Topic: Speex 0.8.0 Is Out (Read 7892 times) previous topic - next topic
Speex 0.8.0 Is Out
Ok, John, consider it a feature request.
"Oggdrop 1.5 alpha: Now with Speex support!" I like the ring of that don't you? Takes care of our music AND voice recordings.
Well, I may disappoint you, but oggdropXPd (next version) does not support Speex.
However,  speexdrop V0.0.1alpha has just been uploaded to Roberto!!
Input for encoding may be any 8 or 16 bit wav file, stereo or mono. Input wavs are resampled to either 8000Hz or 16000Hz and automatically (at the moment) downmixed to mono unless they are already in the specified format.
Decoding/playback options are the same as for oggdropXPd except for the absence, naturally, of vorbisgain tag interpretation.
Comments are welcomed and once the code appears stable (it tests out OK), and I've tidied it up, I'll post the source.
Maybe roberto is not as fast as you... I can't find the proggy there anyway
Speex 0.8.0 Is Out
Patience, my son...
I was testing it.
It's now available at RareWares, "others" section.
Regards;
R.
Speex 0.8.0 Is Out
Just to throw a spanner in the works, V0.0.2alpha is now available (the progress bar didn't function on decode before and now it does  ). I'll upload to Roberto as soon as I can get in, but in the meantime it's available from here.
John
My compiles and utilities are at http://www.rarewares.org/
Speex 0.8.0 Is Out
New frontend is already available.
(Indeed, it has been available for hours, but I forgot to post it)
R.
