Topic: Problems with Columns UI and albumlist panel (Read 2504 times) previous topic - next topic
I for a long time listen to music on a computer on Foobar2000 because it has the most transparent sounding.
But only recently has engaged in its interface - foo_ui_columns and foo_albumlist (foo_uie_albumlist).
I have seen one lack foo_ui_columns which does not allow to display logically the order of songs in an album under number of a track. This absence of global sorting ui_columns.
At foo_albumlist (panel) is present two lacks:
1. It is one global sorting on all strings of display playlist. To switch sorting at each switching a string of display playlist, it is necessary to come in Foobar2000-Preference-Album list and manually to switch a string of sorting.
2. I cannot write a string of display of directories which cleverly would display all directories database, thus having allowed me to show the name songs taken from Tags.
Therefore I address for the help. Somebody could solve these problems?
Have you tried looking at the main menu, "playlist->sort->sort by..."?  A simple sort string like "%artist% - %album% - $num(%tracknumber%,2) - %title%" should do the trick.
[a href="index.php?act=findpost&pid=285506"][{POST_SNAPBACK}][/a]
You offer ordinary  manual sorting.
Which it is necessary to do each time as opens next playlist.
Otherwise display playlist will be in standard sorting Foobar2000.
I am interested with the global sorting, established by the user.
As I understand Columns_UI displays playlist to the sorting  default rigidly accepted in Foobar2000.
Therefore each time, a  you want to display playlist in sorting the user, it is necessary for you to do  manual operation of sorting.
Or I am not right?
I think ColumnsUI and album list use the "Sort incoming Files by" string in Preference > Core.  Changing that should let you use any sort order you like, and have it always applied.
