Topic: Foobar Gallery (Read 1808400 times) previous topic - next topic
Foobar Gallery
Reply #2675
@bode
in the playlist switcher preferences (general tab) you can edit the layout
here are the available tags you can use:
%length% = shows the length of the playlist
%title% = shows the playlist name
%is_locked% = returns "1" if the playlist is locked for editing - can be used in combination with $if functions
%lock_name% = shows the type of lock
%size% = shows the number of entries in the playlist
%is_active% = returns "1" if the playlist is currently selected
%is_playing% = returns if the playlist is the one currently playing
got the info from here
http://www.audiohq.de/index.php?showtopic=1695
It's in german but there are some examples for the use of these tags
Foobar Gallery
Reply #2676
These should also be in the Columns UI wiki.
Foobar Gallery
Reply #2678
hey,
thanx for all that,
I got it working in the playlist switcher,
However, I was wanting to do it in the Album List panel (which is where i went wrong), and cant seem to find anything on it anywhere.
It was working in 0.83, but i was using someone else's config (4nti).
Read the columns UI wiki, searched the forums, to no avail.
Foobar is looking pretty good now too, just the total time in album list and I am a happy man.
Ill keep reading and sure to find it somewhere.
Thanx again for help.
foobar is a bit like a loose tooth, or a scabby knee, a little annoying at first, but once you start playing with it you can't stop. Im addicted.
Foobar Gallery
Reply #2679
My lastest foobar, im still messing with the left panel. both are the foo_uie_trackinfo mod.
Foobar Gallery
Reply #2680
Like Web2.0 Design?
Foobar Gallery
Reply #2682
I think its just the album art flipped with a gradient png overlay
Foobar Gallery
Reply #2685
Here's My Config. I like it alot.
Foobar Gallery
Reply #2686
yeah, that's right!
use SCPL.
Item Display:
$imageabs2(120,120,0,0,120,120,14,$add(23,$mul(-23,%_itemindex%)),
path to Mirror.png,)
path to Reflection.png,)
Group Display:
$imageabs2(120,120,0,0,120,120,14,$add(23,$mul(18,%tracknumber%)),
path to Folder.jpg,)
I guess you look this code, It might be too usually disappointed.
and I'm sorry by poor English.
thanks a lot!
Foobar Gallery
Reply #2688
Link removed by moderation.
Redistribution of modified setup packages is a violation of the foobar2000 license.
Greetings
Sonny Burnett.
Foobar Gallery
Reply #2690
Hello Guys.What code is it if i want to display in my track info panel the album full length,not only the track played and remaining length?
Foobar Gallery
Reply #2691
I dont think thats possible, sorry. foobar only reads per track data, and to get an album length would require it to read other tracks.
the only way around it is pretty much by tagging each file with a tag that holds the album length. You could use a plugin that tags to the database (i forgot which one does that, but its easy to find) so that you dont have extraneous tags in your files.
Foobar Gallery
Reply #2692
Thx.If i use this code in my playlist switcher,its working.But if i load a playlist showing playlists full time,if playing 1 album only,thats correct...
Total Time ->>%title%$if(%is_locked%,$rgb(128,128,128,254,254,125)' ['%lock_name%']') $rgb(65,65,65,192,254,192)'('%length%')'-'('%size%')'
Foobar Gallery
Reply #2693
Bought a new PC recently, which 'forced' me to review my foobar settings.
Below is a picture of my current GUI. (Note: I don't use albums, only singles)
It's quite simple (to build). You only need Columns UI and Queue Manager.
Screenshot
Greetings,
Ivolution
Moderation: Please do not inline images larger than roughly 800x600 and 80KB. Please use thumbnails and/or links for large pictures instead.
Foobar Gallery
Reply #2694
Just started using foobar, my simple config
