Topic: ReplayGain + foobar2000: Automatic? (Read 2502 times) previous topic - next topic
If a file as RG info, does fb2000 automagically play it with the adjusted gain? Or do I have to configure something? I've done my best w/ exploring, the foobar FAQ, and searching this forum, but I can't find a direct answer.
I'm trying to level out the volume of a playlist I want to put on my iPod shffule (soon to be foo_pod shffle if i like it...), but before i do the necessary conversions, i want to know that it's working.
[eric]dfields.net
workItHarder makeItBetter doItFaster makesUsStronger moreThanEver hourAfterOur workIsNever over
[a href="index.php?act=findpost&pid=291105"][{POST_SNAPBACK}][/a]
Replaygain configuration is on the Playback page, you can check if its disabled, use album gain, or use track gain, you can also change the preamp for rg and non rg files.
And there's a Processing section in the Diskwriter options where you can tick Use ReplayGain so it will be used when you convert your files.
