Topic: -V2 vs. -V0 and lowpass filter (Read 2481 times) previous topic - next topic
hi there,
I wonder why --preset extreme (-V0) uses a higher lowpass than --preset standard (-V2). I mean, the goal of -V2 is to be transparent and for the few cases where it isn't I doubt it has something to do with a too low set lowpass.
There are samples where -V0 sounds better than -V2, but isn't -V0 basically just -V2 with a higher lowpass? Since high frequencies need a lot of bandwith I wonder if there's a sample where -V1 or maybe even -V2 sounds better than -V0...
Another thing I've always wondered about is why some --preset CBR 192 file uses a lowpass of 19.5khz or --preset 192 lowpasses at 19.6khz...isn't that a bit too much? -V2 lowpasses at 19.0khz and has pretty much no restriction how much bits it can use... in opposite to some 192 CBR/ABR file..., besides that it's set up to be transparent...
thanks
Try comparing the details --verbose shows from the commandline.
imbo, its possible but very marginaly so.
Its certainly too high a lowpass for me, but this is HA.
Plenty of reason for me to use the --lowpass switch.
CBR rates are setup to be as transparent as possible too, and at 192 kbs the bit reservoir will be filling up like crazy, only getting empty occasionaly or when things get really tough. With all the finely tuned psychocode methods employed, thats the lowpass 192 has been observed to be able to handle -anything less is a bonus then  .
no conscience > no custom
The behaviour regarding sfb21 is different in cbr/abr and in vbr. Cbr/abr behaves like vbr with -Y.
