Topic: Encoding with speex. (Read 2895 times) previous topic - next topic
Hello,
So I'm using speex to encode my data which I'm using for this program I'm building. At this point I have an unsigned char array holding my raw WAV data and I'm setting it up to pass to speex.
Now, based on the manual , the real encoding happens when I call speex_encode and speex_bits_write...
What I'm wondering... speex encode takes a float * as the input frame, I guess that isn't a problem because char * size = float * size. The issue I'm having is I don't pass in the size of MY raw data buffer anywhere ? is that size supposed to be the frame size ?
If I have this totally wrong, how do I pass in my raw data buffer to speex properly to encode and write to another buffer ? The docs unfortunately aren't too descriptive
Sorry if I'm too newbie
