Topic: Azrael (Read 297895 times) previous topic - next topic
Azrael
Reply #100
Azrael
Reply #101
Stupid question....  And I swear I tried to figure it out on my own and tried to find the answer before I asked:
How do I pick my color scheme in azrael?  I can't figure it out for the life of me.  I've gone into globals and I don't have the first clue what to do from there.[a href="index.php?act=findpost&pid=312369"][{POST_SNAPBACK}][/a]
Under Globals look for $puts(color_scheme,x) and change x to the color scheme you want!
As illustrated in the picture above my post!
Azrael
Reply #102
[a href="index.php?act=findpost&pid=312470"][{POST_SNAPBACK}][/a]
Thanks dude.
Azrael
Reply #103
Deleted!!!
New post: here
Azrael
Reply #104
Single tracks with tracknumber 1 still seem to get a line drawn above them. I don't think that this is intended bahaviour, is it?
Thanks for your efforts!
The Link
Azrael
Reply #105
The Link[a href="index.php?act=findpost&pid=314045"][{POST_SNAPBACK}][/a]
Sorry forgot that bug! Try downloading again, it should be fixed now!
Azrael
Reply #106
The line above the artist is gone but above the other fields it still seem to be there.
Azrael
Reply #107
The line above the artist is gone but above the other fields it still seem to be there.[a href="index.php?act=findpost&pid=314052"][{POST_SNAPBACK}][/a]
What other fields? (screenshot?)
Azrael
Reply #108
The line above the artist is gone but above the other fields it still seem to be there.[{POST_SNAPBACK}][/a]
[a href="index.php?act=findpost&pid=314055"][{POST_SNAPBACK}][/a]
See [a href="http://beingalink.de/temp/azrael.png]here[/url].
Azrael
Reply #109
What other fields? (screenshot?)[a href="index.php?act=findpost&pid=314055"][{POST_SNAPBACK}][/a]
See [a href="http://beingalink.de/temp/azrael.png]here[/url].[a href="index.php?act=findpost&pid=314057"][{POST_SNAPBACK}][/a]
When I add singletrack tag to tracks with tracknumber 1 I get this!
[removed screenshot]
Azrael
Reply #110
[a href="index.php?act=findpost&pid=314070"][{POST_SNAPBACK}][/a]
I don't use singletrack indicator tags! I just activate "singletrack if no album_gain".
Azrael
Reply #111
When I add singletrack tag to tracks with tracknumber 1 I get this![a href="index.php?act=findpost&pid=314070"][{POST_SNAPBACK}][/a]
I don't use singletrack indicator tags! I just activate "singletrack if no album_gain".[a href="index.php?act=findpost&pid=314071"][{POST_SNAPBACK}][/a]
Aha, now it is fixed! Just redownload! That teaches me to test my own options!
Azrael
Reply #112
I just managed to fix it myself but your solution is probably cleaner (problem seemed to be the usage of %singletrack% at various places instead of using %is_single%).
One last thing: The end lines (at the end of a playlist) have little spaces where the left and right border colums of the tracknumber column are when the last track of the playlist is a single track (if the last track is part of an album it looks OK).
Thanks for your patience!
The Link
Azrael
Reply #113
The Link[a href="index.php?act=findpost&pid=314078"][{POST_SNAPBACK}][/a]
I have that fixed as well! Redownload!
Azrael
Reply #114
[a href="index.php?act=findpost&pid=314092"][{POST_SNAPBACK}][/a]
edit:
I just realized that the last and first track of a playlist are supposed to have a line. While the last track now always has a correct line, the first doesn't have any at all if it is a single track (works correctly with the first track being an album track).
Azrael
Reply #115
Update!
Azrael
Reply #116
Is there any way to make any song that is not in a complete albumset just go to the bottom or top of the playlist? I'd like single songs that have been downloaded to just pool at the bottom of the playlist so that they dont get in the way of the actual album groups. Thanks.
Azrael
Reply #117
Is there any way to make any song that is not in a complete albumset just go to the bottom or top of the playlist? I'd like single songs that have been downloaded to just pool at the bottom of the playlist so that they dont get in the way of the actual album groups. Thanks.[a href="index.php?act=findpost&pid=318352"][{POST_SNAPBACK}][/a]
To the best of my knowledge yes that is possible! But you need to code some sorting string to do that!
Azrael
Reply #118
[a href="index.php?act=findpost&pid=318366"][{POST_SNAPBACK}][/a]
Hmmm, unfortunately, I dont know how to code that. I'll ask in another thread. Thanks.
Azrael
Reply #119
Well look at the first post!
Azrael
Reply #120
hello,
im new to this. i downloaded the 5.7RC4 azrael.fcs file and i dont know what to do with to get the it working.
i worked out i had to import it.
thhx
Azrael
Reply #121
i worked out i had to import it.[a href="index.php?act=findpost&pid=319971"][{POST_SNAPBACK}][/a]
Have you done this?
1. Install Columns UI plugin
2. Foobar2000 -> Preferences -> Display -> User Interface Module -> Columns UI
3. Restart foobar2000
Azrael
Reply #122
Azrael 5.7 RC4.1 released!
Added Thunder Storm color scheme!
Some color schemes have been changed!
Updated Documentation to 5.7!
Moved to first post!
Azrael 5.6.6 still exists!
Azrael
Reply #123
I updated to your latest version and now I have some problems again. See here.
Singletracks with tracknumber 1 or 2 (don't know if also others) get that line drawn and the last track in a playlist doesn't have a complete line below (also in album mode).
Again: singletrack if no album_gain and singletrack if no album tag is activated
Otherwise nice theme additions!
Regards,
The Link
Azrael
Reply #124
hehe i have the same problem.
