Topic: foobar - allofmp3 384kbps (Read 4351 times) previous topic - next topic
is there a way to get foobar to support allofmp3's free-form 384kbps mp3's? thanks in advance
Try if it works with the mad-decoder.
- Lyx
It won't, since foo_input_std still handles the base stream, and it does not support "free format" or whatever it's called.
I think Madplay are your best bet for playing those. If there's anything else that supports it I at least haven't heard of it.
Tip: Use Madplay with wildcard support from commandline with:
madplay -v --display-time remaining -a -1.5 --tty-control *.mp3
and you can control playback with:
The keyboard controls are:
   P
       Pause; press any key to resume.
   S
       Stop; press any key to replay the current file from the beginning.
   F
       Forward; advance to the next file.
   B
       Back; replay the current file, unless it has been playing for less than 4 seconds, in which case replay the previous file.
   T
       Time display; change the time display mode. This only works with -v (--verbose). The display mode alternates among overall playing time, current time remaining, and current playing time.
       Increase gain; increase the audio output gain by 0.5 dB.
       Decrease gain; decrease the audio output gain by 0.5 dB.
   Q
       Quit; stop decoding and exit.
http://www.linuxmanpages.com/man1/madplay.1.php
[a href="index.php?act=findpost&pid=283528"][{POST_SNAPBACK}][/a]
You could also use the MAD Winamp plug-in (in_mad.dll), which works perfectly with 384k files. It probably works with all players that can use Winamp plug-ins (I tested it with Winamp and 1by1).
Proverb for Paranoids: "If they can get you asking the wrong questions, they don't have to worry about answers."
-T. Pynchon (Gravity's Rainbow)
[a href="index.php?act=findpost&pid=288066"][{POST_SNAPBACK}][/a]
Hmmmm.... and it even plays 640 kbps mp3  (who the f**k would make those.... or even worse, test it...?)
