Topic: Azrael (Read 297399 times) previous topic - next topic
Azrael
Azrael 5.6.6 Released
See first post for changelog!
Enjoy!
Neksus, when will be released Azrael mod for Column UI 0.1.3-pre-alpha10 (for foobar2000 0.9beta3). 5.6.6 not works
Azrael
[a href="index.php?act=findpost&pid=299717"][{POST_SNAPBACK}][/a]
Well just for the beta people,
I will install 0.9 beta and make a version that works give me a day or so!
[edit]
You can use it with some small errors by
enabling both Use global variables for display and Enable legacy support
under Columns UI -> Playlist view -> Globals
[/edit]
neksus
Azrael
Deleted
Azrael
simple, usable and really quick release =)
just one request, could you add %artist album% detection for various artists albums ?
Azrael
[a href="index.php?act=findpost&pid=299873"][{POST_SNAPBACK}][/a]
Was that what you wanted? (look in above post!)
neksus
Azrael
well, for me, if there is an album has the %album artist% tag (and whatever it's containing), it means it's a various artists album (otherwise we would use the standard %artist% tag).
i personnaly use "various artists" for standard va albums or the artist name for electro mixes and such (eg carl cox, jeff mills ...).
edit: forgot to thank you for the update
Azrael
New update to Azrael Light see above post!
neksus
Azrael
Reply #32
the columns at the top of the playlist disappeared on this version, anyone know how to fix it?
nm, managed to fix it
Azrael
great additions, azreal 5.5.6 and light
(zip file is broken for me..)
Azrael
Reply #34
Zip file is broken for me as well.  I'd love to test it
Azrael
Reply #35
[a href="index.php?act=findpost&pid=299972"][{POST_SNAPBACK}][/a]
[a href="index.php?act=findpost&pid=300045"][{POST_SNAPBACK}][/a]
Try to extract it in the different directory, and you'll get a zip file. Then extract it.
Azrael
Reply #36
I have added a 7-zip file, hopefully this works for the people having zip-file problems!
neksus
Azrael
Reply #37
I used 7zip / winrar /total commander unpackers, but none can unpack it. why don't you post fcs file instead? please:) ....and where can I find and download "column_ui 1.3 pre-alpha 10"? thx
Azrael
Reply #38
Neither the .zip file nor the 7-zip file works here
Azrael
Reply #39
Disabled Album Artist = is_various and changed to if Album Artist then Various (I need this tested please!)
it works =)
thx Neksus
edit : i talked too soon, when i enable the option, every album (even single artist ones) takes the va album scheme.
Azrael
Reply #40
it works =)
thx Neksus
[a href="index.php?act=findpost&pid=300089"][{POST_SNAPBACK}][/a]
In the Vaious part of globals change %album artist% for %track artist%
// Various
$if($or(%various%,%va%,$and(%track artist%,$greater($len($trim(%album artist%)),0)),%performer%),is_various=1,
$if($stricmp($substr(%_directoryname%,0,5),'VA - '),is_various=1,
$if($stricmp($substr($directory(%_path%,2),0,5),'VA - '),is_various=1,
$if($strstr($upper(%_directoryname%),'VARIOUS ARTISTS'),is_various=1,
$if($strstr($upper($directory(%_path%,2)),'VARIOUS ARTISTS'),is_various=1,
$if($stricmp($substr(%_directoryname%,0,$len2($get(Various-Artists_indicator))),
$get(Various-Artists_indicator)),is_various=1,
$if($stricmp($substr($directory(%_path%,2),0,$len2($get(Various-Artists_indicator))),
$get(Various-Artists_indicator)),is_various=1,$if($strcmp(1,$get(dalbum)),
$if($stricmp(%_directoryname%,%album%),is_various=1)))))))))
Maybe more things need to be change due new remapping in tag but it works me
Edit: This work for old versions. I didn't see the new
Azrael
Reply #41
[a href="index.php?act=findpost&pid=300074"][{POST_SNAPBACK}][/a]
Because you can't post fcs files on this board!
Download 1.3 pre-alpha from the columns_ui thread!
[a href="index.php?act=findpost&pid=300087"][{POST_SNAPBACK}][/a]
This is really annoying!
But other people seem to be using it just fine,
and I have no problem either!
I going with: it is a problem on the user side!
neksus
Azrael
Reply #43
Deleted!
Azrael 5.7 is coming to foobar2000 0.9 and columns_ui 1.3
Currently planed
[span style='font-size:8pt;line-height:100%']Smaller, simpler color schemes (I hope to convert all current schemes)
No use for the Legacy option in columns_ui
Some options removed
A lot of recoding
New defaults for options (on / off will be different from 5.6.6)
Design changes
Implementing of some Azrael Light codes[/span]
Azrael
Reply #44
There is some problem with IPB which corrupts archived files. There are some alternatives like rapidshare.de and yousendit.com
Azrael
Reply #45
I finally got the archived file to work. The process is interesting, and does not work in Firefox (to my knowledge). You have to have this page open in IE. Anyway, save the file in IE.  It will say index.php (if you have show all extensions enabled); rename it to the correct file name, and it should work properly.
Azrael
Reply #46
[a href="index.php?act=findpost&pid=300795"][{POST_SNAPBACK}][/a]
[a href="index.php?act=findpost&pid=300828"][{POST_SNAPBACK}][/a]
I can download the file just fine and use it just fine!
I use Opera 8.01 Preview 1.
neksus
Azrael
Reply #47
neksus
[a href="index.php?act=findpost&pid=300830"][{POST_SNAPBACK}][/a]
Tried all three browsers with no luck. I remember uploading foo_msn after repairing with WinRAR while the file worked for me (maybe was in my cache) it did not work for others. Sadly my WinRAR has expired and I cannot repair the archive any longer
Azrael
Reply #48
[a href="index.php?act=findpost&pid=300871"][{POST_SNAPBACK}][/a]
I have added direct download links for both Azrael 5.6.6 (1.3 pre-alpha release) and Azrael Light 1.0 beta!
But please only use them if you are having problems with the 7z files!
Best regards,
neksus
Azrael
Reply #49
New to Foobar here, but I love your azrael setup. I want to know how to set up an album art box like you have in your screenshot. I have cover art ready. Am I mising a plugin, or what code do I need to use?
--thnx
