Topic: Foobar Gallery (Read 1808004 times) previous topic - next topic
Foobar Gallery
Reply #1100
my "temporary" setup, i'm too lazy to make better one with my custom string ...
[a href="http://mazy.johanka.cz/my_pics/temp/foobar/mazy-foobar-screenshot-005.png" target="_blank"]
Foobar Gallery
Reply #1101
Is that the Track info across the top there? I really like that idea of the big title across the top like that.
[a href="index.php?act=findpost&pid=306060"][{POST_SNAPBACK}][/a]
yes, it is . i like that too ... i have 3 different track info panels (just hex-edited their guids). hopefully next version will support multiple instances with separate config and font configuration directly in formatting.
Foobar Gallery
Reply #1102
Do you mean you tweaked the dll so now you can have 3 different panels each one with its own tagz and formatting?
I've been asking this many times.........
Foobar Gallery
Reply #1103
yep. it's [a href="http://mazy.johanka.cz/temp/trackinfo.rar]here[/url] if you want it, but it's easy to do that by yourself. only problem is that they all have same name, so it takes some time to learn which panel is which. there has been better version of 2nd track info panel, complete re-compile with changed name etc, but it's not working as it should.
Foobar Gallery
Reply #1105
Foobar Gallery
Reply #1106
[a href="http://img54.echo.cx/my.php?image=foobar3lk.png" target="_blank"]
Foobar Gallery
Reply #1107
Foobar Gallery
Reply #1108
Indeed, very nice setup, synth7.
I second mitchmalibu's request
btw, what font are you using there?
Foobar Gallery
Reply #1109
[a href="http://12thstreetauto.com/dkn/k/desktops/screens/foobar_june.jpg" target="_blank"]
Foobar Gallery
Reply #1110
I like my foobar simplistic
http://www.rudefyet.com/foobar.jpg
although i am thinking of changing some colors in the playist
Foobar Gallery
Reply #1111
mitchmalibu and untl55, sure
Font: Arial Unicode MS 7pt
Background: R: 48, G: 48; B: 53
// Setup //
$puts(discinfo,$trim($if(%disc%,'(''Disc '%disc%[' '''%discname%'']')',)))
$puts(spacer,ffffffּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּּ$char(10))
$puts(spacer2,ּ )
$puts(headline,$rgb(255,255,255))
$puts(main,$rgb(208,128,16))
$puts(info,$rgb(185,185,185))
$puts(text,$rgb(255,255,255))
$puts(grayed,$rgb(150,150,150))
$puts(gaincolor,$rgb(110,170,210))
$puts(streamcolor,$rgb(120,210,110))
$puts(size,5)
// Progress Bar
$puts(progress_length,68)
$puts(progress_color1,$rgb(208,128,16))
$puts(progress_color2,$rgb(195,195,195))
$puts(progress_char,■)
$puts(progress_color1a,$blend($get(progress_color1),$rgb(0,0,0),1,4.5))
$puts(progress_color2a,$blend($get(progress_color2),$rgb(0,0,0),1,5.7))
$puts(progressbar,
$puts(progress,$muldiv(%_time_elapsed_seconds%,$get(progress_length),%_length_seconds%))
$transition($repeat($get(progress_char),$get(progress)),$get(progress_color1a),$get(progress_color1))
$transition($repeat($get(progress_char),$sub($get(progress_length),$get(progress))),$get(progress_color2a),$get(progress_color2))
// OUTPUT //
$get(info)Mode: $get(text)$caps(%_trackinfo_mode%)$char(10)
$if(%_length%,$char(1)C$get(headline)d2aa6e▪ 9a7030▪ 705123▪ 1080d0P R O G R E S S705123 ▪ 9a7030▪ d2aa6e▪$char(10),)
$if(%_length%,$char(1)C$get(progressbar)$char(10),)
$if(%_length%,$get(spacer),)
$if(%_length%,
$char(1)C$get(headline)d2aa6e▪ 9a7030▪ 705123▪ 1080d0S O N G I N F O705123 ▪ 9a7030▪ d2aa6e▪$char(10),
$char(1)C$get(headline)d2aa6e▪ 9a7030▪ 705123▪ $get(streamcolor)S T R E A M I N F O705123 ▪ 9a7030▪ d2aa6e▪$char(10)
$if(%title%,$get(spacer2)$get(info)'Title:' $get(main)$caps(%title%)$char(10),)
$if(%artist%,$get(spacer2)$get(info)Artist: $get(text)$caps(%artist%)$char(10),)
$if(%_length%,,$get(spacer2)$get(info)'Listened For:' $get(streamcolor)%_time_elapsed%$char(10))
$if(%_length%,,$get(spacer2)$get(info)'Bitrate:' $get(streamcolor)$if2($pad(%__bitrate_dynamic%,3)'kbps',$if2(%__bitrate%'kbps',))$char(10))
$if(%_length%,,$get(spacer2)$get(info)'Location:' $get(streamcolor)$replace(%_path_raw%,%_filename_ext%,)$char(10))
$if(%album%,$get(spacer2)$get(info)Album: $get(text)%album%[ $get(grayed)$get(discinfo)]$char(10),)
$if(%tracknumber%,$get(spacer2)$get(info)Track: $get(text)$num(%tracknumber%,2)$char(10),)
$if(%genre%,$get(spacer2)$get(info)Genre: $get(text)%genre%$char(10),)
$if(%date%,$get(spacer2)$get(info)Date: $get(text)[%date%]$char(10),)
$if(%_length%,$char(1)C$get(headline)d2aa6e▪ 9a7030▪ 705123▪ 1080d0S T A T I S T I C S 705123 ▪ 9a7030▪ d2aa6e▪$char(10),)
$if(%__codec%,$get(spacer2)$get(info)Codec: $get(text)[%__codec%]$char(10),)
$if(%__bitrate%,$get(spacer2)$get(info)Bitrate: $get(text)$if(%__lame_profile%,1080d0--%__lame_profile%,%__bitrate% Kbit/s) $get(grayed)['('%__lame_version%')']$char(10),)
$if(%_time_total%,$get(spacer2)$get(info)Time: $get(text)%_time_elapsed% / %_time_total%$char(10),)
$if(%__samplerate%,$get(spacer2)$get(info)Samplerate: $get(text)%__samplerate% Hz$char(10),)
$if(%__replaygain_track_gain%,$get(spacer2)$get(info)Track Gain: $get(gaincolor)$cut(%__replaygain_track_gain%,$get(size)) dB$char(10),)
$if(%__replaygain_album_gain%,$get(spacer2)$get(info)Album Gain: $get(gaincolor)$cut(%__replaygain_album_gain%,$get(size)) dB$char(10),)
$if(%_filesize%,$get(spacer2)$get(info)Filesize: $get(text)$div(%_filesize%,1048576).$left($num($muldiv($mod(%_filesize%,1048576),1000,1048576),3),2)' MB'$char(10),)
$if(%__referenced_file%,$get(spacer2)$get(info)'CUE Reference:' $get(streamcolor)%__referenced_file%$char(10),)
$get(spacer)
// END //
Foobar Gallery
Reply #1112
Simple but effective
Foobar Gallery
Reply #1113
[a href="index.php?act=findpost&pid=306315"][{POST_SNAPBACK}][/a]
wow nice! could you plz zip and upload your foobar-folder (without playlists folder)? foobar is standalone so i can get your complete settings.
i can give you ftp access if needed
Foobar Gallery
Reply #1114
//Colors, etc.
$puts(info_box_size,34)
$puts(default_color,ffffff)
$puts(leading_color,949494)
$puts(heading_color_l,ffffff)
$puts(heading_color_r,ffffff)
$puts(is_playing_color,ffffff)
$puts(len,43)
$puts(music,♪)
///////Song
// $transition( $repeat(,$add($get(info_box_size),4)),$get(heading_color_l),$get(heading_color_r))
// $char(10)$char(10)
$get(leading_color)• TITLE: $get(is_playing_color)$replace(%title%,'(',6c8e93'(',')',')'$get(is_playing_color),'[',6c8e93'[',']',']'$get(is_playing_color))$char(10)
$get(leading_color)• ARTIST: $get(default_color)%artist%$char(10)
$get(leading_color)• ALBUM: $get(default_color)$iflonger(%album%,33,$cut(%album%,29)...,%album%) $if(%disc%,949494CD%disc%,)$char(10)
$get(leading_color)• DATE: $get(default_color)%date%$char(10)$get(leading_color)
$get(leading_color)• GENRE: $get(default_color)%genre%$char(10)
// $char(10)
///////Tech
// $transition(Tech Info $repeat(,$add($get(info_box_size),4)),$get(heading_color_l),$get(heading_color_r))
$get(leading_color)• CODEC: $get(default_color)%__codec%  $get(leading_color)$char(10)
$get(leading_color)• BITRATE: $get(default_color)$if(%__lame_profile%,97cddd--%__lame_profile%,%__bitrate% 949494kbps)$char(10)
$get(leading_color)• FILESIZE: $get(default_color)$div(%_filesize%,1048576).$left($num($muldiv($mod(%_filesize%,1048576),100,1048576),2),2)' 949494MB'$char(10)
// $get(leading_color)FILENAME: $get(default_color)$ifgreater($len(%_filename_ext%),$sub($get(len),14),…$right(%_filename_ext%,$sub($get(len),14)),%_filename_ext%)$char(10)
// $get(leading_color)CHANNELS: $get(default_color)$caps($if($stricmp($codec(),MP3),%__mp3_stereo_mode%,$channels())) $get(heading_color_l)$if(%__samplerate%,%__samplerate% Hz,)$char(10)
$get(leading_color)• LENGTH: $get(default_color)[%_time_elapsed% / ][%_length%]  [949494'('%_time_remaining%')']$char(10)
$progress2(%_time_elapsed_seconds%, %_time_total_seconds%, 19,ffffff'█',9a9a9a'█')
just a modded version of someone else's. but i'm glad someone likes my config
Foobar Gallery
Reply #1115
[a href="index.php?act=findpost&pid=306366"][{POST_SNAPBACK}][/a]
i would like that too.
Foobar Gallery
Reply #1116
thanks a lot synth7
Foobar Gallery
Reply #1117
[a href="index.php?act=findpost&pid=306103"][{POST_SNAPBACK}][/a]
Besides editing the GUID, I also -
1) rename the dll to trackinf2.dll
2) around offset #6990, change "trackinfo.dll"  to  "trackinf2.dll"
3) around offset #6B10, change "Track info panel" to "Track info pnl-2"
4) around offset #6CA8, change "Track info"  to  "Track inf2"
- repeat process for panel # 3 ...etc.
- then the additional panels have new names in the menus ... works great
Foobar Gallery
Reply #1118
My foo: now in red.
Yeah, I'm happy because my win box looks like a copy of Knoppix STD (bblean + Twice style).
Ala..
[span style='font-size:8pt;line-height:100%']moderation: please refrain from inlining images larger than roughly 800x600 and 80KB. please use thumbnails and/or links for large pictures instead. try PNG instead of JPEG for smaller filesize.[/span]
hi
Foobar Gallery
Reply #1119
[a href="index.php?act=findpost&pid=306418"][{POST_SNAPBACK}][/a]
Sorry!  I dont think the Foobar licence allows me to distribute my Foobar folder.  However if you are interested I could try and post my Playlist tree and Columns IU configs.
Foobar Gallery
Reply #1120
Yes, please.  I would like that--especially the Playlist tree.  I thinks its the .col file.
Foobar Gallery
Reply #1121
[a href="index.php?act=findpost&pid=306436"][{POST_SNAPBACK}][/a]
Its here (slightly modified)
[a href="http://www.chilcott.eurobell.co.uk/temp/playlist_tree.col]playlist_tree.col[/url]
Foobar Gallery
Reply #1122
foo_vis_projectM
Foobar Gallery
Reply #1124
Yes - fix linky please - very interested.
No mercy for the bandwidth impaired
