067006Eh, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "ShellHookProc" (+0000CAE4h)
Address: 0048005Ch, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 00690065h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal712" (+0000ABA0h)
Address: 007A006Eh, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 004C0020h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 0061004Dh, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "SHFindFiles" (+0000002Ah)
Address: 0041005Ch, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 0077006Eh, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 00750064h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 00640073h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal7" (+0002817Fh)
Address: 00740061h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 77F41C78h, location: "ntdll", loaded at 77F40000h - 77FEE000h
Address: 004B895Ch, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 0048842Eh, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004B90FCh, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 00403535h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004075EBh, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004075F8h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 0049BC8Ah, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 00487FA3h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004B4080h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 10002D67h, location: "shared", loaded at 10000000h - 1002A000h
Address: 004A30F3h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004289C7h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004D37B0h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 0048B299h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004866B7h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004866B1h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004A893Ch, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004A7000h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004D6C48h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 0048B590h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004A3208h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 0048AA74h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 70A9F849h, location: "SHLWAPI", loaded at 70A70000h - 70AD6000h
Symbol: "Ordinal125" (+00000027h)
Address: 77E6141Ah, location: "kernel32", loaded at 77E40000h - 77F38000h
Symbol: "GetCurrentDirectoryW" (+00000044h)
Address: 77E7B2E5h, location: "kernel32", loaded at 77E40000h - 77F38000h
Symbol: "SetThreadExecutionState" (+00000097h)
Address: 77E77CE0h, location: "kernel32", loaded at 77E40000h - 77F38000h
Symbol: "VerSetConditionMask" (+0000D764h)
Address: 0048AADDh, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 0057005Ch, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal744" (+00001CB4h)
Address: 004E0049h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 004F0044h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal517" (+00000044h)
Address: 00530057h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal702" (+00000961h)
Address: 005C0073h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "ShellAboutA" (+0000072Ah)
Address: 0069004Dh, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal712" (+0000AB88h)
Address: 0073006Fh, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 0066006Fh, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal211" (+000085C9h)
Address: 00690057h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal712" (+0000AB92h)
Address: 0077006Fh, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 00790053h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 006D0065h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 006F0043h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 0070006Dh, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 00620069h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal7" (+00008175h)
Address: 0065006Ch, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal7" (+00038178h)
Address: 0070002Ch, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 006F0072h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 00650063h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal7" (+0003816Fh)
Address: 00730073h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 0072006Fh, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 00720041h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 00680063h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal715" (+0000159Eh)
Address: 00740069h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 00630065h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal7" (+00018171h)
Address: 00750074h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 00650072h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal7" (+0003817Eh)
Address: 00620075h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal7" (+00008181h)
Address: 0069006Ch, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal712" (+0000ABA7h)
Address: 004B0063h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 00790065h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 006F0054h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 0065006Bh, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal7" (+00038177h)
Address: 003D006Eh, location: "foo_abx", loaded at 003C0000h - 003F4000h
Address: 00620035h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal7" (+00008141h)
Address: 00630034h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal7" (+00018140h)
Address: 00660063h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal211" (+000085BDh)
Address: 00640031h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal7" (+0002813Dh)
Address: 0074002Ch, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 003D0065h, location: "foo_abx", loaded at 003C0000h - 003F4000h
Address: 00770022h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 00650076h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal7" (+00038182h)
Address: 00730072h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 006F0069h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 00530022h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal702" (+0000092Ch)
Address: 00730079h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 00650044h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal7" (+00038150h)
Address: 00610066h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "SHFindFiles" (+00000043h)
Address: 006C0075h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal712" (+0003ABB0h)
Address: 0074006Eh, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 00640047h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal7" (+00028153h)
Address: 00500069h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal517" (+00010069h)
Address: 00720070h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 0063006Fh, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal7" (+0001817Bh)
Address: 00730065h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 006F0073h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 00410072h, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 00630072h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal7" (+0001817Eh)
Address: 00690068h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal712" (+0000ABA3h)
Address: 00740063h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 00720075h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 00780022h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 00750070h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 006C0062h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal712" (+0003AB9Dh)
Address: 00630069h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal7" (+00018175h)
Address: 0065004Bh, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal7" (+00038157h)
Address: 00540079h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "SHCreateShellFolderView" (+00001B70h)
Address: 00630063h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal7" (+0001816Fh)
Address: 00660064h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal211" (+000085BEh)
Address: 00790074h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 00650070h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal7" (+0003817Ch)
Address: 00690077h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal712" (+0000ABB2h)
Address: 0076002Ch, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 00720065h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 00690073h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal712" (+0000ABAEh)
Address: 005C0053h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "ShellAboutA" (+0000070Ah)
Address: 0069006Eh, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal712" (+0000ABA9h)
Address: 00650066h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal7" (+00038172h)
Address: 005F0036h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "CDefFolderMenu_Create2" (+000081C8h)
Address: 005F0073h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "CDefFolderMenu_Create2" (+00008205h)
Address: 0077002Dh, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Address: 005F0077h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "CDefFolderMenu_Create2" (+00008209h)
Address: 00640065h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal7" (+00028171h)
Address: 004D002Eh, location: "foobar2000", loaded at 00400000h - 004E6000h
Address: 00660069h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal211" (+000085C3h)
Address: 006C0064h, location: "SHELL32", loaded at 004F0000h - 00CF4000h
Symbol: "Ordinal712" (+0003AB9Fh)
Version info:
foobar2000 v0.9.2
UNICODE
Additional info:
Pause on Lock (extended) 1.0  (foo_lock_ex)
Track info panel mod 0.8  (foo_uie_trackinfo_mod)
Standard input array 1.0  (foo_input_std)
Shell link resolver 1.1  (foo_lnk)
Play Count 1.9.2  (foo_playcount)
foo_lyricsdb 0.0.7 beta 3  (foo_lyricsdb)
Lyric Show Panels 0.3.0.0  (foo_uie_lyrics)
Explorer Tree 1.04.6b  (foo_uie_explorer)
cwbowron's hooks 1.0.1 [Apr 13 2006 - 14:30:00]  (foo_cwb_hooks)
Components versions viewer 0.3  (foo_version)
Masstagger 1.5  (foo_masstag)
Live show tagger 0.6.1  (foo_tradersfriend)
Playlist Manager 1.0  (foo_playlist_manager)
Playlist tools 0.5.7  (foo_utils)
ReplayGain Scanner 2.0.1  (foo_rgscan)
projectM visualization 1.97.6.2  (foo_vis_projectM)
CD Audio decoder 2.1  (foo_cdda)
Album Art Panel 0.164a  (foo_uie_albumart)
foo_managedWrapper 0.3  (foo_managedWrapper)
Well, I installed, changed nothing, and ran it !!
(---> Looks great & should fit exactly what I searched for ...!!)
- I choosed a folder with music and "inserted" it, created new PL or replaced the current PL via its context menu ... worked all well !!
- But when it comes to play a song added in one of these 3 ways, FB crashes with the log to see above.
-Of course it does not happen when i drag&drop SAME folder to FB from the real Explorer in the way I used to do before.
Reply #272
Could you add "Lost Focus Text Color", "Lost Focus Background Color" and "Frame Selection Color" to Color settings in this plugin? Same like it is done in Columns UI. I need to set up different colors (not only inverted) when it is not focused.
Reply #273
JackieKu, could you please add option to show icons only for folders?
and i've found bug / issue. dynamic file icons are not displayed and files show only using generic icons. i'm talking about dynamic bitrate icons like those provided by MP3-Info Extension . could you please resolve this issue? thanks!
Reply #274
Noone else wanting additionally a non tree layout? The problem with a tree view is, it soon runs out of the window. A flat structure with just one directory level (like clicking through total commander or the explorer window without tree) would be nice.
I've seen a bug. If a file in a directory is accessed by another write process and you read the directory with foo_uie_explorer, the foobar2000 progress bar, which shows the metainfo read process, appears twice. But after the second run the playlist gets empty, will not be populated with the folders contents.
