Topic: Reverse Sorting String (Read 2997 times) previous topic - next topic
Now this may be an incedibly stupid question, just wondering how I could get my playlist sorted in reverse order, e.g. from Z to A rather than from A to Z when I'm sorting by artist name. Tried -%Rating%, Reverse %Rating% but nothing seems to work. I don't really want to use the Reverse command every time I try to get my playlist sorted. Is this possible at all?
[a href="index.php?act=findpost&pid=283869"][{POST_SNAPBACK}][/a]
If it's with numbers, yes.  Just subtract the value from the maximum number for that field.  For instance:
$sub(5,%rating%)
will sort reverse by rating.
$sub(5,%rating%)
[a href="index.php?act=findpost&pid=283870"][{POST_SNAPBACK}][/a]
Wow! This did the trick. Thank you so much for your fast reply.
Using this sort string:
$if2(%album artist%,%artist%)
$if2(%album artist%,%date%)
$if2(%venue%,%album%)
%__codec%
$sub(10,%rating%)
%disc%
That works so long as all tracks in an album has the %rating% tag. If they dont, the listing will be wrong, like 10,9,tracks with missing tag,8,7,6,5,4,3,2,1.
Btw i use 1-10 rating, and only display 1-10 instead of all those dots etc, that shouldnt matter though.
Any ideas topdownjimmy?
A cop-out solution is: Sort your playlist first so that the tracks are in the "forwards" order (the one that you want to invert). Then resort your playlist with something like
$num($sub(999999999,%_playlist_number%),9)
Haven't tested this but something like the above should do it. Sorry it's a two-step solution.
@Zoominee: I have a "Playlist->Sort->Reverse" option, which should be much cleaner than the method you suggested.
@gfngfgf: Cool, i probably have that option too then! Never occurred to me because i've never thought about reverse sorting playlists until i saw this thread...
