Topic: Helix Fixed-point open source HE-AAC decoder (Read 22637 times) previous topic - next topic
Yesterday, the RealNetworks Codec Team released an open source optimized High-Efficiency AAC (aacPlus) decoder to the Helix Community.
The Helix Fixed-point HE-AAC decoder provides an optimized 32-bit fixed-point implementation, which will be dual-licensed under RCSL/RPSL. No extra copyright license is required beyond the standard Helix license terms, although patent licenses are not included and must be acquired from the appropriate AAC licensors.
The Helix AAC decoder is highly optimized for ARM processors and meets or exceeds the performance of other commercial implementations. It also features one of the first widely available fixed-point implementations of SBR.
The following features are currently supported:
· MPEG-2 and MPEG-4 low complexity decoding (intensity stereo, MS, TNS, PNS)
· spectral band replication (SBR), high-quality mode
· mono, stereo, and multichannel modes
· ADTS, ADIF, and raw data block decoding
· MP4, RM, and other file formats supported via Helix client
https://datatype.helixcommunity.org/2005/aacfixptdec
Sr. Codec Engineer (video) | RealNetworks Codec Group | helixcommunity.org
This information is provided "AS IS" with no warranties,  grants no rights, and reflects my personal opinion.
Amazing!
Big thanks to RN for contributing this.
Just what the community needs, thanks Karl.
Bravo.
An evolution as one likes it
Thank you Karl.
Great contribution for the evidence to prove the more effiective complexity design  of AAC than any other codec. From the statistical number, we can see the ARM enhanced instruction cannot bring a significant improvemnent as in speech codec. It also tell us that the comparable computation power annouced by coding technology beteewn conventional AAC decoder and HE-AAC decoder is questionable.
However, from my knowledgement base, the fastest commercial AAC ARMv2 decoder in the world can reach 18 MHZ 44.1KHz stereo. But this decoder may devote much effort between memory usage and speed.
[a href="index.php?act=findpost&pid=279670"][{POST_SNAPBACK}][/a]
Hum they only tested it on a ARM9TDMI (v4T), ARM9E (V5TE), StrongARM (v4) and Xscale (V5TE). They didn't test on anything like a ARM1136 (v6) which has various media and SIMD extensions.
They also compiled it with ADS 1.2 rather than the latest ARM compiler RVCT 2.2 which produces significantly faster code.
The fastest ARM ACC codec was handcrafted in assembler by some guys down the corridor from me but we no longer license it commercially.
Hi Karl!  This is really awesome contribution to the open source community.  But is the RCSL/RPSL license compatible with GPL?  I ask because the it would be really nice to use this code in the iPodLinux project.
EDIT: Nevermind, according to this it is .
[a href="index.php?act=findpost&pid=279923"][{POST_SNAPBACK}][/a]
It also says this:
1 Note: because this license contains certain reciprocal licensing terms that purport to extend to independently developed code, You may be prohibited under the terms of these otherwise compatible licenses from using code licensed under their terms with Covered Code because Covered Code may only be licensed under the RealNetworks Public Source License. Any attempt to apply non RPSL license terms, including without limitation the GPL, to Covered Code is expressly forbidden. You are responsible for ensuring that Your use of Compatible Source Licensed code does not violate either the RPSL or the Compatible Source License.
so basically RPSL is compatible with GPL, just not viceversa (according to the strict explenation of the GPL license).
Great!  Now we just need an open source HE-AAC ENCODER
~ J
