Topic: Azrael 5.8 (Read 321389 times) previous topic - next topic
Re: Azrael 5.8
Reply #175
i can't figure out why i always get a "?" after every track
Azrael 5.7 RC6, foobar 0.9 final and columns UI 0.1.3 pre-alpha 17v6
[{POST_SNAPBACK}][/a]
I have the same thing. a question mark after each song title unless it is the now playing track.
[a href="http://imageshack.us][/url]
Re: Azrael 5.8
Reply #176
[a href="index.php?act=findpost&pid=376667"][{POST_SNAPBACK}][/a]
...Set myself on fire?
Re: Azrael 5.8
Reply #177
Hello!
I downloaded Azrael and I also have the latest version of Columns_UI (0.1.3 pre-alpha 17v6) and foobar 0.9, but when I import the latest Azrael I get the whole playlist to be black.
It worked great with foobar 0.8.3 and older versions of Azrael, but not the newest. Has anyone else had this experience and what should I do to solve this? I really love the Azrael config otherwise.
[a href="index.php?act=findpost&pid=376609"][{POST_SNAPBACK}][/a]
I had the same problem originally. Try:
Columns UI > Playlist View > Globals - check "Use Global Variables for Display"
HTH
Sorry, I have nothing witty to say here.
Re: Azrael 5.8
Reply #178
Hello!
HTH
[a href="index.php?act=findpost&pid=376713"][{POST_SNAPBACK}][/a]
hey thanks, it worked fine!
Re: Azrael 5.8
Reply #179
I had the wrong version. All better now.
Nic
Re: Azrael 5.8
Reply #180
It is possible to download old versions of Azrael where you can try to figure out what to work with. I'm affraid design changes normally are permanent on my part sry
[a href="index.php?act=findpost&pid=376537"][{POST_SNAPBACK}][/a]
Yes, well, unfortunately old versions don't work on fb2k 0.9.  Thanks a lot!
Liberate tutemae ex inferis
Re: Azrael 5.8
Reply #181
@neksus:
can this code be updated using the new .9 variables for playcounts?
.9 has Playback Statistics which
Collects statistics about tracks from your Media Library being played. Statistics can be displayed using %last_played% and %play_count%, or using a context menu command.
If you could update playcount column code using the new variables, that would be awesome.
Re: Azrael 5.8
Reply #182
@neksus:
[a href="index.php?act=findpost&pid=376784"][{POST_SNAPBACK}][/a]
The latest version already supported the %last_played% tags!
I have just released a silent update where the playcount column has been updated to use %play_count%.
Enjoy!
Re: Azrael 5.8
Reply #183
hey neksus
i love your config
i was wondering if you can change something though
i have a few va albums that are 2 discs ie main dir va-blah blah, sub dir disc1,disc2
and when that happens the artist column no longer display "Various Artists" instead it displays the first track's artist.  is there anyway to change that?
i would also like to ask how i can add the codec information on the in the artist column track 3. as of right now it's
track 1 showing artist tab(10) genre
track 2 showing album tab(10) year
i would like
track 3 to show the codec information
best option would be to let ppl pick where they want their info tho
but i'm sure that's a lot of extra coding ;p
you help would be much appreicated 8)
Re: Azrael 5.8
Reply #184
I have this same problem =/
Does any1 know solution to this issue?
~JzE
Re: Azrael 5.8
Reply #185
~JzE
[a href="index.php?act=findpost&pid=377224"][{POST_SNAPBACK}][/a]
Download the latest version. [a href="http://foobar.nub4life.net/columns/pafiledb.php?action=file&id=151]http://foobar.nub4life.net/columns/pafiled...ion=file&id=151[/url]
Then it will be all better.
Nic
Re: Azrael 5.8
Reply #187
I have a problem like the multifate one, a few posts above.
I would like to add a new line with information below the artist/genre and album/date  lines
In my 0.8.3 config I had this: http://img375.imageshack.us/img375/9431/836by.jpg
And now in 0.9 this: http://img410.imageshack.us/img410/7716/905zc.jpg
Could any one give any info on where should I make changes?
I would also appreciate some guidance on this. I cannot figure out what to change in the artist column...
Re: Azrael 5.8
Reply #188
[attachment=2154:attachment]
in my various artist albums, i get lines under tracks in the single digits. is there something wrong with my tags?
tags used:
album  <-- all the same
album artist  <-- all the same
artist  <-- changes
genre <-- changes
title <-- changes
tracknumber <-- changes
date <-- changes
Re: Azrael 5.8
Reply #190
sorry I will close the whole site in some weeks
I removed 0.9 configs because I don't want to attract any more users to it
You can still get the config since the download is from Neksus site:
http://neksus.dk/foobar/beta/azrael.fcs
the download for the light config is:
http://neksus.dk/foobar/light.fcs
Re: Azrael 5.8
Reply #191
Thank you, Azrael. I don't have time for learning scripting, and I like your scripts, so this update is more than welcome.
H.
TAPE LOADING ERROR
Re: Azrael 5.8
Reply #192
It seems that it doesn't read the playcount, but it does display the last time played in the statusbar I'm using Foobar 0.91...
The tags are there:
PLAY_COUNTER = 82
By the way:
Does anybody have a luna element 5 black color scheme for azrael?
Re: Azrael 5.8
Reply #194
Any chance of updating to v.9.1?  I'm getting the artist in the title column for some reason for albums...
Just change the following line in Globals -> Variables:
// Various
$if($or(%various%,%va%,$and(%album artist%,$greater($len($trim(%album artist%)),0)),%performer%),is_various=1,
That it looks like this:
// Various
$if($or(%various%,%va%,$and($meta(album artist),$greater($len($trim($meta(album artist))),0)),%performer%),is_various=1,
As you can see %album artist% is exchanged to meta(album artist). So if %album artist% is not set, it will not return %artist%
You can also try this fcs. It's Azrael, but slightly changed by me.
Cya(o)
      Rainer
Re: Azrael 5.8
Reply #195
Does azreal support 3 digit tracknumbers?
i have a various artist album of the top 500 songs according to rolling stone mag. for some reason the tracks 001-009 have lines underneath them. i looked at their tags and nothing looks abnormal.
Re: Azrael 5.8
Reply #197
Azrael 5.8 released
Please check first post for download, screenshot and changes!
Enjoy & best regards,
Neksus
Re: Azrael 5.8
Reply #198
Thank you, Neksus! I use your basic colour scheme and I really like it. It is very light and easy on the eyes.
Re: Azrael 5.8
Reply #199
Azrael 5.8 released
Neksus
Thank you! Azrael is amazing - I styled my whole desktop look around the XPMC style - I downloaded the VS to match the fcs!
