Topic: Sidebar color, and foobar won't close (Read 3597 times) previous topic - next topic
Hey, I'm new to foobar and I have a few problems.
The first is that its pretty tricky to use these forums, the default search form tells me to wait 20 seconds to search, many minutes after my last search.  And for some strange reason, I can't use my gmail account?
Second, I can't change the color of my sidebar where my playlists are listed.  The main window color is exactly what I want it to be, but the sidebar refuses to change.
Finally, foobar won't close when i tell it to close, it just hangs as a system process until i tell it to close from the task manager.
1. If you're nice, an admin might change your email address to your gmail address. And that's if you're nice and ask nicely
2. Works well here. Are you sure you're changing the correct option?
3. Most likely answer: delete foo_tunes.dll
I'm using the Navigator 1.2 theme, and when I change the color presets, it doesn't change the color for the sidebar, and the bottom half of my playlist background color doesn't change.
[a href="index.php?act=findpost&pid=289862"][{POST_SNAPBACK}][/a]
I don't have a foo_tunes.dll.
[a href="index.php?act=findpost&pid=289872"][{POST_SNAPBACK}][/a]
Navigator and all other config (even multi color scheme) have only one sidebar color, because we can't specify that from Title formatting.
But you can adjust sidebar color by "Playlist switcher panel display settings", and your playlist background by "Playlist view display settings".
[a href="index.php?act=findpost&pid=289883"][{POST_SNAPBACK}][/a]
Ah, thanks a bunch, that worked!
Now to fix this issue of not being able to close foobar...
[a href="index.php?act=findpost&pid=289889"][{POST_SNAPBACK}][/a]
A list of plugins that you have installed would be helpful.  Or take a glance at the "problematic components" thread to see if you have one of those installed.
[a href="index.php?act=findpost&pid=289892"][{POST_SNAPBACK}][/a]
I have all of them.  I just downloaded the 'special' installer and it wouldn't close as it is.  I haven't installed any extra.
