Topic: Severe bug (Read 2961 times) previous topic - next topic
Severe bug
Whenever I try to change tags or use replaygain on a file, regardless of whether it is playing or not, the program tells me "Verboten!" in the console. It sure seems stupid to have features built into foobar which can't be used. Well anyway I would guess the problem is as simple as the program "thinking" that the files are read-only or presently in use.
Severe bug
That is what happens when you try to update files while "Block tag update operations" is enabled.
Severe bug
Do you have "Preferences>Database>Block tag update operations" enabled? If yes, just disable that option.
edit: foosion was faster
Severe bug
I'm sure this was asked a million times before...
Life is Real...
(But not in audio :) )
Severe bug
Well, the console should be a little more verbose!
(Thanks guys.)
