Topic: foo_skip: skip tracks that match a specified search query (Read 232371 times) previous topic - next topic
Re: foo_skip: skip tracks that match a specified search query
Reply #625
This is probably a bug of foo_customdb or foobar itself. I'm writing here because customdb thread is closed.
Help me to understand where to send bug report so no one else won't affect this in future.
foobar 2000 1.6.2
foo_customdb 0.1.0_beta1
foo_skip 1.32
I have both components installed, but no such issues. I use cutomdb 9a, though. Why do you think this odd behaviour of foo_skip is caused by customdb, BTW?
I'm late
Reply #626
Well, lucky for you. It's might not be behaviour of foo_skip because it just reads what's in database and doesn't write to it. I opened database in sqlite browser and I saw there new records like skip_track=1.
Reply #627
I see, so you set foo_skip to skip tracks based on the value of a customdb field? I'm afraid this is really off topic here, but the problem might depend on how you set the customdb actions. It's hard to tell without knowing how you edit the skip_track field.
I'm late
Reply #628
Is there other options to keep information about skipped tracks? Where it will be stored? I did my setup a long time ago so customdb seemed the best option at that time. I am at Columns UI and to skip track I use hotkey with "Skip Toggle" action. Bug is probably occured on skipping track with hieroglyphs and other fancy non-typical symbols.
