Topic: Streaming Audio (Read 4614 times) previous topic - next topic
Streaming Audio
A friend of mine is trying to start a site, where various new groups would be able to present their creative talent...something like a mini mp3.com. He decided to use OGG -q0 for downloading the actual song, but he haven't made his mind yet about the streaming format that would be more suitable for the case (actually he leans towards RA, even though I have tried to discourage him). The streaming audio should be around 20Kbps, so I need your suggestions as the best format for the case...the one that will offer the best quality and will be easy to set up as well. RA wouldn't be that bad, if the user didn't have to download Real Player, the synonym of bloatware...
So what do you think?
Streaming Audio
I recently played a bit with oggenc to produce low bitrate streams, i was trying to make a stream under 24kbps and another under 56kbps, so far the best two i could come with are:
(mono under 24kbps):
oggenc -b19 --resample 16000 --downmix --advanced-encode-option lowpass_frequency=8
(stereo under 56kbps):
oggenc -b50
Because the low bitrates are being tuned, i hope to get much better quality with future releases
I'm sure my command lines aren't very good, and i'm playing with the lowpass knowing that some extra noise in the higher freqs sometimes, kinda, makes people feel that it sounds better (other people can't stand the noise).
Of course i'm willing to accept better ideas
Some other crazy stuff i did with interesting results:
-b12 --downmix --resample 12000 --advanced-encode-option lowpass_frequency=6 (17kbps)
-b16 --downmix --resample 16000 --advanced-encode-option lowpass_frequency=8 (19kbps)
Stereo for the cheap
-b30 --resample 22050 --advanced-encode-option lowpass_frequency=11,025 (32kbps)
-b24 --resample 16000 --advanced-encode-option lowpass_frequency=8 (27kbps)
-b16 --resample 12000 --advanced-encode-option lowpass_frequency=6 (22kbps)
RA no matter what, sounds very ugly to me... Even lowbitrate mp3 was better.....
She is waiting in the air
Streaming Audio
Ogg aint the best for streaming audio.
Mp3 and Wma are much better in that.
Only if you are talking about DSL streaming then OGG's quality of sound begins to become atractive!
Ogg is good...but not on qualities under 92k
Streaming Audio
vorbis outperforms wma and mp3 at lower bitrates....
Streaming Audio
Question is....what quality OGG do you need to have reasonable radio and stil have a small streams!
Yes...Ogg uses smaller streams.....
In a certain way they will be very usefull.
Ya know by the way that MediaJukeBox supports streaming, people only have to login into your MediaJukeBox server ( with media juke box ) and they can choose and listen to any song of your mediatheek!
Streaming Audio
who uses MMJB ?
Streaming Audio
and vorbis is THE format for low bitarte streams in regards to quality i you ask me
Streaming Audio
who uses MMJB ?
Thousands and thousands of newbies.
Don't try to judge the average computer user by the visitors of this forum, Benjamin.
Streaming Audio
yeah, i forget this quite often
Streaming Audio
who uses MMJB ?
Mmm, I do ofcourse...
Hey..it's a great full package. and IF I ever need a new function there is a big chance it's already programmed by JimH
It just rocks.
And oh yes...it's not for oldtimers no.....you just keep working with your little .pls files!
Streaming Audio
who uses MMJB ?
MMJB = MusicMatch JukeBox
MJ = Media Jukebox
As far as I know, JimH has nothing to do with MMJB.
Streaming Audio
who uses MMJB ?
MJ = Media Jukebox
My Fault!
I self never used Music Match
Streaming Audio
Check out this thread.
You will be able to stream at 8kbps
Yeah, I've followed that thread right from its beginning, but at the moment only Garf is able to produce those low bitrate files...hope we all have the chance to use its tweakings soon.
Artemis3: Thanks for the suggestions...I'll try them out and see if they offer the desired results when it comes down to quality.
Streaming Audio
You can produce good quality files down to 8-12kbps with the standard Vorbis libs. My hack is only usefull if you need to go still *below* that, which hopefully isn't the case for pratical applications.
Try for example
oggenc -q -1 --resample 8000 --downmix, which should give you 10-12kbps files IIRC.
