Why not use lossy if you can..
Reply #16 – 2005-02-16 19:57:16
I keep them on a home server. I used an old motherboard, cpu, ram, case, etc. I spent $100 on a 3ware RAID card, and $400 for 4 200GB maxtor drives. So, about $600 investment. The drives are configured as RAID 5, so about 6ooGB usable space. The OS is Redhat Fedora. Nice setup. I just had a Maxtor DiamondMax10 300GB (6BS300) almost full of music and it recently had master file table (MFT) failure. I was scared that I lost some of my music but in the end I could recover everything through the backup drive and using a recovery software on the damaged drive. So I'm not going for Maxtor again. I now have 300GB Seagate 7200.8 as my main music drive and a Western Digital backup drive. I guess we need a separate thread for this discussion but I'm really interested in other people's experiences in how to maintain a large music database and their recovery stories. Even though RAID 5 seems like a good idea. It seems like you'll have 5 drives always active -> 5 times the probability of failure. I think if the drives are running then they have the potential to die. I am also suspicious about PAR2 recovery. Either a drive totally collapses (in which case PAR2 could not be utilized) or very rarely gets sector errors. Optical backup is not safe either b/c the media dies and you'd never know unless you verify them and replace them over time. So I tend to believe a 1-1 backup stored in a safe place is the safest which would be quite costly for a 600GB setup. Is lossless worth all this trouble and possibility to lose everything?
