Topic: WavPack 4.2 released (Read 70751 times) previous topic - next topic
WavPack has a new site design (thanks to Ariakis and Roberto) and version 4.2 has been released with the following enhancements:
  • new option (-i) added to ignore length in header of wav files (for foo_clienc and CDex)
  • new option (-w) added to write APEv2 tags from command-line (including cuesheets)
  • bug fixed that caused problems with wav files over 2 gigabytes (new limit: 4 gig)
  • improved encoding and decoding speeds in common modes (16-bit, stereo)
  • added winamp media library support to winamp plugin
  • added mode to decoding library for streaming support
  • updated source code to compile on 64-bit machines
http://www.wavpack.com
To everyone who contributed to this release and to everyone who uses and supports WavPack:  Thanks!
Wow, great!
Keep up the good work, bryant!
WavPack iz da best!
Thank you!
Great! Thanks Bryant.
You might want to add VUPlayer http://www.vuplayer.com to your list of WavPack supporting players. I am not sure if the author of that player knows about your 4.2 update. He is pretty good about including updates, if you let him know.
Impressive, as every update so far. Thanks for your work, bryant.
Good news. Thanks Bryant.
daefeatures.co.uk
Yay!
Just for kicks and giggles, I uploaded a Solaris SPARC compile of WavPack 4.2 to RareWares. Hopefully soon, Kuniklo will provide a MacOS X compile.
Regards;
Roberto.
Thank you very much!
Beautiful. Thank you!
BTW. Are Kuniklo's XMMS plugin getting mature enough for the regular user now?
And would it in that case be useful to include it on WavPacks official site?
[a href="index.php?act=findpost&pid=289484"][{POST_SNAPBACK}][/a]
Thank you. WavPack is a great program - I like the new features- keep up the good work !
WavPack 4.2 binaries for Mac OS X uploaded here:
http://www.hydrogenaudio.org/forums/index....pe=post&id=1453
Feel free to host it at Rarewares.
[a href="index.php?act=findpost&pid=289568"][{POST_SNAPBACK}][/a]
Excellent! Thank-you very much.
Just uploaded it, and announced at the index page.
[a href="index.php?act=findpost&pid=289573"][{POST_SNAPBACK}][/a]
Page says
WavPack V.4.2b3 for MacOS X  2005-04-10
Guess that should be V.4.2 now....
As always your hard work on WavPack is very much appreciated bryant
Nero AAC 1.5.1.0: -q0.45
the new site layout is lightyears better than the older one IMO, much more appealing and way better structured, well done (finaly)
ah, and thx for the update
Nothing but a Heartache - Since I found my Baby ;)
Page says
You beat me on this one. They certainly are 4.2 (no beta) binaries...
Ooops. Fixed. Thanks for pointing that out.
Many thanks Bryant for this great codec.
If people is interested, Toff has made a new package of directshow filters (a splitter and a decoder) for wavpack and matroska files. It's not finalized yet but works fine with stereo files...even in WMP.
Status (2005-04-05) :
Alpha .wv splitter added, should works with lossless and hybrid file (autoload .wvc file if present)
24 bits PCM and 32 bits floats should now works.
More than 2 channels support not implemented yet.
Improved seeking from .mka file (require last Haali's Splitter version)
Any plans for a commandline replaygain scanner for Wavpack? A wvgain or wavpackgain or something?
[a href="index.php?act=findpost&pid=289553"][{POST_SNAPBACK}][/a]
The sporadic performance bug has been fixed, so I'd consider it at beta level now.
[a href="index.php?act=findpost&pid=289620"][{POST_SNAPBACK}][/a]
Yes. But it seems David plans to now prioritize ASM optimizations of some routines for several target platforms, at first M68K (for the iRiver RockBox) and TI DSP (for the Neuros).
But a replaygain scanner is definitely in his todo list
If people is interested, Toff has made a new package of directshow filters (a splitter and a decoder) for wavpack and matroska files. It's not finalized yet but works fine with stereo files...even in WMP.   [{POST_SNAPBACK}][/a]
[a href="index.php?act=findpost&pid=289624"][{POST_SNAPBACK}][/a]
Excellent! That warrants an update to the lossless comparision thread.
[a href="http://www.hydrogenaudio.org/forums/index.php?showtopic=29655]http://www.hydrogenaudio.org/forums/index....showtopic=29655[/url]
"Software support" for WavPack goes from "average" to "good".
If you want to test an even newer version is available here :
[a href="http://www.matroska.org/~toff/WavPackDS-20050410.zip]http://www.matroska.org/~toff/WavPackDS-20050410.zip[/url]
Status (2005-04-10) :
Added more than 2 channels support for splitter and decoder
Tested only with 5.1
