Topic: Can't load load foo_dbsearch properly (Read 2243 times) previous topic - next topic
Hi there all!
I'm experiencing a problem loading foo_dbsearch... There doesn't seem to be a selectable option in the "Components" dropdown box.
The plugin (foo_dbsearch) is loaded, there's the options available, database is enabled but I just nothing is being displayed (from both Components and the context menu).
Anyone knows what could be going on?
Have you tried adding the command menus by hand? (Go to Prefences/Core/Main menu items or Context menu items.) New commands arr normally added to the menus, but sometimes they are not, most likely when the component had been installed before.
[a href="index.php?act=findpost&pid=288655"][{POST_SNAPBACK}][/a]
Thanks... that solved the problem.
