Topic: Foobar Gallery (Read 1808426 times) previous topic - next topic
Foobar Gallery
Reply #2375
Here's mine for v0.9 final:
judging from your taste in music, we could be friends
you even have old fax stuff yay
(not much modding here yet, i just installed 0.9 this morning)
Foobar Gallery
Reply #2376
Can someone post here his file, i want to customize a bit my Foobar but it will be easier with examples  (Hannuh for example, your script has some things i want to include in mine)
Foobar Gallery
Reply #2377
[a href="http://img95.imageshack.us/my.php?image=foobs5lv.gif" target="_blank"]
Foobar Gallery
Reply #2379
thanks a lots!!
Foobar Gallery
Reply #2380
Made mine like this:
hi
Foobar Gallery
Reply #2381
[a href="index.php?act=findpost&pid=374068"][{POST_SNAPBACK}][/a]
Very nice. Is that columns ui? If so, would you mind posting the config? I'd like to try it.
love, IAN
droptothetop.com/
Foobar Gallery
Reply #2382
What font's that?  It's very elegant.
Foobar Gallery
Reply #2383
Here is my current 0.9 setup
Foobar Gallery
Reply #2384
Here's mine...
Foobar Gallery
Reply #2385
@ tool++, 4nt1 and spex04
What fonts are you using?
They're very clean and smooth-looking!
Foobar Gallery
Reply #2386
[a href="index.php?act=findpost&pid=374115"][{POST_SNAPBACK}][/a]
the only font i ever use
VERDANA
Foobar Gallery
Reply #2387
VERDANA
[a href="index.php?act=findpost&pid=374127"][{POST_SNAPBACK}][/a]
Sweet, thanks!
BTW, I don't have the little note chars you use in your RG column, I can't find them in charmap
Foobar Gallery
Reply #2388
Here's mine...
[a href="http://img367.imageshack.us/my.php?image=foobar2dg.png" target="_blank"] I'll see what crazy stuff I can cook up.
Foobar Gallery
Reply #2389
V0.9
Fcs file here.
[a href="index.php?act=findpost&pid=372820"][{POST_SNAPBACK}][/a]
What is it you check on whether or not to display the artist???
I've imported your fcs, but it shows for all albums (except one) the artist in the title-column... I see no difference in the tags...
Edit:
Found it... It was the %time% variable it was doing something with...
Foobar Gallery
Reply #2390
0.9, modified soap.fcs
Edit: FCS
Foobar Gallery
Reply #2391
Sweet, thanks!
[a href="index.php?act=findpost&pid=374132"][{POST_SNAPBACK}][/a]
like this?
[span style='font-size:14pt;line-height:100%']♫[/span]
[span style='font-size:14pt;line-height:100%']♪[/span]
they don't seem to exist in verdana (they do in arial though)
Foobar Gallery
Reply #2392
in the columns playlist switcher how do you get the total play time and track numbers to appear?
whats the code
Foobar Gallery
Reply #2393
Here's mine...
[a href="index.php?act=findpost&pid=374184"][{POST_SNAPBACK}]
Sure, I only made it quickly last night though, so it might be a bit rough..
http://www.sendmefile.com/00313793
whats the code
[a href="index.php?act=findpost&pid=374193"][{POST_SNAPBACK}][/a]
%length% and %size%
Foobar Gallery
Reply #2394
Here's mine...
whats the code
%length% and %size%
[a href="index.php?act=findpost&pid=374197"][{POST_SNAPBACK}][/a]
Does it work with 0.8.3 ?
Foobar Gallery
Reply #2395
[a href="index.php?act=findpost&pid=374198"][{POST_SNAPBACK}][/a]
I'm not sure..  I haven't got 0.8.3 here to try it out on
Foobar Gallery
Reply #2396
[a href="index.php?act=findpost&pid=374207"][{POST_SNAPBACK}][/a]
They do not, they only work with the latest columns_ui, which is only for 0.9 unfortunately
Foobar Gallery
Reply #2397
Sweet, thanks!
like this?
[a href="index.php?act=findpost&pid=374192"][{POST_SNAPBACK}][/a]
How comes the ♪ is displayed rotated left 90 degrees?? (in my fcs that is... )
Foobar Gallery
Reply #2398
[a href="http://img98.imageshack.us/my.php?image=foobar220320066pp.jpg" target="_blank"].
Foobar Gallery
Reply #2399
Windowblinds - Orilla
Background - Samurai Champloo
ObjectDock - Custom
Toaster - dBaines (Orange Version)
Go da Orange!
