Topic: 5.1 AAC using Nero or Quicktime? (Read 4095 times) previous topic - next topic
Is there a way I can encode 5.1 wav to 5.1 aac using Nero or Quicktime encoder?
Daniel
Yes, Nero should work from both Burning ROM and foobar2000.
AFAIK QT doesn't currently support multichannel.
[a href="index.php?act=findpost&pid=282971"][{POST_SNAPBACK}][/a]
"Encode Files..." from Nero Burning ROM tells me "Can't open file" when I try to "Add..." any file that is 3, 4, 5 or 6 (5+1) channels. These are wav files. What am I missing?
As I see, foobar lists only FAAC as AAC encoder. How do I add Nero encoding to foobar2000 (please save me time)?
Daniel
Download foo_nero on Case's website:
http://www.saunalahti.fi/cse/foobar2000.php
[a href="index.php?act=findpost&pid=282981"][{POST_SNAPBACK}][/a]
Yes, 5.1 aac encoding using Nero encoder is working ok with foobar2000. Still can't get it to work using Burning ROM...
