Plugin Album List is erroneous
2005-02-10 23:05:43
took me a lifetime to circle this problem but finally i have got the suspect: whenever i add the tab Album list to my (ui_columns-)interface, i get the following errors...ERROR (foo_matroska) : Matroska: unable to find a "A_AC3" packet decoder object. ERROR (foo_input_std) : referenced file doesn't exist ERROR (foo_input_std) : referenced file doesn't exist ERROR (foo_input_std) : referenced file doesn't exist ERROR (foo_input_std) : referenced file doesn't exist ERROR (foo_input_std) : referenced file doesn't exist ERROR (foo_input_std) : referenced file doesn't exist ERROR (foo_input_std) : referenced file doesn't exist ERROR (foo_input_std) : referenced file doesn't exist ERROR (foo_input_std) : referenced file doesn't exist ERROR (foo_matroska) : Matroska: unable to find a "A_AC3" packet decoder object. i figure there are some broken files in one of the directories it parses but it's very annoying having that console pop up every time i start foobar and the errors are so general i don't even know which files are broken. what i'm not going to do is check my whole collection for broken files. so is there anything to alleviate this problem? clearly, i am outwitted... maybe album list could be altered to the point that it spits out which files are actually broken (at which point the input-plugins spat out the error)? i mean it's really only an annoyance since the generated list is working, as far as i can tell complete and everything, only the error really bugs me.
