Topic: Game Emu Player (foo_gep) by kode54 (Read 197622 times) previous topic - next topic
Re: Game Emu Player (foo_gep) by kode54
Reply #575
Hello. I'm having a problem with this component. Whenever I use it to try and play .gbs files, at least with Pokemon Gold/Crystal, everything is all mixed up. For instance, the first track that plays is the "Pokemon March", but the length and tags are those of "Pokemon GS Intro 1". What might be causing this problem?
Reply #576
Sounds like the M3U files are messed up. I can never get that feature right, because nobody has settled on a common behavior for even the subsong numbers.
Reply #577
...nobody has settled on a common behavior for even the subsong numbers.
Well that's inconvenient. Is it something I could fix by messing with the m3u file myself? Or is that more complicated than not?
Reply #578
My code can be changed to deal with the off by one error, assuming you’re running the latest version. The thing is, if it’s correct for your files, it may be off for others.
