Car radio supporting Ogg?
Reply #36 –
Can you consider using a mobile DAP in the car (Lucem wrote about this idea already)?
I do it this way and have plugged my iRiver H140 to my car radio.
It's a pity that car radios usually don't have an adequate connector for this purposes.
But if you are able to solder a little bit it's not a problem if you buy a car radio with the possibility to attach a cd changer. This is the case with my car radio.
I bought a cheap adapter that plugs to the cd changer adapter of the car radio, and soldered a 3.5mm cable (attached to the player's earphone output) to the cd changer connector. Moreover a pin of the cd changer connector called 'cd bus' has to be connected to ground on the cd changer connector to tell the radio it is to use the changer (I do it via a switch so that I can still use my car radio cd drive, but I actually never did it after having connected my DAP).
That's all. I love the idea of a universal music machine I can use on its own and plug to whatever I like.
