Topic: Foobar Gallery (Read 1808025 times) previous topic - next topic
Foobar Gallery
Reply #75
Can anyone tell me how UpNorth made his visualisation look like that?
Foobar Gallery
Reply #76
[a href="index.php?act=findpost&pid=269484"][{POST_SNAPBACK}][/a]
Right click on the visualization in Columns UI and choose "bars mode".
@ UpNorth
Damn nice config indeed. You should upload that to the foo_ui_columns configs thread.
Foobar Gallery
Reply #77
@ UpNorth
Damn nice config indeed. You should upload that to the foo_ui_columns configs thread.[a href="index.php?act=findpost&pid=269490"][{POST_SNAPBACK}][/a]
I have planed to do it, but I need to prepare some documentation first, and also verify that everything works as intended.
Foobar Gallery
Reply #78
Hello, i'm a new member and i'd like to show you my foobar. It's a patchwork of many configs taken from this forum and others. I still have a question : where can I find a complete guide for the language used in columns_ui? (the default 'title formatting help' is quite short...  )
Bye!
http://blokoss.perso.cegetel.net/
Emu 1212m, PIV 2Ghz, ATI9550, WinXp, Debian Etch
Foobar Gallery
Reply #79
Very nice config's, inpired me to do something in Foobar
Foobar Gallery
Reply #80
this is mine
screenshot
The playlist is a modified gems by lyx.
[span style='font-size:8pt;line-height:100%']Moderation: Converted image to link. Please do not inline images larger than approx. 800x600 and 80KB. For lager images please use links and preferably thumbnails in your post.[/span]
Foobar Gallery
Reply #81
Notice how many people don't use skins / choose windows standard?
Here's mine.
Foobar Gallery
Reply #82
[a href="index.php?act=findpost&pid=269568"][{POST_SNAPBACK}][/a]
I've used windows classic for as long as i remember, but with neowin's patcher you can get really nice and clean theams that dont use resources.  So I say. . why not?
Foobar Gallery
Reply #83
Says the guy with the hacked Marlett font
Foobar Gallery
Reply #84
My config
Beto, how do you get the progress bar to look like that?  I copied a script from somewhere that had to insert a symbol which was basically just a character that I chose, I would love to have a real progress bar like yours.
EDIT, never mind I figured out that it was my font.
Foobar Gallery
Reply #85
[a href="index.php?act=findpost&pid=269582"][{POST_SNAPBACK}][/a]
I'm on Win2k. No vs for me...*
* Unless I'm playing with Windowblinds
Foobar Gallery
Reply #86
[a href="index.php?act=findpost&pid=268415"][{POST_SNAPBACK}][/a]
I love you config!!!
I just have 1 question: why when I import it  it doesn't show right the playing track's time? It only shows something like ? <> ?
10x 4 help
Foobar Gallery
Reply #88
10x 4 help
[a href="index.php?act=findpost&pid=269706"][{POST_SNAPBACK}][/a]
Thx...
You mean the track lenght ?
because the number that should be near the >< are the time elapsed/remaining.
Because if its the track lengh missing, check if the column for LENGHT is enabled..
If you could post a screenshot would help to understand your problem.
If some symbol is missing you must take in consideration that some caracthers i use exist in the font im using and maybe not in yours....in this case you must replace them to match your font.
The font i use is Frutiger Linotype.
Foobar Gallery
Reply #89
It doesn't show up well on the screenshot, but I configured 3 different behaviours for tags and colors, basically:
$meta_test(full_album) isn't true (displays %artist%)
$meta_test(full_album) is true and $meta_test(va) isn't true (displays %artist% only on first line)
$meta_test(full_album) is true and $meta_test(va) is true (displays %artist% only on _isplaying and selected lines)[a href="index.php?act=findpost&pid=269224"][{POST_SNAPBACK}][/a]
What is the code for those behaviors?
Foobar Gallery
Reply #90
My current config:
-Recently played tracks are marked by a light blue double note. Later it changes to a darker color, and the appearance goes: Double note->Single note->line->dot->nothing[a href="index.php?act=findpost&pid=269469"][{POST_SNAPBACK}][/a]
What is the code for comparing system time to last played time?
Foobar Gallery
Reply #91
Foobar Gallery
Reply #92
I’ve changed couple of things.
my config
Foobar Gallery
Reply #93
beto and Kamelian where could I find that visual style?
and Speek: quite minimalistic setup there..
Foobar Gallery
Reply #94
Wow, I really like your set up Xerion and Strictly4me. Wanna do me a favor and email me your configs? badrad@gmail.com
God I love foobar.
Foobar Gallery
Reply #95
My foobar is visible at http://datto.altervista.org/myfoo.jpg
[a href="index.php?act=findpost&pid=269720"][{POST_SNAPBACK}][/a]
ey, man! really love your old-skool style!!
Foobar Gallery
Reply #96
[a href="index.php?act=findpost&pid=269802"][{POST_SNAPBACK}][/a]
the winxp style? it's called Opus.
You can find it at deviantart.com
Foobar Gallery
Reply #97
Im trying to do a sort of history tracking graphic like UpNorth, but Im having trouble. %_history_number% does not seem to work (I just get a "?"). And yes, I have the history plugin installed.
Foobar Gallery
Reply #98
Im pretty sure upNorth's config has the notes based off the last played time, you can use [a href="http://www.hydrogenaudio.org/forums/index.php?showtopic=20719&hl=foo_playcount]foo_playcount[/url] to add a last played tag
Foobar Gallery
Reply #99
ah, ok. That makes things a bit more complicated though.
So, theres no way to use foo_history strings in columns?
