Hey Case,
I bring good news. Before I installed the debug version I found out the problem - it was m-TAGS. Double-clicking a to-be-skipped FLAC track in the playlist directly, it played fine, while same m-TAGS track would skip. So I moved the m-TAGS decoder above Skip Tracks decoder, now everything seems it work perfectly.
Installing debug version, I tested the non-stop skipping issue and was able to push stop button during the silence you mentioned, so that works too. In case I was not clear about that, the freeze was not a typical "unresponsive" app that Windows reports, rather none of the menus or buttons would even highlight in blue when mouse-over'd and clicking them did nothing. (foobar though just doing as instructed, skipping every track really fast
Nonetheless the debug results, not revealing much. The only difference between the two tests was the line "Skipping track..." (track #2 set to skip, double-clicking it...)
Playing correctly (m-TAGS decoder on top):
Skip Track debug: on_playback_starting
Skip Track debug: g_playing_playlist_name = Ben Harper - Lifeline, g_active_playlist_name = Ben Harper - Lifeline, g_playback_order_name = Repeat (playlist)
Skip Track debug: track_command_settrack
Skip Track debug: new g_playback_order_name = Repeat (playlist)
Opening track for playback: "M:\Music\Ben Harper\Lifeline\Lifeline.tags" / index: 2
m-TAGS:: REFERENCED FILE: file://M:\Music\Ben Harper\Lifeline\02 In The Colors.flac [0]
foo_title: Loading album art...
m-TAGS:: REFERENCED FILE: file://M:\Music\Ben Harper\Lifeline\01 Fight Outta You.flac [0]
Skip Track debug: on_playback_new_track
Skip Track debug: on_playback_stop
Skip Track debug: stop_reason_user
And skipping incorrectly (Skip Tracks decoder on top):
Skipping track...
Opening track for playback: "M:\Music\Ben Harper\Lifeline\Lifeline.tags" / index: 3
m-TAGS:: REFERENCED FILE: file://M:\Music\Ben Harper\Lifeline\03 Fool For A Lonesome Train.flac [0]
(Adding to queue works either way. I'm not sure why beta 2 worked with m-TAGS / double-click though...)
Component list, FYI
Core (2019-07-07 08:11:44 UTC)
foobar2000 core 1.4.6
foo_albumlist.dll (2019-07-07 08:11:06 UTC)
Album List 4.6
foo_cad.dll (2019-01-30 15:17:07 UTC)
CD Art Display 1.0.2
foo_cdda.dll (2019-07-07 08:11:04 UTC)
CD Audio Decoder 3.0
foo_converter.dll (2019-07-07 08:11:06 UTC)
Converter 1.5.3
foo_discogs.dll (2019-03-06 17:56:53 UTC)
Discogs Tagger 2.19
foo_dsd_processor.dll (2017-07-21 23:11:13 UTC)
DSD Processor 1.0.1
foo_dsp_eq.dll (2019-07-07 08:10:56 UTC)
Equalizer 1.2.1
foo_dsp_meiercf.dll (2019-02-01 15:44:04 UTC)
Meier Crossfeed 1.1.1
foo_dsp_src_resampler.dll (2018-10-24 12:38:21 UTC)
SRC Resampler 1.0.9
foo_dsp_std.dll (2019-07-07 08:10:56 UTC)
Standard DSP Array 1.3.2
foo_dynamic_range.dll (2014-12-31 14:32:42 UTC)
Dynamic Range Meter 1.1.1
foo_dynfil.dll (2018-10-22 00:56:29 UTC)
Dynamic Fields 1 beta 4
foo_facets.dll (2013-02-17 06:49:54 UTC)
Facets 1.0
foo_fileops.dll (2019-07-07 08:11:04 UTC)
File Operations 2.3
foo_freedb2.dll (2019-06-28 18:42:26 UTC)
Online Tagger 0.7
foo_hdcd.dll (2018-11-23 02:23:06 UTC)
HDCD decoder 1.19
foo_input_ffmpeg.dll (2019-05-06 15:20:30 UTC)
FFmpeg Decoder Wrapper 0.5.5
foo_input_monkey.dll (2019-05-06 15:20:30 UTC)
Monkeys Audio Decoder 2.2.3
foo_input_sacd.dll (2017-07-21 23:11:08 UTC)
Super Audio CD Decoder 1.0.9
foo_input_std.dll (2019-07-07 08:11:30 UTC)
FFmpeg Decoders 3.4.5
Standard Input Array 1.4.6
foo_jesus.dll (2014-11-22 06:37:40 UTC)
Autosave & Autobackup 10
foo_keep_queue.dll (2018-09-04 19:49:47 UTC)
Keep Queue 0.3.5
foo_managed_wrapper.dll (2019-03-15 20:18:01 UTC)
foo_title 1.0.5.25137
Managed Wrapper (.NET) 0.7.3
foo_masstag.dll (2013-02-22 04:51:56 UTC)
Masstagger 1.8.4
foo_musical_spectrum.dll (2019-06-20 02:18:14 UTC)
Musical Spectrum 0.9.1
foo_out_wasapi.dll (2018-11-23 02:23:12 UTC)
WASAPI output support 3.3
foo_playcount.dll (2019-05-06 15:20:30 UTC)
Playback Statistics 3.0.3
foo_playlist_attributes.dll (2019-03-06 17:56:53 UTC)
Playlist Attributes 0.5.5
foo_rgscan.dll (2019-07-07 08:11:12 UTC)
ReplayGain Scanner 2.3
foo_run.dll (2018-07-26 00:26:27 UTC)
Run services 0.3.8
foo_simplaylist.dll (2018-08-27 17:18:12 UTC)
SimPlaylist 1.0
foo_simplaylist_manager.dll (2013-02-23 11:55:13 UTC)
SimPlaylist Manager 1.0
foo_skip.dll (2019-07-17 12:27:31 UTC)
Skip Track 1.10 debug
foo_spider_monkey_panel.dll (2019-06-25 13:19:38 UTC)
Spider Monkey Panel 1.2.1
foo_stop_after_queue.dll (2019-06-20 02:17:52 UTC)
Stop After Queue 1.1.1
foo_tags.dll (2018-11-25 12:37:47 UTC)
m-TAGS 1.2
foo_textdisplay.dll (2019-06-08 12:16:18 UTC)
Text Display UI Element 1.1 beta 1
foo_tfsandbox.dll (2018-08-01 21:25:29 UTC)
Title Formatting Sandbox 1.0.3
foo_ui_std.dll (2019-07-07 08:11:12 UTC)
Default User Interface 1.4.6
foo_uie_eslyric.dll (2018-06-12 23:23:38 UTC)
ESLyric 0.3.6
foo_uie_esplaylist.dll (2019-02-01 13:10:44 UTC)
EsPlaylist 0.1.3.9
foo_w7shell.dll (2018-09-01 22:17:19 UTC)
Windows 7 integration 0.2.9.1
foo_wave_seekbar.dll (2014-09-24 17:55:48 UTC)
Waveform seekbar 0.2.45
At any rate I'm very happy with this new and improved foo_skip. Thanks, Case. Sorry my request took so much mucking about.
Cheers
