Topic: Unable to avoid clipping (Read 3325 times) previous topic - next topic
Hello.
From times to times, i get clipping with foobar.
I don't understand why:
- my tracks have RG info
- "use peak info to scale down tracks that still clip after applying replaygain" is checke
- i use  the advanced limiter
These settings should be overkill, and i should not get clipping, or at least i think so.
Who has an idea ?
Do you hear clipping or do you get clipping warnings in the console output?
I'm also using the advanced limiter and I never get clipping warnings in the console. But that doesn't mean that there cannot be any distortion in the music you hear if the recording/mastering was horrible. In such cases nothing can help you (afaik).
I hear clipping, and i see it in patchmix (sound card mixer). However, i'm unable to see the console since i disabled it one day, and i'm unable to find the way to enable it again  .
I think the console component is part of every installer available.
is the limiter at the end of the DSP-chain, or are other DSPs *after* the limiter? (the order does matter)
- Lyx
If it sounds like crackling then mute all the outputs & inputs that you don't use and lower the volumes in your driver.
[a href="index.php?act=findpost&pid=290581"][{POST_SNAPBACK}][/a]
From the menu (hope you still have that  ) components -> Show console ?
Else reinstall.
- Lyx
[a href="index.php?act=findpost&pid=290589"][{POST_SNAPBACK}][/a]
It's in the last position of the dsp chain.
