Topic: Pqf Specs (Read 3214 times) previous topic - next topic
Pqf Specs
I am wondering if someone could verify for me if I got the right info for the AAC pqf filterbank. I only have the MPEG4 Final Committee Draft copy and I am not sure if there are any mistakes in the Final specs.
The 48 Q coefficients:
9.7655291007575512e-05,
-2.2656858741499447E-02,
1.3809589379038567E-04,
-6.8031113858963354E-03,
9.8400749256623534E-05,
1.5085400948280744E-02,
-8.6671544782335723E-05,
3.9750993388272739E-02,
-4.6217998911921346E-04,
6.2445363629436743E-02,
-1.0211814095158174E-03,
7.7622327748721326E-02,
-1.6772149340010668E-03,
7.9968338496132926E-02,
-2.2533338951411081E-03,
6.5615493068475583E-02,
-2.4987888343213967E-03,
3.3313658300882690E-02,
-2.1390815966761882E-03,
-1.4691563058190206E-02,
-9.5595397454597772E-04,
-7.2307890475334147E-02,
1.1172111530118943E-03,
-1.2993222541703875E-01,
3.9091309127348584E-03,
-1.7551641029040532E-01,
6.9635703420118673E-03,
-1.9626543957670528E-01,
9.5595442159478339E-03,
-1.8073330670215029E-01,
1.0815766540021360E-02,
-1.2097653136035738E-01,
9.8770514991715300E-03,
-1.4377370758549035E-02,
6.1562567291327357E-03,
1.3522730742860303E-01,
-4.1793946063629710E-04,
3.1737852699301633E-01,
-9.2128743097707640E-03,
5.1590021798482233E-01,
-1.8830775873369020E-02,
7.1080020379761377E-01,
-2.7226498457701823E-02,
8.8090632488444798E-01,
-3.2022840857588906E-02,
1.0068321641150089E+00,
-3.0996332527754609E-02,
1.0737914947736096E+00
The Analysis filter's cosine modulator :
h[n] = 0.25cos((2i + 1)(2n + 5)PI/16)
n = 0,1...96
i=0,1,2,3
The Syntesis filter's cosine modulator :
h[n] = cos((2i + 1)(2n - 3)PI/16)
n = 0,1...96
i=0,1,2,3
wkw
Pqf Specs
Ok, didn't feel like comparing, so I copied it from the official spec:
0 9.7655291007575512E-05 24 -2.2656858741499447E-02
1 1.3809589379038567E-04 25 -6.8031113858963354E-03
2 9.8400749256623534E-05 26 1.5085400948280744E-02
3 -8.6671544782335723E-05 27 3.9750993388272739E-02
4 -4.6217998911921346E-04 28 6.2445363629436743E-02
5 -1.0211814095158174E-03 29 7.7622327748721326E-02
6 -1.6772149340010668E-03 30 7.9968338496132926E-02
7 -2.2533338951411081E-03 31 6.5615493068475583E-02
8 -2.4987888343213967E-03 32 3.3313658300882690E-02
9 -2.1390815966761882E-03 33 -1.4691563058190206E-02
10 -9.5595397454597772E-04 34 -7.2307890475334147E-02
11 1.1172111530118943E-03 35 -1.2993222541703875E-01
12 3.9091309127348584E-03 36 -1.7551641029040532E-01
13 6.9635703420118673E-03 37 -1.9626543957670528E-01
14 9.5595442159478339E-03 38 -1.8073330670215029E-01
15 1.0815766540021360E-02 39 -1.2097653136035738E-01
16 9.8770514991715300E-03 40 -1.4377370758549035E-02
17 6.1562567291327357E-03 41 1.3522730742860303E-01
18 -4.1793946063629710E-04 42 3.1737852699301633E-01
19 -9.2128743097707640E-03 43 5.1590021798482233E-01
20 -1.8830775873369020E-02 44 7.1080020379761377E-01
21 -2.7226498457701823E-02 45 8.8090632488444798E-01
22 -3.2022840857588906E-02 46 1.0068321641150089E+00
23 -3.0996332527754609E-02 47 1.0737914947736096E+00
Didn't check if the corrigenda contain corrections to this, but they are available for free.
Synthesis modulator is correct, couldn't find the analisys modulator that fast.
Menno
Pqf Specs
thanks
wkw
Pqf Specs
MPEG4 AAC -SSR Profile PQF - IPQF coeficients are LOUSY!!!
Could anyone verify my conclusions?
wkw
Pqf Specs
The order you have them in, in your first post, is wrong.
In my posting the index is in front of the coefficients, just compare (hint: there are 2 columns).
Menno
