Topic: 5.1 AC3 to 5.1 Wav file (Read 16491 times) previous topic - next topic
I am looking for a software solution that will help
me convert a 5.1 Channel AC3 file to 5.1 Wav file
its not seperate 6 mono wav but a single 5.1 Wav.
This file is required so that i can try 5.1 Wav to 5.1 MP3 Surround encoding
as the 5.1 Mp3 surround encoder accepts only 5.1Wav
Please guys let me know.
More info on Mp3 Surround check my todays post
http://www.hydrogenaudio.org/forums/index....&st=0&p=258426&
tried foobar it worked well
but besweet is not working
can u give me a link or the procedure for besweet.
[a href="index.php?act=findpost&pid=258438"][{POST_SNAPBACK}][/a]
Try www.doom9.net for general info on BeSweet.
Also, use the BeSweet GUI in the wizzard mode, available there.
MP3 surround is a waste of time completely.
It is not discrete but matrixed.
Why bother?
All it will do is ruin surround in the same way that it has already ruined stereo.
Why bother?
[a href="index.php?act=findpost&pid=258543"][{POST_SNAPBACK}][/a]
It appears that you don't even understand the conecpt of joint stereo nor channel matrixing. Both of these can be done losslessly and please provde some abx'ing information to prove your statement about stereo separation to comply with the TOS #8.
Hi!
I have a problem of Foobar2000.
When I open the ac3 file, the Foobar write this text:
"INFO (CORE) : location: "file://C:\Kirippelt Filmek\Balszerencse áradása\magyar.ac3" (0)
ERROR (CORE) : error opening file for playback :
ERROR (foo_diskwriter) : Conversion failed.
INFO (CORE) : opening file for playback :
INFO (CORE) : location: "file://C:\Kirippelt Filmek\Balszerencse áradása\hangja.wav" (0)
INFO (CORE) : location: "file://C:\Kirippelt Filmek\Balszerencse áradása\magyar.ac3" (0)"
And my second question: where change I the number of audio channels?
I saw the convert settings, but i didn't find anything of audio channels.
Please help me!
does your foobar have the AC3 plugin installed? (foo_ac3.dll)
Ohh, sorry, I forget the plugin  , but in my computer the BeSweet is working too. Thank you for your help! But I have a new question, but it isn't this topic's problem. I write it too, maybe, you have the answer. I made with BeSweet a 5.1 Ogg audio, because NanDub can read this file format. I want to open the ogg, and the nandub don't read it. nandub need a plug-in too?Now I see another version of nandub, maybe it works.
