Topic: Foobar Gallery (Read 1810232 times) previous topic - next topic
Foobar Gallery
Reply #975
Here is my foobar2k:
Between, PNG images seems not to work for me. Buttons are drawn but transperancy support is missing. The black or white border is drawn round every button and it looks ugly...
vir
Foobar Gallery
Reply #976
Small update ... now with Explorer Tree and Playlist Tree.
[a href="http://img156.echo.cx/img156/6396/foogantblaurot7hr.png" target="_blank"]
((((( Strictly4me )))))
Foobar Gallery
Reply #977
What? So few people use the default UI?  I think you can do some nifty things with it.  Maybe I'll check out this Columns UI thing one day.  Until then, enjoy my current title formatting.
Foobar Gallery
Reply #978
Its pretty nice, actully. But we like the fact we can seperate the info, change its contents and colours more easily then when its in a single string
Foobar Gallery
Reply #979
@crx - good taste in music  Also, I'm a minimalist too, but give Columns UI a play.  You might like it (and you can use it to strip foobar down to an even more minimal layout).
"more minimal" (heh)
Foobar Gallery
Reply #980
[a href="http://img.photobucket.com/albums/v497/crx/Music/fb2k.gif" target="_blank"]
Foobar Gallery
Reply #981
Thanks, guys.  I'll give Columns UI a try some time.  I've only been using foobar2000 for a few days.
Foobar Gallery
Reply #982
Well here's in my fb2k finally after searching the forums a lot.
I borrowed a lot of ideas.
This is a 1280x1024 image.
[a href="index.php?act=findpost&pid=302245"][{POST_SNAPBACK}][/a]
You might want to check the option in Column UI that says the playback button image has mouse over images included.  Can't remember the exact name of the option, but it is on the last tab (I think).  I would be more specific, but fb2k is converting my FLAC files right now....only 1200 or so left.
[a href="index.php?act=findpost&pid=302332"][{POST_SNAPBACK}][/a]
Thanks for the tip. I checked the option but i didn't notice anything different when passing the mouse over the image. Is it that my image has no mouse-over effect?
Foobar Gallery
Reply #983
Oh, what I was saying was that I use a plugin called 'foo_syfm' to load TAGZ configurations that I download, the problem is that they only seem to work if I have columns ui off, like... if I use the default interface. If i use columns ui as my interface, then the playlist changes do not take effect. Is it supposed to be that way? I would like to have a TAGZed playlist interface, but id miss my panels too much. I dunno, but thanks for reading~
Foobar Gallery
Reply #985
[a href="index.php?act=findpost&pid=302628"][{POST_SNAPBACK}][/a]
after all, foo_syfm is a default ui preset loader :x
Foobar Gallery
Reply #986
Mine...
[a href="http://home.centurytel.net/jabba/foo.png" target="_blank"]
Foobar Gallery
Reply #987
There is a LOT of TAGZing you can do with the Columns UI playlist, just take a look at some peoples setups, or download some formatting strings from here [a href="http://foobar.nub4life.net/columns/pafiledb.php?action=category&id=5]http://foobar.nub4life.net/columns/pafiled...n=category&id=5[/url] and tear them apart to see how they work.
Foobar Gallery
Reply #988
Can someone please code for me this simple status bar, I'm trying whole day with no luck. You don't have to mess with color, I'll change it.
I would be very thankful.
Foobar Gallery
Reply #989
Mine...
[a href="index.php?act=findpost&pid=302706"][{POST_SNAPBACK}]
Here they are... Click
I included the .fcs file, the track info config, and the buttons i modified.
The main playlist is just an old version of Azreal, the track info panel is something i modified from one that was posted in the track info thread.  The buttons are a more spaced out version of the elevator 04 buttons.  Let me know if you need anything else.
Foobar Gallery
Reply #990
[a href="http://www.imageshack.us" target="_blank"] )
Foobar Gallery
Reply #991
Why not just use
$char(9)[%_time_elapsed%] $progress2(%_time_elapsed_seconds%,%_time_total_seconds%,5,'• ',$rgb(171,49,51)'• ')
(and change the bullets to whatever character you like). You can also change the 5 to whatever number you like to make the progressbar longer.
edit: there's still some tweaking in the code (I just copypasted my own progressbar code there), but I have no time to edit it now.
Foobar Gallery
Reply #992
I just pasted the progress bar that i have in my trackinfo, which I got from someone in the trackinfo thread, like I said, I'm a beginner.
EDIT: the original code that I pasted had a nice transition-effect progress bar, but for the code I posted, I removed the transition bits. I assume that transitions aren't possible with $progress/$progress2.
Foobar Gallery
Reply #993
Why not just use
[a href="index.php?act=findpost&pid=302869"][{POST_SNAPBACK}][/a]
I <3 you dude. Its the little things that make our configs awesome and add to our players.
God i love Foobar.
Foobar Gallery
Reply #994
Updated, little tweaks here and there, much smoother now if you ask me. Special thanks to anza and Neil K for helping with status bar code.
Foobar Gallery
Reply #995
Wow, awesome config, what font is it? Franklin Gothic?
Foobar Gallery
Reply #996
[a href="index.php?act=findpost&pid=302914"][{POST_SNAPBACK}][/a]
Yes, Franklin Gothic Medium, 7.
Foobar Gallery
Reply #997
miniml, care to share your config?
We're all just noise on the wires..
Foobar Gallery
Reply #999
keeping it fairly simple
