Topic: Foobar 0.8.3 Not Starting Anymore (Read 1680 times) previous topic - next topic
Yesterday it was all fine, listened to music etc.
But today, when i tryed to run foobar, it just didn't run. The exe seems to do  nothing. After double clicking the cursor turns into the sandclock for a half a second, and that is all. Tryed uninstall, reisntall, all modes(Full, normal, minimum). What is going on? Other proggies seem to run correctly.
Just a few random ideas for you to try...
Did you restart your machine? If not, can you check that there is no hanging foobar2000.exe process in the task list? If not, when you start the exe, does one appear and stay?
Did you try removing (renaming) foobar2000.cfg to see if reverting to the default settings helps? Or installing to a different directory so you're sure you're getting a clean install? Perhaps some component you installed is causing problems.
Do any logs get generated in the foobar directory?
Restarted, didn't help.
Made squeeky clean install, nuthin.
And no logs :S
Nothing runnign in the taskmanager eighter
