Topic: Cannot tag mp3 or ogg files (Read 3149 times) previous topic - next topic
I'm no more able to tag files (mp3 or ogg). I'm using the special file infobox (foo_infobox). If I change a tag and click "update" it says: "error writing file info". This is definitely not about windows privileges. I rather think its because I cleaned up my components folder the other day (because of slow startup with some seconds of 100% CPU).
I think I've removed a necessary component?!?
This is what I removed, maybe someone might have a look:
foo_abx.dll 32.76828.06.2004 00:30-a--c
foo_ac3.dll 69.63224.04.2004 16:25-a--c
foo_albumlist.dll 34.30422.07.2004 01:00-a--c
foo_ape.dll 114.68829.06.2004 17:11-a--c
foo_apl.dll 24.57625.02.2004 20:29-a--c
foo_burninate.dll 36.86422.01.2004 22:46-a--c
foo_cdda.dll 33.79228.06.2004 00:30-a--c
foo_channel_mixer.dll 106.49623.12.2004 06:14-a--c
foo_convolve.dll 301.56803.04.2004 12:58-a--c
foo_dbsearch.dll 87.55213.06.2004 23:22-a--c
foo_dsp_crossfade.dll 10.24025.02.2004 20:29-a--c
foo_dsp_crossfeed.dll 9.21622.11.2003 22:23-a--c
foo_dsp_delta.dll 11.26425.03.2005 16:32-a--c
foo_dsp_nogaps.dll 12.28825.02.2004 20:29-a--c
foo_dsp_skip_silence.dll 9.21625.02.2004 20:29-a--c
foo_dsp_soundtouch.dll 33.28029.02.2004 03:28-a--c
foo_dynamics.dll 13.82425.02.2004 20:29-a--c
foo_faac.dll 192.00016.05.2004 11:21-a--c
foo_festalon.dll 158.20805.09.2004 17:41-a--c
foo_flaccer.dll 78.84816.05.2004 13:19-a--c
foo_lame.dll 20.99205.01.2004 20:05-a--c
foo_lpac.dll 16.89625.02.2004 20:31-a--c
foo_matroska.dll 265.21621.07.2004 20:25-a--c
foo_mod.dll 24.06409.09.2004 11:49-a--c
foo_monkey.dll 100.35205.09.2004 12:11-a--c
foo_mpcenc.dll 18.94425.11.2003 23:07-a--c
foo_nez.dll 139.26424.04.2004 17:11-a--c
foo_null.dll 10.24025.02.2004 20:31-a--c
foo_oggpreview.dll 1.022.97612.06.2004 19:26-a--c
foo_out_dsound_ex.dll 20.48028.06.2004 00:32-a--c
foo_out_ks.dll 31.23228.06.2004 00:31-a--c
foo_pphsresample.dll 47.10423.05.2004 18:04-a--c
foo_psf.dll 145.40823.08.2004 10:38-a--c
foo_read_http.dll 24.06428.06.2004 00:32-a--c
foo_run.dll 15.36019.08.2004 10:30-a--c
foo_scheduler.dll 73.21604.12.2004 15:09-a--c
foo_shn.dll 49.15206.06.2004 18:08-a--c
foo_sid.dll 279.04025.02.2004 04:35-a--c
foo_spc.dll 54.27228.06.2004 00:32-a--c
foo_speex.dll 89.08816.05.2004 11:28-a--c
foo_syfm.dll 26.62404.04.2004 19:30-a--c
foo_temple.dll 33.28024.10.2004 21:02-a--c
foo_tfmx.dll 28.16028.10.2003 19:15-a--c
foo_toolame.dll 64.00022.11.2003 22:26-a--c
foo_tta.dll 20.48030.08.2004 18:33-a--c
foo_tta_old.dll 19.96830.08.2004 18:37-a--c
foo_ui_std.dll 83.96828.06.2004 00:32-a--c
foo_uie_albumlist.dll 48.64030.11.2004 21:37-a--c
foo_uie_ascii_buttons.dll 13.31208.11.2004 00:47-a--c
foo_uie_dbexplorer.dll 30.72026.08.2004 18:21-a--c
foo_unpack.dll 164.86428.06.2004 00:32-a--c
foo_vis_simple_spectrum.dll 24.06410.11.2003 12:01-a--c
foo_vis_vu_meter.dll 16.89631.01.2004 17:32-a--c
foo_vorbisenc.dll 1.095.16808.08.2004 11:15-a--c
foo_xa.dll 57.34424.04.2004 17:08-a--c
Thanks in advance.
foo_input_std.dll is missing. I guess you cannot play MP3 or Vorbis files either currently.
Edit: I noticed the list you gave were the removed components, not the remaining ones. I still think you should check for foo_input_std.dll.
another. check Database setting,
Preferences > Database
if the box "Block tag update oprations" is checked.
Unchecked it, that solved the problem, thank you!
@foosion: foo_input_std was under my active components.
Thx both!11!
