Topic: Log-in problem (Read 2886 times) previous topic - next topic
Log-in problem
I've suddenly started getting the reply 'you must enter a user name' when I try to log-in, despite the fact I have done so.
I tried re-registering and got the reply 'you did not click the I Agree checkbox' again having done so.
I'm sending this from a second PC which is on-line through the same router and accepts my log-in.
Any idea what's causing this weird behaviour?
Thunder Bolt
Strikes where least expected!
Log-in problem
Just an idea, not that I'm sure of, but.. have you tried cleaning your "temporary internet files" (assuming you're browsing with IE)?
Sergio
M-Audio Delta AP + Revox B150 + (JBL 4301B | Sennheiser Amperior | Sennheiser HD598)
Log-in problem
Try cleaning the browser cache and delete cookies.
Log-in problem
Tried that, thanks. Made no difference.
I've checked every setting I can think of and can find no reason for this problem.
My second computer is using the same IP address for access and works fine.
[BTW the one that works is running W98SE, the one that doesn't is on XP SP2, although it did work OK until yesterday?
Edit: Corrected URL to IP address
Thunder Bolt
Log-in problem
Check your hosts file (usually under C:\WINDOWS\system32\drivers\etc ) if there's anything other than localhost in there.
Log-in problem
Thanks, CiTay,
I use Tweakmaster, so my hosts file is updated by that.
I deleted the entries, and the original hosts file, and now everything is working OK.
Thanks very much for the help.
Thunder Bolt
