Topic: LUA dll's (Read 2843 times) previous topic - next topic
LUA dll's
Sorry if my english is not good, I'm french. I look for LUA dll's (in order to use skins) but the link on the forum does not work.
Have you got it ?
Thanks very much
LUA dll's
foo_looks 2.1 doesn't need lua dlls anymore
LUA dll's
arf, I use " foo_looks_2.1.zip " and I have an error when I start Foobar : MSVCR71D.dll is not found. Try to reinstall this application.
I reinstall Foobar but I have always this message.
Then the console says me :
INFO (foo_looks) : Initializing GDI+
INFO (CORE) : startup time: 69078 ms
ERROR (CORE) : Failed to load DLL: foo_ui_gfx_debug.dll, reason: Unable to load DLL.
What must I do ?
LUA dll's
Remove foo_ui_gfx_debug.dll, you probably don't need it anyway (there's still the regular version foo_ui_gfx.dll). It requires the debug version of the C runtime which is not installed on your machine.
