Topic: Foobar Gallery (Read 1808281 times) previous topic - next topic
Foobar Gallery
Reply #150
Gaah - oops I meant to post a link, then got distracted and posted the image...
[a href="index.php?act=findpost&pid=270986"][{POST_SNAPBACK}][/a]
The edit button is your friend
Foobar Gallery
Reply #151
[a href="index.php?act=findpost&pid=270865"][{POST_SNAPBACK}][/a]
Could you please post your Title Formatting for your history panel?
Foobar Gallery
Reply #152
to gob
also how do you get the tabs at the bottom of the history panel, to me it looks like ur cheating and having like 6 panels or the same thing, changing the sort for each and renaming the panels, tell me its not that simple
Foobar Gallery
Reply #153
tHiNkBoNe
nice config.........I think your using the same playlist strings as me ........could you post the changes you have made to the colour strings please...mine is red.
Foobar Gallery
Reply #154
Husker.......G Force isnt in a panel Iv just resized it there.
GForce can be made borderless by going to your windows user directory (something like c:\Documents and Settings\<username>) which has a subfolder called G-Force. Inside there is a file named "Preferences (foobar2000).txt". In that file you can change the NoBo property from 0 to 1
[a href="index.php?act=findpost&pid=270753"][{POST_SNAPBACK}][/a]
Foobar Gallery
Reply #155
to gob
[a href="index.php?act=findpost&pid=271000"][{POST_SNAPBACK}][/a]
Ummm....it's that simple.
Just set up multiple album list tabs and sort each like you want. Then just rename the tab to however you sorted or want it to read.
Also...thanks McEnergizer...I got it set!
Foobar Gallery
Reply #156
I am able to shift-click to add multiple tabbed panels vertically in the sidebar, but can't figure out how some people are adding them horizontally (side-by-side)... For example, see gob's post above [#136]. There appears to be 3 tabbed panels across the top.
Columns FAQ
[a href="index.php?act=findpost&pid=270884"][{POST_SNAPBACK}][/a]
Thank you!  I could almost kiss you!
Foobar Gallery
Reply #157
Only just decided to start customising foobar last nigt (have been using it for ages now just defaultish.. although I had no luck customising it thank fully 4nt1 helped me with it and gave me his whole foobar folder, so I have edited it to my colors I like and removed the things I don't like / use.. here's the result..
http://axion.orcon.net.nz/foobar.JPG
Foobar Gallery
Reply #158
[a href="index.php?act=findpost&pid=271034"][{POST_SNAPBACK}][/a]
nice one mate, glad to see you got the functionality you were after
Foobar Gallery
Reply #159
tHiNkBoNe
[a href="index.php?act=findpost&pid=271001"][{POST_SNAPBACK}][/a]
Sure,
These are all in globals, no custom color settings for data columns.
$puts(text_color1,$rgb(0,255,255))
$puts(text_color2,$rgb(0,255,255))
$puts(track_color,$rgb(190,190,190))
$puts(background_color1,$rgb(0,0,0))
$puts(background_color2,$rgb(0,0,0))
$puts(background_color_opposite,$rgb(255,255,255))
$puts(firsttrackback,$rgb(0,128,128))
Foobar Gallery
Reply #161
heres the code for my history panel:
$ifgreater($len(%_history_time%),4,
$puts(play_hour,$left(%_history_time%,2)),
$puts(play_hour,$left(%_history_time%,1)))
$ifgreater($get(play_hour),11,
$puts(ampm,pm),$puts(ampm,am))
$ifgreater($get(play_hour),12,
$puts(play_hour,$sub($get(play_hour),12)),)
$ifgreater($get(play_hour),0,,
$puts(play_hour,12))
$if($strcmp($left($get(play_hour),1),0),
$puts(play_hour,$right($get(play_hour),1)))
$puts(play_minute,$right(%_history_time%,2))
$ifgreater($get(play_hour),9,,$puts(play_hour,  $get(play_hour)))
$puts(12_hour_time,$get(play_hour):$get(play_minute)$get(ampm))
$puts(history_date,$substr(%_history_date%,6,7)'/'
$substr(%_history_date%,9,10)'/'
$substr(%_history_date%,3,4))
$transition(
$get(history_date) $get(12_hour_time)-,
E39D0C,BD830A)
$if(%_history_is_playing%,
5357EF'♪' [%artist% - ]$if(%title%,%title% ['['%album%']'],
%_filename_ext%) '♪',
[%artist% - ]$if(%title%,%title% ['['%album%']'],%_filename_ext%))
and heres the code for  the track info panel:
//Colors, etc.
$puts(info_box_size,36)
$puts(default_color,d4d4d4)
$puts(rating_color_1,5357EF)
$puts(rating_color_2,042573)
$puts(rating_symbol,♫)
$puts(is_playing_color,5357EF)
$puts(tag_missing_color,757575)
$puts(heading_color_l,ffb00d)
$puts(heading_color_r,000000)
//Code
///////Song Info
$transition(----- Song Info $repeat(-,$add($get(info_box_size),4)),$get(heading_color_l),$get(heading_color_r))
$char(10)$get(default_color)
$if(%title%,$if(%_isplaying%,
$get(is_playing_color)$iflonger(%title%,$get(info_box_size),$cut(%title%,$sub($get(info_box_size),3))...,%title%),
$iflonger(%title%,$get(info_box_size),$trim($cut(%title%,$sub($get(info_box_size),3)))...,%title%)),
$if(%_isplaying%,
$get(is_playing_color)$iflonger(%_filename_ext%,$get(info_box_size),$cut(%_filename_ext%,$sub($get(info_box_size),3))...,%_filename_ext%),
$iflonger(%_filename_ext%,$get(info_box_size),$trim($cut(%_filename_ext%,$sub($get(info_box_size),3)))...,%_filename_ext%)))
$if(%artist%,
$iflonger(%artist%,$get(info_box_size),$cut(%artist%,$sub($get(info_box_size),3))...,%artist%),
$get(tag_missing_color)no artist info)
$if(%album%,
$iflonger(%album%,$get(info_box_size),$cut(%album%,$sub($get(info_box_size),3))...,%album%),
$get(tag_missing_color)no album info)
$if($or(%publisher%.%label%,%date%),$if($or(%publisher%,%label%),© ,)%date%$if($or(%publisher%,%label%),'. ',)[%publisher% ][%label%],
$get(tag_missing_color)no date or copyright info)
$if(%rating%,$get(rating_color_1)
$repeat($get(rating_symbol) ,%rating%)
$get(rating_color_2)$repeat($get(rating_symbol) ,$sub(5,%rating%)) ,)
$get(default_color)$if(%genre%,%genre%,$get(tag_missing_color)no genre info)
$char(10)$char(10)
///////Statistics
$transition(----- Statistics  $repeat(-,$add($get(info_box_size),4)),$get(heading_color_l),$get(heading_color_r))
$if(%play_date%,
$puts(month,$left(%play_date%,2))
$puts(day,$substr(%play_date%,4,5))
$if($strcmp($left($get(day),1),0),$puts(day,$right($get(day),1)))
$puts(year,$right(%play_date%,2))
$puts(month_name,$select($get(month),
Jan,Feb,March,April,May,June,July,Aug,Sept,Oct,Nov,Dec))
$if($strcmp($right($get(day),1),1),$puts(xx,st),
$if($strcmp($right($get(day),1),2),$puts(xx,nd),
$if($strcmp($right($get(day),1),3),$puts(xx,rd),
$puts(xx,th)))))
$puts(time_of_year,$get(month_name) $get(day)$get(xx) 20$get(year))
$if(%play_counter%,Played $if($strcmp(%play_counter%,1),
once$if(%play_date%,',')$if(%play_date%, on $get(time_of_year)),
%play_counter% times$if(%play_date%,
$char(10)  Last played on $get(time_of_year))),This song has not played before)
$ifgreater(%play_counter%,1,,$char(10))
$char(10)$char(10)
///////Tech Info
$transition(----- Tech Info  $repeat(-,$add($get(info_box_size),4)),$get(heading_color_l),$get(heading_color_r))
%__codec%
$if(%__bitrate_dynamic%,%__bitrate_dynamic%,%__bitrate%)kbps
$if($stricmp(%__codec%,mp3),$if($stricmp(%__extrainfo%,vbr),VBR,CBR))
$if($stricmp($codec(),MP3),%__mp3_stereo_mode%,$channels())
[%_time_elapsed%/][%_length%][  -%_time_remaining%]
$if(%_isplaying%,
$muldiv(%_time_elapsed_seconds%,100,%_time_total_seconds%)'%',)
$div(%_filesize%,1048576).
$left($num($muldiv($mod(%_filesize%,1048576),1000,1048576),3),2)' MB'
$if($or(%__replaygain_track_gain%,%__replaygain_album_gain%),
['['Tg']' %__replaygain_track_gain% ]['['Ag']' %__replaygain_album_gain%],
$get(tag_missing_color)there is no gain)
enjoy, i made these myself, mostly with help from here
also, the font i use in the playlist is arial 10pt bold (i think someone asked me)
Foobar Gallery
Reply #162
to gob
[a href="index.php?act=findpost&pid=271010"][{POST_SNAPBACK}][/a]
yep... yep
Foobar Gallery
Reply #163
Congrats everybody for your work.
I'd like to try a (simple) customization for my needs: basically a couple of tabs sorted by Genre and Artist and, if possible, a panel to display the %LYRICS% tag.
The problem is, I'm new to this: can you suggest me where to start? What plug-in(s) are necessary?
TIA.
Alessandro
Foobar Gallery
Reply #164
TIA.
Alessandro
[a href="index.php?act=findpost&pid=271118"][{POST_SNAPBACK}][/a]
general framework - foo_ui_columns
tabs sorted by genre/artist - foo_uie_tabs with 2 tabs of foo_uie_albumlist, each with an appropriate sorting string
panel to display %LYRICS% - foo_uie_trackinfo with %LYRICS% as formatting string (or anything else that you want to add)
Foobar Gallery
Reply #165
Time for a dumb question.
When I cut and paste code into foobar, it pastes as one continuous block of text, not line by line as it appears in the code box I'm copying from.
What am I doing wrong?
Foobar Gallery
Reply #166
Have a look: Link
Bye
Foobar Gallery
Reply #167
could someone tell me everything that he used in that screenshot ? I'm kinda new to all this and that's the nicest setup I've seen !
I suppose he's using: ColumnsUI, Plysk (?), components for Tabs and playcount.
what is he using for the history... another component ? The playlist with the tree ?
thanks
if someone could add me to msn to explain really quick it would be really appreciated!!
slashdot99 (AT) hotmail.com
thanks.
Foobar Gallery
Reply #168
Thx tHiNkBoNe
Foobar Gallery
Reply #169
Michaell,
How did you change the Main menu font (ie, Foobar 2000 Playlist Playback Components)
Foobar Gallery
Reply #170
Michaell,
[a href="index.php?act=findpost&pid=271193"][{POST_SNAPBACK}][/a]
i imagine he changed his windows font ie so everything has that font. thats the only way i would imagine it could be changed?
Foobar Gallery
Reply #171
mmm.. I see
Foobar Gallery
Reply #172
Columns FAQ
My Foobar :
Foobar Gallery
Reply #173
MrEnergizer: I'd say it's just my windows font lol, I don't know I been on this windows install for ages
Desktop icon font is Georgia 8 I'd say it's the same as the one that's on the foobar thing...
Foobar Gallery
Reply #174
ok Michaell
